Old 03-06-2012, 05:39 PM   #113
tachi1247
tachi1247's Avatar
Drives: 04 BMW 330i & 03 Mazdaspeed Protege
Originally Posted by SVTSHC View Post
The models they've driven are what we'll be seeing in the production models. If they added more power to this thing then they'll be adding $$ to the pricetag, because with 50-60 more bHP at this weight this thing will be hanging with STI's.
I'm just saying that prior to the first car being sold and prior to actually driving the car without big brother looking over their shoulder it is way too early to claim they have duplicated the magic of the miata.
I would expect a more powerful version to cost more money. don't think I ever said they should deliver more power for the same 25k. if it hangs with an sti that would be great and they could charge sti money for it. this car is different enough from a wrx that they could sell both even if they have similar straight line performance numbers.
tachi1247 is offline   Reply With Quote
Old 03-06-2012, 05:46 PM   #114
Capt Canuck
Drives: BMW E36 323is
Originally Posted by tachi1247 View Post
The rx-8 also had glowing reviews when it was released and we know how that turned out. No torque = no fun for a lot of...
...people.
Some folks do not like having to do anything then put their foot down and for those people they may indeed not like the FRS/BRZ.
Those are probably the same people that like flying away from people on motorway onramps and talking numbers down the pub.
If people cannot get their head around what the initial version of the FRS/BRZ provides, that is not the manufacturers fault.
Capt Canuck is offline   Reply With Quote
Old 03-06-2012, 06:36 PM   #115
serialk11r
Drives: '06 AM V8V Coupe
Now to address your question, yes there is a difference. It's the reason that most people end up buying a sports car. They want performance. A truly good sports car has both great handling and good power. If I'm driving a corolla, I expect to have to make that downshift, if I'm driving a sports car I don't. It's all about expectations. In a time when an affordable 4 door family sedan can hit 60 in ~6 seconds expectations are higher for a sports car.
First of all, a properly designed street going car does not have a lot of passing power in the highest gear. The whole point of a gearbox is so you can shift down to get more power, shift up when you don't need it. Exception would be supercars which have enough power to use more than 6 gears and so much displacement they can't be geared efficiently.
Second of all, a Camry V6 does 0-60 in 6.5 seconds, which the FRS/BRZ can possibly beat. An Accord Hybrid, the most powerful Accord, similarly does 6.5 seconds. Normal Accord V6s are 7 seconds or so. Aka, no Honda produced in the last several years besides the S2000 can outaccelerate this car, no Toyota produced recently (non-Lexus) can outaccelerate this car.
Third of all, I have seen maybe 2 Accord Hybrids ever, and while I do spot Camry V6s sometimes, on a typical day I don't see one.
A 3.5L engine is ludicrously big for a family car, it's pretty good already that this car is likely faster than said cars.
Old 03-06-2012, 06:37 PM   #116
OrbitalEllipses
Drives: Attitude
But it takes 7.6 seconds to get to 60 in a German-spec BRZ/GT/86!
Old 03-06-2012, 06:42 PM   #117
serialk11r
Where did you see that? Everything I've seen is under 7.
Old 03-06-2012, 06:46 PM   #118
OrbitalEllipses
Drives: Attitude
http://www.ft86club.com/forums/showp...0&postcount=51
Old 03-06-2012, 06:54 PM   #119
serialk11r
Yea I just saw, I think it may have to do with an extra shift getting to 100kph rather than 60mph, which should be reached in 2nd. Most magazines are saying it should be hitting 60 in under 7 seconds. I bet having the engine revved a little and dropping the clutch would drop it a lot since the engine is extremely weak below 2500.
Old 03-06-2012, 06:57 PM   #120
LSxJunkie
LSxJunkie's Avatar
Drives: Car
Well fine, given the example I can see your point. I typically just wait for an opening then go around jump into the next lane. The point I was making is that toyota/subaru tailored this car in a direction that would make it a great entry level RWD sports car with a dynamic feel to it. The car more than delivers on that as seen in many reviews the power can always be added later if need be.
Lets take this from a performance perspective. There aren't very many new RWD vehicles out there that offer drivers that might not be the best a chance to safely improve their skills without putting them at life threatening speeds. That was the whole reason behind putting prius tires on the car as well. Sure 100 more HP and sticky tires would have made the car a hell of a lot better but it would also raise the threshold the driver has to get to in order to make the car far/the threshold new racers would need to get to in order to start learning how to handle oversteer, heel toe brake, know what to do in an "oh shi-" situation (and IMO that's the most important), etc..
