#113 | ||
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
Getting back to the states and seeing this
Went through a few threads and found some good nuggets. Quote:
Software Update and bulletin with describes the issue. It appears Toyota acknowledges there is an issue. http://www.ft86club.com/forums/showp...2&postcount=65 This makes a lot of sense to me Quote:
http://www.ft86club.com/forums/showp...1&postcount=28 Few youtubes in the middle of that page of the sound that may be caused by the O-ring failing http://www.ft86club.com/forums/showt...t=20930&page=2 I did ask @Jeff@Perrin and @Chris@Perrin about it. They just sent me a new tune for the Vortech system which they say should prevent the issue. I may listen for a few days before flashing to see if I have it. I haven't heard anything unusual so I don't think I have it fortunately.
#114 |
Drives: A lot of supercars.
Been in the shop since May 6th. Still waiting on the brand new DI's to be shipped straight from the manufacture in Japan. 2nd time ive been back to the dealer for a DI leak.
#115 |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
are you turbo?
#116 | |
I'm NA, with a Perrin CAI |
#117 |
Drives: 86 (FR-S)
Soshite e85 ne? I know we aren't blaming e85 yet, but if it's involved it should be listed.
#118 |
Drives: 2013 Black FR-S
can anyone explain why there is detonation during this On-Off-On situation during upshifting from high rpm?
#119 | |
Drives: 2010 BMW M3, 2013 Subaru BRZ
If I knew about this issue I would of refrained myself from shifting where I shifted and rather taken that corner slower. Just like what Robi said, I knew exactly where it happened after I read about the shifting and on and off throttle. |
#120 | |
Would you mind detailing the scenario so that others can maybe avoid doing it? |
#121 |
Drives: GT86
Because it takes a short time delta for the ECU to measure load again once you quickly drop the clutch. During this delta, the spark angle is too advanced which causes the transient det. The transient spark table is designed to interpolate between the old and future spark angle during a gear change.
#122 |
Drives: GT86
I hope this block doesn't use nikasil...
#123 |
My scenario is Streets of Willow turn three going counter clockwise (aka the fish bowl) so entering it I am at 2nd gear and I hit redline there. If I dont shift I bounce around redline, if I shift to 3rd I get maybe around another few mph before I have to brake and shift down back to 2nd. If I stay in third, I dont have enough power since it is uphill after that. So here is an example of the on and off throttle while shifting down up down which is said to have caused the issue.
#124 |
I see thanks RAWR!
You are on stock tune? I am wondering how much damage I have done to my seals after the 5-6 track days I have done already this summer... I haven't gotten any factory flashes yet and I bought the car last July. |
#125 |
Drives: 2013 Asphalt FR-S
I've done zero track days and mine are toast...
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703 |
#126 | |
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
| FRS-BRZ Port Fuel Injector (interesting) | Element Tuning | Engine, Exhaust, Transmission | 50 | 04-21-2016 04:26 PM |
| Need Help - 2 codes thrown | jpit | Issues | Warranty | Recalls / TSB | 3 | 04-20-2013 12:41 AM |
| Bulb codes | JDMenrique | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 02-17-2013 03:25 PM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 0 | 08-21-2012 05:03 PM |
