Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 02-16-2022, 08:36 PM   #85
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
Laws of physics don't lie. The only thing that's going to decrease stopping distance is your tire grip. Larger brakes don't do squat if you're tire grip is the same. You will just lock up earlier.
Do BBKs give you more confidence lap to lap? Hell yes. And confidence could be one of those x factors that help you get quicker but on the same skill, they will not yield faster lap times.
Do BBKs have a Return on Investment (ROI) compared to stock? Absolutely. Bigger pads, means more material which spreads out the same amount of energy (assuming same laps run) over a larger mass which means peak temps should be lower. This means the material doesn't see as much peak temp damage and the swings in temperature aren't as vicious. There's been videos done on this to calculate ROI.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
The Following 3 Users Say Thank You to Frost For This Useful Post:
Daedex (03-19-2022), NoHaveMSG (02-16-2022), ZDan (02-16-2022)
Old 02-16-2022, 09:00 PM   #86
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ
Not true. You’re considering that the brake system was optimized for straight line braking, which is often nor the case.
You can change the front/rear ratio, and reduce stopping distance (this would need to consider data from the specific setup), but this would bring other issues.
A often used solution for that is braking bar to change the bias.
Regarding a vehicle where you cannot tweak rhe electronics, than it is better to keep the same ratio, and than the stopping distance may marginally change.
Stonehorsw is offline   Reply With Quote
Old 02-16-2022, 09:19 PM   #87
Stonehorsw
Stonehorsw's Avatar
Originally Posted by ZDan View Post
People who use "then" when they mean "than", are of course as dumb as rocks. But people who use *than* when they should use *then*, jeezis these people are fuken LOST...
Hahaha
Thanks for correcting, I fkd up on that. Too late and too tired to write properly.
Anyways, arguments stands.
I will search the article from Porsche later talking about that on one of the early models (928 or 944, i do not recall)
Old 02-16-2022, 09:29 PM   #88
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by Stonehorsw View Post
Hahaha
Meantime I deleted my post cuz I was being a bit of an ass
928, 944, they had great braking for the era. Meanwhile 4-channel ABS on modern cars will pretty much ensure short stopping distances.
That said, I was frikn thrilled with the brakes on my '17 BRZ, right up until they went nuts at Watkins Glen. I've been tracking with the 40A ABS fuse pulled since then..
Old 02-16-2022, 09:44 PM   #89
Frost
Frost's Avatar
#lawyered
You're micro'ing at this point and while correct, is missing the point of this thread. In this case, a BRZ with a BBK versus a BRZ without BBK on the same tires.
Old 02-16-2022, 09:54 PM   #90
Stonehorsw
Stonehorsw's Avatar
No worries, after 5 seconds my blood stopped boiling
Not my mother language and I assume that several times I make mistakes (I read my emails 3-5 times before sending, which I do not do on the forum)
I used one public example as it was an easy one, and shows how to tweak cars for specific usage. The problem was not the caliper/friction material, but suboptimal tire road coefficient usage.
Modern ABS can help mitigating this using EBD, but system is still reactive, when WSS reading reaches some triggers, abs will start modulating pressure, you can also change the triggers to a more conservative like the BRZ.
E-Boost can do a even better job on OeM condition, as you can use more proactive controls.
I did a quick check on the BRZ calculation (used geometrical calculation, as I do no have access to their AK Master testing), see below, also I did not instrument the car to verify, so take with a grain of salt.
If you run one day with VBox, send me wheel end pressure and abs log files and I can analyze for you.
Old 02-16-2022, 10:14 PM   #91
Stonehorsw
Stonehorsw's Avatar
#lawyered
Yeah, my bad. I am running stock blood, so it boiled due to the statement. I just intervened for the sake of sharing knowledge.
To calm down, I am going to install a BBK (big beer kit) cheers
The Following 3 Users Say Thank You to Stonehorsw For This Useful Post:
Daedex (03-19-2022), wheelspeed (02-19-2022), ZDan (02-18-2022)
Old 02-16-2022, 11:49 PM   #92
Frost
Frost's Avatar
Old 02-17-2022, 11:17 AM   #93
ZDan
ZDan's Avatar
Drives: '23 BRZ
FWIW:
2018 BRZ tS with huge rotors and fixed-caliper Brembos, 2825 lb on 215/40-18 Michelin PS4: 70-0 in 151 ft.
https://www.caranddriver.com/reviews...-drive-review/
2022 BRZ with dinky rotors and sliding-calipers, 2843 lb on 215/40-18 Michelin PS4: 70-0 in 152 ft.
https://www.caranddriver.com/reviews...aru-brz-drive/
The Following 4 Users Say Thank You to ZDan For This Useful Post:
Daedex (03-19-2022), Frost (02-17-2022), joemysterio (02-17-2022), timurrrr (02-17-2022)
Old 02-17-2022, 01:22 PM   #94
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
I'm more curious to see what the distance comparison looks like after 7-10 repeated stops.
The Following User Says Thank You to WolfpackS2k For This Useful Post:
soundman98 (02-17-2022)
Old 02-17-2022, 02:39 PM   #95
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Will depend a lot more on the pads than calipers.
The Following 2 Users Say Thank You to timurrrr For This Useful Post:
Ultramaroon (02-17-2022), ZDan (02-17-2022)
Old 02-17-2022, 03:02 PM   #96
Stonehorsw
Stonehorsw's Avatar
Not sure if someone from Europe have a copy of AMS testing. This magazine have a repeated braking testing that became benchmarking there for braking performance under repeated usage.
Old 02-17-2022, 05:50 PM   #97
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
FWIW:
TIL if I take a REALLY big poop before my session, I can brake 1' later.
trippinbillies40 is offline   Reply With Quote
The Following 2 Users Say Thank You to trippinbillies40 For This Useful Post:
soundman98 (02-17-2022), ZDan (02-17-2022)
Old 02-17-2022, 06:26 PM   #98
Frost
Frost's Avatar
FWIW:
This post makes me hnnnnnnng.
The Following 2 Users Say Thank You to Frost For This Useful Post:
NoHaveMSG (02-17-2022), ZDan (02-18-2022)
big brake kit, brz, gonna happen soon, my big break, wilwood
FS: OEM Brake Rotors + Brake Lines + Clutch Line + Steering Rack Bushings fc3s_johnny Brakes, Suspension, Chassis 11 10-05-2020 10:26 AM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-24-2013 11:26 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
