Old 07-15-2016, 08:13 PM   #113
DSOmegaX
DSOmegaX's Avatar
Originally Posted by kuczynskika View Post
Pictures are up in the original post. Excuse the dirt haha. Sure, I'd be down to paint you one! If you shipped a new garnish to my address we could work something out in terms of labor and go from there? I'd be willing to do a tS badge for you too if you'd like?
Haha nice yeah well touch base. It looks great!
@dsomegax.cars
The Following User Says Thank You to DSOmegaX For This Useful Post:
kuczynskika (07-15-2016)
Old 07-18-2016, 10:36 PM   #114
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
Reinstalled my tS badge today. Had the t coated in real chrome and repainted the S in Grimmspeed Cherry Blossom.
Also installed my STi Flexible Drawstiffeners today. Some notes on the installation:
Overall the process was very easy, just simple bolt ons.
1. Removed protective undertray.
2. Unbolt existing bolt and install RH and LH brackets. (Note on this: reuse existing undertray bolt to align bracket while tightening main bolt. Only reason why I mention this is because is was not super clear in the instructions. See pic pointing to bolt).
3. Install flexible rods with length adjusted to 366mm and then to 370mm
4. Adjust to spec's and torque rod bolts to 20nm.
5. Reinstall undertray.
Impressions:
WOW. This further allows the BRZ to eat corners for breakfast. The response on initial turn in is wonderful. The front end feels tighter and the car feels more nimble and controlled when entering a corner. Overall such a wonderful sensation. Highly suggest to anyone to install this simple mechanical improvement.
kuczynskika is offline   Reply With Quote
Old 08-01-2016, 12:28 PM   #115
kuczynskika
Coming Soon
Old 08-01-2016, 12:53 PM   #116
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Nice! Don't forget the smaller pulley, too.
MS, CSCS, TSAC-F, CPT
Old 08-01-2016, 12:54 PM   #117
kuczynskika
Oh yes, eventually haha
Old 08-01-2016, 01:00 PM   #118
weederr33
weederr33's Avatar
Are you going to keep it CARB legal or add headers to it as well? Hopefully still keeping that sweet cosworth catback.
Old 08-01-2016, 01:09 PM   #119
kuczynskika
The Cosworth catback is going no where. Idk if I can live without out it tbh haha.
And yes, I am going to run the stock tune from Harrop for a while, but eventually I would like to do the full exhaust with the Cosworth/Nameless 1.2 with resonator and the Cosworth/Nameless or ACE CS400 Headers.
Then, I'll be looking for a new clutch, injectors, fuel pump etc.
Then (perhaps in a couple years) look at going for a fully built engine. Thats MUCH later tho.
Old 08-01-2016, 01:12 PM   #120
weederr33
weederr33's Avatar
Sounds like a solid plan for sure!
I think the ACE CS400 headers would be a good set. I've considered switching to those
Old 08-01-2016, 03:37 PM   #121
kuczynskika
Yeah everyone seems to like them and comment on the gains that they make in the torque department.
Old 08-07-2016, 01:48 PM   #122
weederr33
weederr33's Avatar
So did you ever settle on which oil cooler you're going to get?
Old 08-07-2016, 02:42 PM   #123
kuczynskika
No, not yet. Most likely it would be a Perrin. I'd kinda like to pick up a used one for cheap, but after doing research and considering the driving I will be doing a cooler isn't 100 necessary yet.
I also like Harrop's design tho.
Old 08-07-2016, 02:47 PM   #124
weederr33
weederr33's Avatar
I'm thinking about getting the Cusco honestly. So if you wanna buy my perrin, you're welcome to it! But I don't really need a full on oil cooler as I rarely drive crazy. In fact, I almost feel as though I might be over cooling my car, especially during the "cooler" season.
The Following User Says Thank You to weederr33 For This Useful Post:
kuczynskika (08-07-2016)
Old 08-07-2016, 02:51 PM   #125
kuczynskika
Yeah that would be my concern too. Are you monitoring your oil temps or no? I will think about it. Between this, the supercharger install and possibly doing the wheel conversion I've got a lot in flux right now haha.
Old 08-07-2016, 02:54 PM   #126
weederr33
weederr33's Avatar
I haven't monitored my temps. I probably should though....
Cosworth SC build... Ernie L Member's Car Journals 184 09-10-2015 04:25 PM
What did YOU do with your Cosworth plaque? weederr33 Engine, Exhaust, Transmission 31 02-24-2015 04:23 PM
Cosworth worth the $$$$? EAGLE5 Off-Topic Lounge [WARNING: NO POLITICS] 28 02-24-2015 01:12 AM
Stage 1.1 Cosworth FRS FR-S89 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 12-22-2014 01:23 PM