Not to mention the car would go up in price, which you have to consider how much R&D and platform development went into this car. What they're asking for it is a hell of a deal.
I don't disagree. I get it. This is a great "my first sports car." I'm just fighting the assertion that this is all the power you should ever have or can use because it's just enough. Having driven far more powerful cars daily, it's less power than I want for anything other than a daily driver. However, that's not the point of this car.
And, to be quite honest, I don't consider a 370Z on its stock tires (and a shit ton of oil coolers) "life threatening" as a tool for teaching drivers how to drive competently. Monticello uses 556hp CTS-Vs for their track instruction cars. Bondurant uses Camaro SSs and Corvettes. Spring Mountain uses Corvettes. Skip Barber uses a mix of MX5 Cup cars and Open wheel formula cars.
I think what you're trying to say is that this low power and low grip combination will allow people to hoon around on the street and wreck without killing themselves. Things happen slower so they'll learn to drive their cars. I agree with you, but I'm just saying that there are a LOT of people out there who don't fit this profile, and know how to use more than 200hp going through the rear wheels.
I'm not saying this car needs more power. I'm saying that the idea that this is all the power you could ever want, need, or can use (in any car) is plain wrong.
LSxJunkie is offline   Reply With Quote
Old 03-06-2012, 07:09 PM   #121
tachi1247
tachi1247's Avatar
That would be ome awfully poor engineering on subarus part to need an extra gear shift to hit a benchmark acceleration figure. Its only a 2mph difference.
Motor trend clocked 6.5 seconds for the 2012 camry hybrid. Hybrid! As in maximum economy vehicle. A mazda 6 and a nissan altima are also in the low to mid 6 range. A mt accord coupe can hit 60 in 5.9 seconds.
Old 03-06-2012, 07:18 PM   #122
serialk11r
The Camry Hybrid has a 105kW electric motor, nothing to scoff at!
And let's not forget Motortrend said this car was estimated 6.2s. Has anyone actually been able to time this car?
What do you mean awfully poor engineering? The benchmark itself is stupid. It's already been calculated that the car can't hit 62 in 2nd gear I'm pretty sure.
Old 03-06-2012, 07:30 PM   #123
Capt Canuck
Want sure, need no. Unless you are towing/hauling something there is no need for a big capacity engine.
I sure would like a 997 911 GT3 RS. Do I need that power, no, not in the least.
The FRS/BRZ does not need more power to get people from point A to B to C and down to Z.
You like alotta oomph. Great, we all like different things. But to make out like driving is a tedious, endless slog without a large capacity engine in a car is plain wrong.
Old 03-06-2012, 07:30 PM   #124
OrbitalEllipses
Drives: Attitude
Check the ratio of 2nd gear and use the 4.1 rear end to calculate speed: 95KPH at 7500RPM. This is with 215/24/17 tires.
Multiple times.
Old 03-06-2012, 08:26 PM   #125
86'd
86'd's Avatar
Drives: 2012 WRX Sedan
I asked this question to my friend a few weeks ago:
How fast, percentage wise (out of all of the cars/trucks on the road), is say, my Civic SI, 0-60?
Now I know the time is mid to low 7s. So what, 90% faster than all of the cars on the road? 70% 95%? 60%?
Then I found this:
It's all of the cars motortrend has tested in the past 5 years. The average age of cars on the road today is 10.8 years, moving that meaty part of the curve over a bit to the right.
Meaning, (I don't know the exact percentage, I'd still like to know) 6.5 is plenty fast especially vs all the cars on the road.
But truth be told if I wanted to maximize my fun I would obviously buy an Accord Hybrid. . .
86'd is offline   Reply With Quote
Old 03-06-2012, 08:31 PM   #126
serialk11r
Can't use that graph, because although relatively few models of cars are slower than the mode, the slower cars are by far the most common on the road. Don't worry about it, I'd say 95% of the cars I see on the road are basic Camry/Accord/Civic/Corolla/Focus/minivans/trucks, which are all slow.
Question jay4prez Off-Topic Lounge [WARNING: NO POLITICS] 9 10-23-2020 11:31 AM
Question about the nomenclature.. RadOnc Scion FR-S / Toyota 86 GT86 General Forum 46 12-14-2013 11:55 PM
Stupid Question Canibuz Engine, Exhaust, Transmission 24 03-05-2012 09:50 AM
Engine Question alex05 Engine, Exhaust, Transmission 4 02-21-2012 06:08 AM
