go_a_way1
Old 04-30-2013, 04:10 PM   #1247
Nhil
Drives: 2013 Scion FRS
Sorry if this has already been answered but I'm a bit paranoid this wont fit. Looking at a 17x9 wheel with a +42 or +45 offset and a 245/40/17 tire with stock struts and RCE yellows. Will I have rubbing issues in the front? Would dropping to a 17x8 work better or will the tire be my issue?
Thanks in advance!
Nhil is offline   Reply With Quote
Old 04-30-2013, 04:20 PM   #1248
RavSpec
Drives: Rx7
Thanks in advance!
close call. I'll keep 17x9 but drop to 235/40 tires.
RavSpec is offline   Reply With Quote
Old 05-01-2013, 06:10 PM   #1249
nalc
Drives: 13 BRZ Limited 6MT GBS
Is anyone running the 16x6.5 stock wheels from the older WRX on their BRZ?
Seems like they would be a good choice to run a narrower winter tire, they fit newer WRXes so I think they'd be fine with us, but wanted to check.
Based on searching, it sounds like they are 16x6.5, 53mm offset, 16.5 lbs, so they'd be a little more tucked in compared to stock, but by less of an amount than they are narrower than stock, so I don't think there would be rubbing issues.
http://i6.photobucket.com/albums/y24...04WRXwheel.jpg
nalc is offline   Reply With Quote
Old 05-01-2013, 06:14 PM   #1250
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
@nalc they fit... I have a set sitting in the garage I use on burn days. Had them on the car for a weekend.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 05-02-2013, 06:31 AM   #1251
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
The rpf1 17x8 +45, will it fit with the sti Brembo swap?
Old 05-02-2013, 08:55 AM   #1252
Shiftatredline
Drives: 2013 Galaxy Blue Silica BRZ
I am looking at getting a set of Volk GTS wheels. I need some help/advice on the size and options. First let me explain my goal with the car and go from there. I'm planning on dropping it on RCE springs and Koni yellows. Over the next couple months I'll be buying all the various supporting mods with the supercharger being bought in the September time frame and tuned. I'll be using it for DD, lot's of spirited driving and after I've spent some time learning the car possibly some track use. With that being said my confusion is what to run. Unfortunately I can only find the GTS's confirmed in 19x8 5x100. I am waiting to hear back from a company that may have 18x8 5x100 which I'd prefer for tire price's sake. Based on my power goals I'm thinking I am ultimately gonna need a wider wheel. I can get them wider in 5x114 but I'll have to run an adapter, but it will free up various widths and offsets. I've expressed my function concerns, my form is flush with no tuck and no poke. So I'm looking for some knowledgeable input based on my wants and needs for the car, any help would be appreciated.
1997 Acura Integra GSR - JR supercharged 11.5 psi
1998 Mitsubishi Eclipse Spyder Conv. - Forgot Mods
2007 Mazda Mazdaspeed3 - Too Many Mods
2013 Subaru BRZ - Too Little Mods
Shiftatredline is offline   Reply With Quote
Old 05-02-2013, 01:05 PM   #1253
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Supercharger type?
Estimated power output?
Torque curve?
Aftermarket LSD?
Staggered or square setup?
S tire or R tire?
Happy to help. Need more data.
ill86 is offline   Reply With Quote
Old 05-02-2013, 01:11 PM   #1254
RavSpec
Drives: Rx7
Might want to consider a different wheel. GTS are being discontinue now.
Old 05-02-2013, 01:17 PM   #1255
Shiftatredline
Originally Posted by ill86 View Post
Supercharger type?
Torque curve?
Aftermarket LSD?
S tire or R tire?
Looking at getting the Vortech setup with Flex Fuel option tuned. I don't exactly have a specific HP or Torque goal other than to have it tuned safely running as much psi efficiently as I can. I hadn't planned on swapping out the stock LSD as of yet. I would prefer the square but depending on what the opinions are of my setup I'm open to suggestions. I'll be going with a street tire. If I eventually make my way to track or autox I would end up getting a seperate set of wheels for track setup.
Old 05-02-2013, 01:23 PM   #1256
Shiftatredline
I know. I just can't find any other wheel I like at this point. I can be stubborn like that haha
Old 05-02-2013, 02:10 PM   #1257
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
Can someone confirm if its safe to run 18x9.5 +45, 255/35/18 all around with coilovers ?
adprokid is offline   Reply With Quote
Old 05-02-2013, 02:13 PM   #1258
RavSpec
Drives: Rx7
rear yes, front are too much .
The Following User Says Thank You to RavSpec For This Useful Post:
adprokid (05-02-2013)
Old 05-02-2013, 02:30 PM   #1259
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
Do you think a negative camber will be enough or i should go 245/35 ?
Old 05-02-2013, 10:31 PM   #1260
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
No.
17x9 +42 Mach V Awesome, 245/40R17 Direzza ZII.
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
