Old 01-16-2016, 01:44 PM   #1
shdobxr
Drives: 2015
Exhaust noise
So I have the Ptuning header but there is a sound that I suspect is coming from a specific heat shield coming from the midpipe that joins to the overpipe.
I have a video of the noise, but was wondering if anyone has taken that part off with any bad effects?
I will upload a video of the noise in just a sec. The noise seems to go away when the engine/exhaust is warmer.
shdobxr is offline   Reply With Quote
Old 01-16-2016, 02:38 PM   #2
_gt86_user
Inactive
Drives: .
It's prolly not the heat shield if it's a feint metallic rattle at mid rpm under load then it's normal.
_gt86_user is offline   Reply With Quote
Old 01-16-2016, 05:09 PM   #3
shdobxr
Drives: 2015
I thought it was normal too, would that rattle be the 2nd cat?
Old 01-29-2016, 08:31 AM   #4
shdobxr
Drives: 2015
So what exactly is that noise coming from? Just curious before I go digging around under the car.
Old 01-29-2016, 09:50 AM   #5
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
I had a loose bash plate from hitting a rock.
Could be similar... Thought it was an exhaust issue, but luckily just the plate... Tightened up and all good now.
I like driving!
86 South Africa is offline   Reply With Quote
Old 01-29-2016, 10:26 AM   #6
Cole
Not a troll
Cole's Avatar
I also had an annoying rattle. Thought it was my heat shield coming loose. Turned out it was my O2 sensors were loose. I'd check those too.
Old 01-29-2016, 01:07 PM   #7
rjgough95
rjgough95's Avatar
Drives: 13 Subaru BRZ, 02 7.3 F350 Diesel
Ive had the same rattle for awhile now and i was thinking it had something to do with my exhaust system and the flex joints possibly. I have the uel Borla headers that have two flex joints. Then i have the HKS dual resonator front pipe and Perrin cat back non resonated exhaust which has one flex joint at the connection to the front pipe.
rjgough95 is offline   Reply With Quote
Old 01-29-2016, 01:09 PM   #8
rosol16
Not A Member
rosol16's Avatar
Drives: 2014 Mustang GT
Wait isn't your exhaust suppose to make noise?
rosol16 is offline   Reply With Quote
Old 02-01-2016, 07:49 AM   #9
shdobxr
Drives: 2015
Exhaust noise
I took video of it. I can post it soon. Need to make sure the sound is ok. I'm pretty sure it isnt the skid plate. But more of that heat shield touching something making that noise. I triple checked the o2s when I installed cause once it's in. It's in there.
Old 02-07-2016, 10:54 AM   #10
shdobxr
Drives: 2015
Here is the video. https://s3.amazonaws.com/shdo-pics/v...aust_noise.mov
Old 02-08-2016, 06:52 AM   #11
shdobxr
Drives: 2015
I'll link this to YouTube. Just for kicks.
Old 02-09-2016, 07:54 AM   #12
shdobxr
Drives: 2015
[ame="https://www.youtube.com/watch?v=rxc2e-QNGPA"]exhaust noise brz - YouTube[/ame]
Old 02-09-2016, 05:47 PM   #13
Docmattic
Drives: GT 86
Originally Posted by shdobxr View Post
That would drive me nuts! Sorry don't know what it is though.
Docmattic is offline   Reply With Quote
Old 02-09-2016, 05:49 PM   #14
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Could be the heat shield on the overpipe touching the frame. It's a little more likely than the front pipe touching something.
jawn is offline   Reply With Quote
MLV for exhaust noise and drone? PandaSPUR Electronics | Audio | NAV | Infotainment 19 03-05-2016 10:13 AM
Clicking noise from exhaust? azynneo Issues | Warranty | Recalls / TSB 6 06-16-2015 02:05 PM
Exhaust noise etherealfall Engine, Exhaust, Transmission 7 12-20-2014 04:34 AM
Exhaust Noise that goes away after warmed up FastLane1000 Engine, Exhaust, Transmission 10 08-15-2013 10:06 PM
Exhaust Noise Levels EN2_Squirrel Engine, Exhaust, Transmission 0 07-11-2013 10:32 PM
