Old 06-16-2014, 05:52 PM   #113
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
exterior video after waiting months for my camera mount [ame="https://www.youtube.com/watch?v=OGMrf382Kx4"]Subaru BRZ JDL UEL + Tomei Type 80 Stage 2 OFT - YouTube[/ame]
andrew5826 is offline   Reply With Quote
The Following User Says Thank You to andrew5826 For This Useful Post:
mxsled (06-16-2014)
Old 06-16-2014, 06:15 PM   #114
Tenchi
Tenchi's Avatar
Drives: Silver Ignition 6MT 10 series FR-S
What settings are you running?
Tenchi is offline   Reply With Quote
Old 06-18-2014, 07:19 PM   #115
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
check op
Old 10-27-2014, 10:57 PM   #116
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Originally Posted by ML View Post
My unichip does this to my car. After getting on the engine, and then starting to ease off sometimes when I push in the clutch it will pop pretty loud. I'm thinking about ditching it though and just getting a T-cable.
I'm running EcuTek and my car does this as well. It really doesn't matter to me as long as it's not causing any issues with my car.
kmbkk is offline   Reply With Quote
Old 10-28-2014, 01:07 AM   #117
ML
ML's Avatar
Drives: 13 White MT FR-S
wow that was an old quote. I'm on OFT tune now and it still pops, probably louder now with no cats.
Old 10-28-2014, 10:37 AM   #118
BuBlake
Chronic Flashturbator
BuBlake's Avatar
Drives: '13 Scion FR-S MT
Just did the -10 @.15 load in Base Timing B on a E85 tune. This is after just 10 or so miles of driving. Sounds like the Ken Block Gymkhana Fiesta under deceleration. lol
MAF voltage(and therefore engine load) is lowest when decelerating in gear. If in neutral I rarely hear the pops as of right now. Have only scaled my MAF for 3v+ so this may be part of the problem, but I suspect it will get better with time as yours did.
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
BuBlake is offline   Reply With Quote
Old 10-28-2014, 05:28 PM   #119
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
In ECUTek, what would be call the "Base timing B" and the "Primary Open Loop Fueling"?
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
Old 10-28-2014, 05:59 PM   #120
Kodename47
Kodename47's Avatar
Drives: UK GT86
They are just the main base ignition timing map and the main fuel map. It's quite easy to figure out
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
trueno86power (10-28-2014)
Old 10-28-2014, 07:06 PM   #121
trueno86power
[||•]=(86)=[•||]
Great, just wanted to be sure !
Thanks (again lol) for your help
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
Old 10-29-2014, 10:14 AM   #122
BuBlake
BuBlake's Avatar
as requested
Sent from my SGH-I337M using Tapatalk
I noticed that you actually just changed the columns .3 and .4 to .15 and .3 respectively in the open loop fueling table. I'll do the same I guess as they are near duplicates anyways. shoot flames yet?
Old 10-29-2014, 10:53 AM   #123
BuBlake
BuBlake's Avatar
Anyone know if you can add rows to our ROM? I would like to add rows to the open loop fueling table.
Old 10-29-2014, 11:05 AM   #124
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
The Following 4 Users Say Thank You to SomeoneWhoIsntMe For This Useful Post:
chaoskaze (01-13-2015), DriveDriftDogfight86 (09-01-2019), FRSBRZGT86FAN (01-02-2016), Roadcone (09-19-2016)
Old 10-29-2014, 12:46 PM   #125
Kodename47
Kodename47's Avatar
Drives: UK GT86
Not in standard maps, no. You can rescale the axis though to suit.
.: Stealth 86 :.
Kodename 47 DJ:
BuBlake (10-29-2014)
Old 10-29-2014, 12:52 PM   #126
BuBlake
BuBlake's Avatar
Stage 2 E85 tune with afterfire here:
[ame="https://www.youtube.com/watch?v=8t-Tjm4XGTY"]FRS just the afterfire(edited) - YouTube[/ame]
Had to give just a tiny bit of throttle after revving to get it to work. Not sure exactly, but I guess I wasn't in the right load range. May do some logs of just revs and see what's happening.
Thanks! @andrew5826
rom tuning for pops and backfires andrew5826 Software Tuning 110 12-23-2016 04:39 AM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 05:29 AM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 07:48 AM
OFT-Help with Romraider/FFS and Launch Control-issues continuecrushing Software Tuning 9 04-17-2014 11:07 PM
Possible backfires Bg8780 Engine, Exhaust, Transmission 0 05-22-2013 02:12 PM
