Old 06-19-2015, 01:24 AM   #113
livingambition
Drives: White
Cheers for the Stg 2 98 tune Wayno! Removed the CEL and also seems to have removed my loud exhaust bark at startup.
livingambition is offline   Reply With Quote
Old 06-20-2015, 09:20 AM   #114
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Updated. Mainly MAF scale for stock airbox and some more load limit adjustment for 3000-4000rpm region.
Old 06-24-2015, 02:18 AM   #115
ATaraxias
Drives: 1994 Geo Metro Hatchback
Amazing Stg2 UEL E85 tune Wayno!
It's a complete night and day difference compared to the OTS Stg1 EL E85 tune running on the stock header. I highly recommend it if you are even thinking of going Stg2 on the OFT platform.
ATaraxias is offline   Reply With Quote
Old 06-24-2015, 06:52 PM   #116
efactor84
efactor84's Avatar
Drives: 2015 Scion FR-S
I'm trying to understand RomRaider, so you only can edit your file that matches up the CAL to your BRZ/FRS like Stg 2 EL D00D? That is currently my CAL for OFT. Appreciate if anyone can clarify that for me.
efactor84 is offline   Reply With Quote
Old 06-28-2015, 08:28 AM   #117
Wayno
Wayno's Avatar
Updated.
FINALLY have AFR's that resemble the tune on a MT, meaning it will finally make the power it's supposed to.
Before:
http://datazap.me/u/wayne/206-stg2-u...1&zoom=540-682
After:
http://datazap.me/u/wayne/v74-6?log=...zoom=1483-1637
The Following 3 Users Say Thank You to Wayno For This Useful Post:
drewbot (07-17-2015), phrosty (06-28-2015), steve99 (06-28-2015)
Old 06-28-2015, 11:37 PM   #118
steve99
Your ROM is a block of hex data that contains the program instructions and the tune table data required for the ecu to run your car
A definition file is an index into the ROM , it defines where the most used tune tables are, their are many tables that have not been discovered.
You need different definition for each rom as the tables are in different positions in each ROM. The romraider guys have to reverse engineer the positions of these tables.
Romraider is a ROM editor that uses definition files to allow you to edit and copy ROM tables.
If you have both roms and both definitions you can transfers the tunes data from one rom to another by opening both in romraier and copying tables between roms
Old 06-29-2015, 03:41 AM   #119
Wayno
Wayno's Avatar
Added US MT rom to first post.
It's the same changes as AT including load limits. Only the MAF scale is different.
Would be great if people with MT could test out the load limits, particularly to see if more power is produced at 2500-4000 rpm during WOT.
What to log:
Engine Speed (rpm)
Throttle (percent)
MAF Voltage (volts)
Engine Load (g/rev)
Ignition Advance / Total Timing (degrees)
AFR
Commanded AFR / Target AFR
STFT (percent)
LTFT (percent)
Oil Temp (F)
Fuel Sys Status (2 = CL, 4 = OL)
IAT / Intake Air Temp (F)
Advance Multiplier
FLKC / Fine Learning Knock Correction (degrees)
Old 06-29-2015, 05:00 AM   #120
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
What to log:
Engine Speed (rpm)
Throttle (percent)
MAF Voltage (volts)
Engine Load (g/rev)
AFR
STFT (percent)
LTFT (percent)
Oil Temp (F)
Advance Multiplier
Wayno, dont you have some A00G MT rom ready to try?
I actually feel myself as dumbass with all those digits so i even cannot scale my MAF due to some unknown reason (i assume there is something wrong with computer codes... or with my hands) - just cant load log into vgi maf scaling utility.
But i can log it anyway.
Ondreiko is offline   Reply With Quote
Old 06-29-2015, 05:14 AM   #121
steve99
remove the first 3 lines from the oft log file stuff that says proceed log ect just leave the headers then it will load into vgi utility
Old 06-29-2015, 05:15 AM   #122
Wayno
Wayno's Avatar
I use vgi's tool as a reference, but i calculate and edit my OL manually.
Old 06-29-2015, 05:30 AM   #123
Ondreiko
RWD addicted
Ondreiko's Avatar
this is exacly what i did, but it is unable to load - it writes stange symbols where i suppose the name of my log file should read. The file name is just "1".
Old 06-29-2015, 05:39 AM   #124
Ondreiko
RWD addicted
Ondreiko's Avatar
and it doesnot let me enter the name of the columns into apprpriate fields of that setup window
The Following User Says Thank You to Ondreiko For This Useful Post:
steve99 (06-29-2015)
Old 06-29-2015, 05:42 AM   #125
steve99
Make sure you have latest version of vgi tool
When you edit out those lines in excell make sure you save file as a csv ie comma separated variable and not in Xls or excel format
Old 06-29-2015, 05:46 AM   #126
Ondreiko
RWD addicted
Ondreiko's Avatar
So don't i need to divide columns (comma separated) prior loading into vgi?
My vgi tool is surely latest.
Help uploading 2.06 tunes to OFT Jimmy817 Software Tuning 3 12-28-2014 10:06 PM
Custom Az Tunes Juggles Arizona 13 11-08-2014 11:15 AM
EcuTek Tunes Rio Engine, Exhaust, Transmission 1 04-29-2014 01:10 AM
How long until *other tunes? ScionFrsFan Engine, Exhaust, Transmission 61 12-07-2012 06:34 PM
Speedhunters - TRD TUNES THE 86 quik1987 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 69 05-22-2012 05:26 PM
