#99 | ||
Drives: AE86, 2x GT86, TE27
All the cars and turbos I have quoted, I owned, and tracked them. Granted I didn't tune them. If there is no lag difference between your gtx2867r and a gtx3076r, I blame the tune, or the car. Show me a dyno where one turbo has been taken off and replaced with the other and there is no lag difference. You can see on the PTUNING kit where the max boost is reached. Its around 500 - 1000rpm later than a gtx28, depending on whos dyno you are comparing it to. I'm not saying that a gtx28 turbo will make the same power as a gtx30. I'm saying that using a gtx30/35 for a hp target that a gtx28 can easily reach is not always better. I spent the day at the track yesterday driving my ae86 drift car. 2000cc, 400whp. Spins up 4th gear while spooling. It just makes me laugh when I'm out there driving that, that there are people here talking about having more than that in a street car. This is pump gas. 10:1 static comp. Oh, and its a t28 frame turbo. (Tomei M8270) Not even BB. ![]() Granted, I am considering replacing that turbo with a gtx3067r. I think it's well suited to what I want from the motor. I'll stick around the 400whp mark, but it should spool sooner (because BB and billet), and run cooler. But, take note, I'm at the 400whp mark, making the call to go from t28 frame to t30 frame. I wouldn't be making that call at 300whp. gtx28 for 300whp all day erry day. Look, we all have different goals, and I'm doing is putting forward a counter arguement; as I dont like seeing a heavily one sided thread, which will then lead others to believe its fact. Last edited by diss7; 02-19-2014 at 06:33 PM. |
#100 | |
King of Kiwi Palace
Drives: Faster than you
#101 |
Drives: Firestorm 6MT
So given how heat management is crucial on this car jumping to a turbo slightly bigger than what you initially had in mind would benefit you all around. I had in mind a gtx2867r because of its great success but now I'm tossing that option out and going a step further.
#102 | |
All I will add, is that you can still compare it to other motors, but go in knowing the difference. When I was trying to to research on my 3sge beams, all I had to compare it to was a sr20. But I know my beams was a better motor, so it would perform better. High comp helps spool and response of all turbos. It might make a big turbo streetable for you. But it will also make a smaller turbo, that much more responsive. |
#103 | |
The gtx turbos I would chose would be gtx2860r 0.63 gtx2863r 0.86 gtx3067r 0.63 gtx3071r 0.63 gtx3576r 0.63 gtx3582r 0.86 Starting at the smallest, which would be my choice for 275whp. Each one would be my choice adding another 50whp. They'll all do more than that, and obviously well less as well, but they'd be my choices. |
#104 | |
King of Kiwi Palace
#105 | |
You do realise its power that bends rods. Not boost. The rods will bend from power. Its like you think turbo a @ 10psi making 300whp, and turbo b at 8psi making 350whp, that the motor is under less strain with turbo b. Edit - (obviously there are situations where turbo b will be less stresss, if for example turbo a is really poor VE) The the point I'm trying to get across, is that I see signs on these forums that people thing turbo boost is the governing thing; and that a large frame kit like ptuning running 6psi and making 340?hp is just as safe as a small frame kit like avo running 6psi and making 240hp. Anyway, I've put enough counter points forward to raise some discussion. I'm not here to convince anyone to my line of thinking; and I don't necessarily think you big frame boys were either. People need to make their own decisions. James for example, he had one turbo, went for a ride in another car with a different turbo, and now wants to go that way. Thats the best scenario, when you can experience that, and make the call yourself. I've had similar experiences, but the other way; enjoying my car better with a smaller turbo. Last edited by diss7; 02-19-2014 at 07:04 PM. |
#106 | |
King of Kiwi Palace
torque breaks. Progressive power v/s sudden power, thats the risk you assume.
#107 | |
![]() Yes, it's responsive. But sudden? Far less sudden than a setup that is basically doing nothing till 4000 then gains up to 200ft/lbs of torque over 800rpm. Now, that's sudden. However, a large turbo is certainly easier to tune - you don't have to do much to the tuning until you are well into open loop. |
#108 | |
But some people want sudden power. Like me. Sudden turbo spool is awesome for drifting, for the exact reason you hate it. It breaks traction. Upgraded axles are a cheap fix. The box is all down to how you drive it. I destroyed my synchros NA. |
| The Following User Says Thank You to diss7 For This Useful Post: | Ironsquid (02-19-2014) |
#109 | |
King of Kiwi Palace
![]() And you threw up a dynograph without saying what turbo was used and I assume thats an 86. This entire thread makes me really sad. Just noticed you said large frame turbo. You realize they are putting bigger wheels in smaller housings now right? This isnt the 90s
#110 |
Drives: Sterling BRZ Ltd
A+, this thread just has big turbo in the title so its more of the people who choose larger turbos.
#111 | |
The dyno above is a motor with headwork (but still stock cams) bigger valves, and custom intake and exhaust manifolds. Remember psi is a measure of the restriction of the motor, in other words the pressure is a result of a restriction. Having custom manifolds and head work allows the motor to breath easier, so it is less of a restriction, so it takes more air at the same psi. For example, that same turbo on an sr20 needs 1.5bar to get to the level I reached with 1.1bar. But the turbo is out of puff at that power, so I run the 0.9 bar (400whp) as my map. As for the fa20, its more a case of knock than psi. I'm not in a position to comment on what is safe and what isn't. I'm not a tuner, and haven't boosted my car yet. But the more I see 400hp + builds, it gives me faith in raping the car at 300whp. |
#112 | |
Drives: DGM BRZ Limited
Mind you, all my testing has been done at higher elevations. This has an impact on the turbos performance in a lot of different ways, so sea level results can vary to my personal experiences. Likewise, I've tested a lot of the housings for several of the garrett turbos and the .86/.82 housings have always out-performed the smaller counterparts without any cons to how the power is delivered. The smaller housings do seem to spool a bit softer and give a more linear feel to how the boost is felt. The larger housings can have a rather abrupt boost onset which could be a bit harder to control, but I love the feeling! I tested the .63/.82/1.06 housing on a GT3076r back to back and the larger housing did make more power. The 1.06 had iffy transient response, but really just felt like a non-bb turbo. The compressor never surged with this housing though, unlike the others. I bet the 1.06 would work decently well with the non-ported shroud compressor cover. Should help improve the efficiency of the compressor. I don't have the time or resources to do this kind of testing anymore. |
| The Following User Says Thank You to Coheed For This Useful Post: | diss7 (02-19-2014) |
| !!!Limited time only sale on Greddy Turbo Kits with Free Boost Gauge!!! | vividracing | Forced Induction | 0 | 01-24-2014 01:30 PM |
| "My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) — General Topics | 48 | 08-09-2013 06:34 PM |
| Turbo Kits: Rational boost threshold yet? | Ryephile | Forced Induction | 88 | 01-22-2013 12:05 AM |
| Hyundai Calls 2011 Sonata Turbo "Very Delicious," Reveals Near-Term Future Plans | vh_supra26 | Other Vehicles & General Automotive Discussions | 1 | 02-19-2010 02:53 PM |
