#113 | |
Drives: Sterling BRZ Ltd
Interesting, luckily swapping turbine housings is cheap enough that its completely viable to try some options. I plan too.
| The Following User Says Thank You to mrk1 For This Useful Post: | Ironsquid (02-19-2014) |
#114 | |
My point is that if you were to experience all three, you'd have a more sound basis on which to make a judgement, and would likely find the difference to be far less than expected, as I did. I wouldn't have believed it either if I didn't experience it for myself. Sorry if you think my post came off as a bit of a **** (it did, I agree), but I really think you should take a ride before casting judgement based on experience with other cars or from applying what I agree is common knowledge on the subject. |
#115 |
Drives: AE86, 2x GT86, TE27
My opinion on spool is its more noticeable on a daily commute. I don't doubt on ride alongs up and down the highway, that a bigger turbo doesnt feel much difference. Ditto on the track.
For me, spool difference of even a few hundred rpm can make the difference of whether the turbo is in boost when I come out of a corner, or whether I have to wait for it; which then inturn governs whether I'm happy with the entire setup or not. I want my turbo to hit like a lightswitch at 3300-3500rpm. I'll either use the accelerator to modulate this if I want traction, or I'll keep it buried and enjoy the fact I dont have to clutch kick my car anymore to hang it out. |
#116 | |
#117 |
Yea for sure. I'm just not planning on driving my car like that. Its a street car. Not a track car (have one of those) not a highway car (dont have enough of them here)
I drive my street car on tight twisting roads, where spool and response make or break the experience. There are VERY few spots you even get into 4th gear. http://goo.gl/maps/P8aWv I actually wont be using anywhere near 300whp on these roads, for most of the time. My gt86 NA keeps up with STIs now, on all but the most open sections. |
#118 | |
Drives: 2013 "AVO Orange" FR-S
Turbo used was a "small" 18G size turbo, the one that ships in our kit, and seems to be the reference point for small in this forum. Never mind that we'd rate it on the large side for a 2.0-liter. Everybody has different power and drive-ability goals, and I of all people respect that greatly. There is a balance to everything, and finding the right one for everybody is impossible. But some of the claims are a bit outrageous, especially the one where a small turbo will break things faster than a large one. There is a whole lot of automotive manufacturers with billion dollar budgets who are getting it all wrong then - hell, I owned one of those mistakes, a 2.0-liter twinscroll legacy who's peak torque was reached at 2400rpm out of the factory. They've since lowered it to 2000rpm. Did a lot of time attacks and circuit racing in that particular car. Only thing I broke was the front drift, and that was from doing a 360 around a cone at the end of a hill climb. Did a small turbo setup on some cars cause breakage issues? Yes. Did a large turbo setup on some cars cause breakage issues? Again, yes. Does it apply to this car with these setups? There is no definitive answer, the car is new, and the highest mileage cars with FI are still only in the 20k~30k range. If we are to base everything off of what has happened with other vehicles, then we'd all still be running 5~6psi max, because that's also all that boosted Subaru N/A motors traditionally could take (12+ years of experience doing that!). |
#119 | |
Drives: Silver BRZ
to counter this argument is simple... The motors to which you are referring were designed for that torque... The fa20di motor is not. It's designed with that sub 200ft lbs of torque.. big turbos ease the torque on making it "somewhat" safer. not saying big turbos are "Safe" by any means. think of it as someone dropping 300lbs in your lap or setting 300lbs in your lap... |
#120 | |
And my argument was, if a bigger turbo is "inherently" safer because of "gradual" torque (and I'm still not sure how jumping 200ft/lbs over a 1000rpm range is gradual), then why doesn't the manufacturers clue in to that? The easy answer to that is that, for them and their customers, it is about daily driver response, gas mileage, and area under the curve. And given their budgets, they can and do design and tune for a turbo that will work through closed and open loop with reliability and smoothness. The new Legacy motor that made peak at 2000rpm? A variant of the FA20, the turbo version. |
#121 | |
Boosted
Drives: Not a supra....yet
What about the ability of these small turbos to hold to redline, even in the graph you guys posted above it tapers off after 7000 ? Sent from my IBrick
#122 |
Junior
Drives: a car
Listen, guys guys guys. guys. If you want boost early, get a supercharger. If you want more power, get a turbocharger. But wait, why not both?
http://www.ft86club.com/forums/showt...t=44768&page=1 /thread Lol jk
#123 |
just going to leave this here,
#124 |
Drives: DGM BRZ Limited
GTX3076r correct?
I wonder if the GTX3576r would need the ported shroud housing? the 76mm typically comes with the ported shroud since it was mated to a small turbine. The larger turbine should allow you to get rid of the larger housing which could actually free up some space. |
| The Following User Says Thank You to Coheed For This Useful Post: | mrk1 (02-21-2014) |
#125 | |
#126 |
I've gone turncoat and changed to a gtx3071r.
I've plotted it at where I think a pump tune will be. Basically 10psi resulting in 320whp at 7500rpm. It's good to also see that should my car be able to spool the turbo freakishly earlier at 3000rpm, that it's still inside surge. A 76mm wheel moves this surge line to the right, risking compressor surge. So this gives me faith in using the 71mm wheel, in opting for the t04b cover instead of the t04e. That means I have two things working in my favour over a gtx3076r in terms of spool, a smaller comp wheel, and a regular non anti surge comp cover. I've also opted for the 0.63 ex housing. All this, combined with the smaller runners of the jdl manifold gives me a lot of hope for a great street kit. 3000rpm and 7500rpm plotted @ 10psi ![]()
| !!!Limited time only sale on Greddy Turbo Kits with Free Boost Gauge!!! | vividracing | Forced Induction | 0 | 01-24-2014 01:30 PM |
| "My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) — General Topics | 48 | 08-09-2013 06:34 PM |
| Turbo Kits: Rational boost threshold yet? | Ryephile | Forced Induction | 88 | 01-22-2013 12:05 AM |
| Hyundai Calls 2011 Sonata Turbo "Very Delicious," Reveals Near-Term Future Plans | vh_supra26 | Other Vehicles & General Automotive Discussions | 1 | 02-19-2010 02:53 PM |
