02-16-2022, 08:36 PM | #85 |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
Laws of physics don't lie. The only thing that's going to decrease stopping distance is your tire grip. Larger brakes don't do squat if you're tire grip is the same. You will just lock up earlier.
Do BBKs give you more confidence lap to lap? Hell yes. And confidence could be one of those x factors that help you get quicker but on the same skill, they will not yield faster lap times. Do BBKs have a Return on Investment (ROI) compared to stock? Absolutely. Bigger pads, means more material which spreads out the same amount of energy (assuming same laps run) over a larger mass which means peak temps should be lower. This means the material doesn't see as much peak temp damage and the swings in temperature aren't as vicious. There's been videos done on this to calculate ROI.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
02-16-2022, 09:00 PM | #86 | |
Drives: 18 Brz (Sold) / 22 BRZ
You can change the front/rear ratio, and reduce stopping distance (this would need to consider data from the specific setup), but this would bring other issues. A often used solution for that is braking bar to change the bias. Regarding a vehicle where you cannot tweak rhe electronics, than it is better to keep the same ratio, and than the stopping distance may marginally change. |
02-16-2022, 09:19 PM | #87 | |
Thanks for correcting, I fkd up on that. Too late and too tired to write properly. Anyways, arguments stands. I will search the article from Porsche later talking about that on one of the early models (928 or 944, i do not recall) |
02-16-2022, 09:29 PM | #88 | ||
Drives: '23 BRZ
That said, I was frikn thrilled with the brakes on my '17 BRZ, right up until they went nuts at Watkins Glen. I've been tracking with the 40A ABS fuse pulled since then.. |
02-16-2022, 09:44 PM | #89 | |
You're micro'ing at this point and while correct, is missing the point of this thread. In this case, a BRZ with a BBK versus a BRZ without BBK on the same tires.
02-16-2022, 09:54 PM | #90 | |
Not my mother language and I assume that several times I make mistakes (I read my emails 3-5 times before sending, which I do not do on the forum) I used one public example as it was an easy one, and shows how to tweak cars for specific usage. The problem was not the caliper/friction material, but suboptimal tire road coefficient usage. Modern ABS can help mitigating this using EBD, but system is still reactive, when WSS reading reaches some triggers, abs will start modulating pressure, you can also change the triggers to a more conservative like the BRZ. E-Boost can do a even better job on OeM condition, as you can use more proactive controls. I did a quick check on the BRZ calculation (used geometrical calculation, as I do no have access to their AK Master testing), see below, also I did not instrument the car to verify, so take with a grain of salt. If you run one day with VBox, send me wheel end pressure and abs log files and I can analyze for you. |
02-16-2022, 10:14 PM | #91 | |
To calm down, I am going to install a BBK (big beer kit) cheers |
The Following 3 Users Say Thank You to Stonehorsw For This Useful Post: |
02-16-2022, 11:49 PM | #92 |
02-17-2022, 11:17 AM | #93 | |
Drives: '23 BRZ
2018 BRZ tS with huge rotors and fixed-caliper Brembos, 2825 lb on 215/40-18 Michelin PS4: 70-0 in 151 ft. https://www.caranddriver.com/reviews...-drive-review/ 2022 BRZ with dinky rotors and sliding-calipers, 2843 lb on 215/40-18 Michelin PS4: 70-0 in 152 ft. https://www.caranddriver.com/reviews...aru-brz-drive/ |
The Following 4 Users Say Thank You to ZDan For This Useful Post: |
02-17-2022, 01:22 PM | #94 |
Drives: '12 C63 P31, '23 GRC
I'm more curious to see what the distance comparison looks like after 7-10 repeated stops.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
The Following User Says Thank You to WolfpackS2k For This Useful Post: | soundman98 (02-17-2022) |
02-17-2022, 02:39 PM | #95 |
Drives: 2022 GR86
The Following 2 Users Say Thank You to timurrrr For This Useful Post: | Ultramaroon (02-17-2022), ZDan (02-17-2022) |
02-17-2022, 03:02 PM | #96 |
Not sure if someone from Europe have a copy of AMS testing. This magazine have a repeated braking testing that became benchmarking there for braking performance under repeated usage.
02-17-2022, 05:50 PM | #97 | |
Drives: '22 WRB
The Following 2 Users Say Thank You to trippinbillies40 For This Useful Post: | soundman98 (02-17-2022), ZDan (02-17-2022) |
02-17-2022, 06:26 PM | #98 | |
Tags |
big brake kit, brz, gonna happen soon, my big break, wilwood |
Similar Threads | ||||
FS: OEM Brake Rotors + Brake Lines + Clutch Line + Steering Rack Bushings | fc3s_johnny | Brakes, Suspension, Chassis | 11 | 10-05-2020 10:26 AM |
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! | eauto | Brakes, Suspension, Chassis | 255 | 10-15-2014 01:45 PM |
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot | CamryDS | Interior Parts (Incl. Lighting) | 0 | 06-24-2013 11:26 PM |
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
