#113 |
Drives: 2JZ FRS
I have a set being built. Along with a bunch of other fixes for weak spots and poor high rpm shifting. I'd like to think I'll be testing it by summer, but there is really no timeframe on when it'll be ready for me to install
#114 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
So no real availability then. Ah well. I have an extra transmission laying around and thought I'd look into having it built. Ah well. It's no rush for me. I'm only on a Sprintex 210.
#115 |
Drives: 2JZ FRS
Once I get to beat on it for a little and we make sure it's all good it will be marketed. I'll be testing it at 600whp with mickey Thompson et street radials
#116 |
#117 | |
Drives: 22RE, FA20, 4G63
And that's brings me so many unpleasant memories of my 4G63 (talon AWD). Apparently that gear box(es) we're made out of cheese... Ufff it's all coming back! The heat soak, the timing belt, fry clutch and the easy fading brakes. Man that was mechanic 101 to 3560. Now I'm trying to avoid that rout with the FA20, so ALL fluid should be cool at all times (peace of mind) and AT (no easy clutch upgrade) (BTW that was the fuse that was remove and after that trany start to fall like flys) in the AWD Talon... A good combination was a heavy duty pressure plate with the OEM disc (good because last longer than stoke and didn't break trany as easy)... Outstanding setup? Didn't find it Just move on. Sent from my iPad using Tapatalk |
#118 |
Junior
Drives: a car
Of course it is. everyone knows it's 400.84 whp. C'mon
#119 |
Junior
Drives: a car
@Reaper, have you buy chance fitted an STi 6 spd yet? Assuming that'd be more cost effective than a TKO or T56 or super magnum and definitely a V160.
Yes you'd need a rwd converted one, but would that tack on a lot of cost? Iat just popped into my head, didn't really think about it lol
#120 |
Engineering Student
Drives: Scion FR-S 2015
There’s no time to stop for gas, we’re already late
#121 |
Off Topic
@Reaper, would it be worthwhile to have a custom 4th gear made that can hold the torque that you and others are putting out? I've found a fair number of racing transmission manufacturers that could cut a stronger gear for you. Although that would move the failure point to somewhere else, I'm sure.
#122 | |
Junior
Drives: a car
#123 |
Off Topic
#124 |
Junior
Drives: a car
Thats why I asked about a rwd converted STi trans.
#125 |
Off Topic
You'll have a bump hanging down where the front diff is, but I suppose you could use that to hold more transmission fluid and run cooler.
I'd have to wonder where the shifter would fall. The STI engine is mounted in front of the front axle, and the shifter's right on top of the transmission. Our engine is on top of/behind the front axle, but our shifter is extended backwards from the transmission. It would be perfect if pushing the STI transmission back to mate with our engine lined it up with the shifter hole in the tunnel. Swaps don't usually go perfectly, though. |
#126 |
Junior
Drives: a car
that's the nature of a swap lol
| WTB FA20 Stock | Cross | Want-To-Buy Requests | 22 | 08-19-2014 02:59 PM |
| WTB FA20 Stock | Cross | Want-To-Buy Requests | 1 | 08-01-2014 06:47 PM |
| Stock FA20/trans, never modified 9k miles ATM - April/May | slicktop | Engine, Exhaust, Bolt-Ons | 2 | 02-24-2014 07:44 PM |
| Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? | Acree | Engine, Exhaust, Transmission | 2 | 08-26-2013 06:39 PM |
| Stock AISSIN Transmission Power Capacity | Don@Accelerated | Forced Induction | 37 | 07-03-2013 10:15 PM |
