Old 05-31-2014, 01:38 PM   #1317
TmP
TmP's Avatar
Drives: A bunch of 'em...
Ok, I just inventoried the kit and as far I can tell - everything is where it should be.
Also, I feel like I should state that the quality and design of this kit is nothing short of pornographic. I can't believe these things go for 4200 bucks...
That's ridiculous value for your money.
Dat blower bracket tho
TmP is offline   Reply With Quote
Old 05-31-2014, 02:42 PM   #1318
Taino-BRZ
Taino-BRZ's Avatar
Drives: Subaru BRZ-SWP
Ok update: My kit was installed yesterday 5/30/14, did all the labor myself with help of a friend, al i have to say is wow the car is amazing very quiet under low rpms and good power band when you punch it. drove the car today to work with no issues, the tune seems smooth but im upgrading to E85 tune soon. Ill try to get some dyno time next week and ill post the results, overall very happy with my kit. KW was also very helpfull with some minor issues i had.
Taino-BRZ is offline   Reply With Quote
Old 05-31-2014, 05:07 PM   #1319
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Couldn't with the washer bottle and the intercooler piping there....
may the schwartz be with you....
washer bottle? what washer bottle ?
glamcem is offline   Reply With Quote
Old 05-31-2014, 11:30 PM   #1320
zERoTu
Drives: 1st RBv2 10 Series FRS
Picked up mine today. Gonna install it on June 10.
whats the preferred exhaust pipe size to be used with a supercharger? i know turbo is 3 inches. any difference gains between 2.5 and 3.0/3.5 inch pipe with the kraftwerks supercharger?
zERoTu is offline   Reply With Quote
Old 06-01-2014, 11:13 AM   #1321
TmP
TmP's Avatar
Um... how does one use the flash program / cable?
I have installed everything on my laptop, using the interface and the dongle. Now what?
Old 06-01-2014, 11:16 AM   #1322
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Do you have the flash file from your tuner? If you do, have both your USB dongle and USB license key connected to your laptop, connect your dongle to the ODBII port on your car and follow the directions here:
http://blogperrinperformance.com/how...-your-brzfr-s/
If you don't have the file, then you need to get that first.
mit_peid is offline   Reply With Quote
Old 06-01-2014, 12:57 PM   #1323
TmP
TmP's Avatar
I got the kit from KW with the tune.
There's the USB dongle that I needed for the install, the cable for the OBD2 port and a KW usb stick.
Old 06-01-2014, 01:19 PM   #1324
Taino-BRZ
Taino-BRZ's Avatar
Kw USB stick is your tune, that file needs to be uploaded on the ecutek software and then you flash the ecu
Sent from my SGH-M919 using Tapatalk
Old 06-01-2014, 02:16 PM   #1325
glamcem
glamcem's Avatar
another reason to have catch cans this is after one session at this Friday's event
heat wrapped the intake piping and placed the .5" Boomba racing vacuum check valve (on PCV oil catch can)
yes, I can destroy exhaust gaskets
Old 06-01-2014, 06:36 PM   #1326
TmP
TmP's Avatar
Where did you guys put the horn?
Old 06-01-2014, 07:27 PM   #1327
captain_jack
captain_jack's Avatar
I took the horn off the bracket and mounted it on the side of intercooler where it bolts to the mount.
sent from your mom
Old 06-01-2014, 07:37 PM   #1328
TmP
TmP's Avatar
Left it on the bracket and utilized a different hole in the body. (that sounds awful. lol)
Old 06-02-2014, 02:26 PM   #1329
FR-S Matt
Add me to the list @digital_assassin
Ordered today: 6/2/2014
Look forward to the install and performance.
Old 06-02-2014, 02:32 PM   #1330
TmP
TmP's Avatar
Mine is all installed.
What a great fitting kit.
Just a few MINOR things that could be better IMHO:
- Tensioner Pulley bolt: If the head was longer it wouldn't be such an unnessesary PITA to tighten
- Why are there no provisions to clip the MAP and AC compressor cables back into place?
- Blower oil routing / Filter location: Not a fan. Mounted the filter to the strut dome instead.
- Horn: No mention of the need to move it in the manual or any pointers on how to relocate it.
That's it.
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
