03-22-2013, 07:19 PM | #981 |
Drives: 2013 Scion FR-S (manual)
Do what you want. I'm waiting on some 19's as well. Yes the gears will be tall but that can be offset by the gear reduction that some people are already installing. If you can get the correct offset on wheels you can install 235/35/19's in the front and 275/30/19 in the rear. Virtually the same diameter between the two. Of course they are taller than stock. so what
Customize the piss out of it and call it yours!
03-22-2013, 09:35 PM | #982 |
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Um, no. Square on an 8.5 and a 9.5 will either stretch in the back or if the back is no stretch the front will be ballooning. And even if you just square on the front and stretch the back a bit, the fuel econ and steering will be horrible for a DD. That said, 255/35r18 would do the trick...
The Following User Says Thank You to Khyron686 For This Useful Post: | eddieEndo (03-22-2013) |
03-22-2013, 09:38 PM | #983 |
ビーアールゼット
Drives: WRB BRZ '18
Are you a fan of understeer? Why would you want to run an inch wider out back? Just run the same size wheel and tire all the way around--then you have the advantage of being able to easily rotate your tires.
03-22-2013, 10:05 PM | #984 | |
Smokin on Dat Endo
03-22-2013, 10:23 PM | #985 |
03-22-2013, 10:32 PM | #986 |
Smokin on Dat Endo
not if i get different sized tires.. dude if youre not gonna help gtfo i got staggered wheels its my ride
03-22-2013, 10:49 PM | #987 | |
Drives: 01 MR-s, 78 280z, 13 FR-s
The Following User Says Thank You to turbo_jimbo For This Useful Post: | Squishy86 (03-25-2013) |
03-22-2013, 11:08 PM | #988 |
Custom User Title
Drives: Asphalt FR-S MT
Did you not read what was just said? He meant "no stretch" when he said square. So you calling him stupid is pretty ignorant.
The Following User Says Thank You to boredom.is.me For This Useful Post: | eddieEndo (03-22-2013) |
03-22-2013, 11:16 PM | #989 |
I'll offer a retraction of previous statement IF I was the one to read the poorly communicated wording wrong, AND the OP meant a square shoulder setup and NOT square tire. Huge difference considering square tires means not staggered...
03-22-2013, 11:53 PM | #990 |
Smokin on Dat Endo
i didnt ask if i should run square wheels vs staggered telling me to get square wheels is not relevant to my question, by square i meant not stretching the tires for either rim
03-23-2013, 02:05 AM | #991 |
Drives: 2013 WhiteOut FR-S
Lmfao!! 245/35/18 F and 265/30/18 R
The Following User Says Thank You to RehabJeff86 For This Useful Post: | dori. (03-25-2013) |
03-23-2013, 02:18 AM | #992 |
The Following User Says Thank You to husker741 For This Useful Post: | Squishy86 (03-25-2013) |
03-23-2013, 11:05 AM | #993 |
philosopher
Drives: '13 BRZ Sport-Tech CB MT
How to maintain stock wheel/tire diameter with 17x7.5
THE BACKGROUND:
I'm looking to keep my BRZ pretty much stock. The only mod will be the exhaust (Perrin resonated). I can't lower the car for a few reasons which all relate to the fact that I live in Canada and I need to drive in the snow/ice/salt. Since this means I need snow tires, I'm planning on putting a set on the stock rims once these tires wear out. But this means that I'll need to get some rims for the summer, and some summer tires. THE QUESTION: If I move up to 17x7.5 wheels from the stock 17x7, will 215/45/17 tires (Yokohama AD08) maintain the same diameter as they would on a 17x7 set, or would it end up stretching and making the wheel/tire smaller as a whole? Also, any ideas on what looks good on a black BRZ when the car can't benefit from a drop? I figure that the move from 7 to 7.5 opens up some more options. Thanks. |
03-23-2013, 11:54 AM | #994 |
Drives: 2013 Scion FRS "Raven"
I put some Toyo R1R 235/40/17 on the stock rims. It looks amazing, closed the gap between the tire and the body line. The tire is just smaller then the stock tire so it doesn't mess with any settings. Plus the handling is amazing.
Tags |
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
Similar Threads | ||||
Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
