Old 11-25-2015, 08:15 PM   #113
Trettiosjuan
Drives: GT86
I specifically drove and listened for cluncks and to see if I could notice droop issues or the fronts topping out because of the preload. No such thing. But wouldn't want to run much more preload, there is no top out bump stop, just metal to metal. Remaining droop travel in front is approx 40mm or bit more than 1,5", that usually is plenty for road driving.
If I were you I'd try yours without the preload and see what that does.
Trettiosjuan is offline   Reply With Quote
Old 11-25-2015, 08:19 PM   #114
bfrank1972
Drives: 2013 FR-S Argento
Ah yes - I was thinking about that the other day when I replied to your post saying "I have no issues with preload" Maybe I do? It's not much preload but it's easy enough for me to reduce to 0 preload and try it out.
bfrank1972 is offline   Reply With Quote
The Following 2 Users Say Thank You to bfrank1972 For This Useful Post:
CSG Mike (11-25-2015), Trettiosjuan (11-26-2015)
Old 11-26-2015, 06:26 AM   #115
Trettiosjuan
Drives: GT86
Need to take back some of the above, I drove a very short speedhump today, and I could clearly hear how the front struts top out. Sounds similar to bottoming out, but on the extension fase. So 7mm preload is absolutely the most, perhaps I'll reduce it a turn to 5mm, will see.
Edit: An alternative set-up that keeps most of the height adjustability would be just to use a 7kg spring of the original lenght and without preload, it would still improve bump travel by having the damper sit closer to halfway the travel with the weight on the car.
Old 11-26-2015, 09:26 AM   #116
Trettiosjuan
Drives: GT86
Just drove a very deep pothole at speed, and the preload does clunk when the fronts top out. If I would redo it today I could just go for the original length spring at 7kg, and run it at a small preload of 4mm or so which would be possible because the mini bump stop reduces effective damper stroke somewhat.
Old 11-26-2015, 09:36 AM   #117
bfrank1972
That's where I'm currently at, but I'm wondering if the 4mm at the rear is causing the light clunk noise in the rear - possible the coils are contacting each other. If I can find time this weekend I'll reset the rear preload/height and see if that changes anything. Otherwise I have no complaints, feels great, and the extra camber afforded by the front plates really liven up the front end.
Old 01-29-2016, 07:09 PM   #118
getbent
Drives: 2013 FR-S Blue MT
Do these have exposed adjusters sticking up through the carpet in the trunk like the Flex-Z's?
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
Old 01-30-2016, 04:54 AM   #119
Trettiosjuan
Drives: GT86
Yes. I threaded wheel lugs over so that luggage can't mess with damping adjustment...
The Following User Says Thank You to Trettiosjuan For This Useful Post:
CxG (07-26-2017)
Old 01-30-2016, 05:26 AM   #120
DeaconRoc
Drives: GT86
They do. I fitted a cusco rear brave which offers some protection to them but I never had a problem before to be honest.
DeaconRoc is offline   Reply With Quote
Old 02-21-2016, 01:26 PM   #121
shiftspark
Drives: Toyota GT86
Hi
Does anyone know if these can be used with standard top mounts ? The reason being my local sprint regs do not allow modified mounts with spherical bearings.
Thanks
shiftspark is offline   Reply With Quote
Old 02-21-2016, 04:44 PM   #122
shiftspark
Drives: Toyota GT86
Originally Posted by _gt86_user View Post
Yeah it will work, just gotta trim your carpet area.
Why is that ? thanks.
Old 08-31-2016, 02:04 PM   #123
DeaconRoc
Drives: GT86
The adjusters stick up so you have to trim the side trim panels to let them stick through.
Old 10-10-2016, 10:41 PM   #124
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
Installed Flex A this weekend, and I must say I love this coilovers, after running lowering springs for over a year now and the ride was just getting unbearable day to day.
I'm currently running 9mm of preload front and 6mm of preload in the rear with 9 clicks from stiffest setting and the car feels so comfortable.
I will post how well it handles at the track once I go on novermber, but as a baseline, my car was on Swift spec-r (4.4K front, 5.3K rear) with koni shocks and it was very tail happy with a bit of body roll... so far on the street the teins make the car feel way more planted, but will give a full review once I take it to the track, and yes, I know this are not meant to be corner carving coilovers, but its a compromase I had to make to DD the car without destroying me.
Cartman is offline   Reply With Quote
Old 10-15-2016, 01:15 PM   #125
JW843
JW843's Avatar
Drives: 2013 BRZ Limited
just installed a pair the other night. I only got to take them around the block for a bit but instantly felt better than the eibach sportlines i was on and potentially even better than stock. Had them set about 8 clicks softer than the hardest setting. Going to put them to the test at an autocross next weekend and will update with the results after.
JW843 is offline   Reply With Quote
Old 05-03-2017, 05:42 PM   #126
Anthonyc77
Drives: 2017 Toyota 86 Halo
Bump, anyone have any updates/reviews?
Anthonyc77 is offline   Reply With Quote
Tein Flex A and Z!!! breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 05-24-2016 04:44 PM
Tein Flex Z Bigmaxy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-27-2015 04:22 AM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 04:12 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 02:10 PM
FS: Tein Flex Coilover Jade 86 Brakes, Suspension, Chassis 43 06-15-2013 10:35 PM
