Old 05-27-2013, 01:38 PM   #99
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Opposed View Post
\Its ok Pops usually happen after the car was started, typically for the first 5-8 seconds, then it idles fine. I got it this morning actually. Temps were in the mid fifties. I am running his latest 1.11 version of the E85 tune. It also did it on pumpgas as well.
Gotcha. I can't say that I've had that ever happen to me before. Best of luck getting it figured out.
Old 05-27-2013, 01:49 PM   #100
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Is there any video of the popping sound? Every now and then I get popping from the intake when doing aggressive down shifting or letting the car do its auto blip down shift when in automatic mode.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 05-27-2013, 02:26 PM   #101
Opposed
Drives: 2013 Asphalt FR-S
Post number 29 in this thread http://www.ft86club.com/forums/showt...t=20930&page=2
And there is a video on page 2 of this thread.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 05-27-2013, 03:06 PM   #102
feldy
feldy's Avatar
Thanks.
Old 05-27-2013, 06:33 PM   #103
RAWR BRZ
Drives: 2010 BMW M3, 2013 Subaru BRZ
Originally Posted by mad_sb View Post
http://www.ft86club.com/forums/showp...2&postcount=65
Confirmed sofware update for injector seal failure.
It says the Root Cause:
Under certain engine operating conditions, significant increased temperature & cylinder pressure occurs due to combustion knocking.
Combustion knocking occurs only when the following conditions are met:
1. Full engine acceleration, Wide Open Throttle [ON->OFF->ON within 0.6sec] during gear shifting.
2. The above operation occurs when the engine rpm is above 5200rpm. = shifting up rapdily from 3rd to 4th, 4th to 5th, 5th to 6th from 7450 rpm. (E.g. shifting from 3rd @ 7450rpm up to 4th finishing @ 5864 rpm)
NOTE: Investigation results revealed that this condition is observed during track usage, and a unique aggresive driving style, not during normal driving.
That last part pisses me off to no end, So running the car up to the factory rev limiter and shifting gears is considered aggressive track driving... sounds like they intend on F'ing people out of the warranty repair of the seals.
It also states that it retards timing above 5200rpm, does that mean it reduces power above 5200 rpm? Accelerate slower?
RAWR BRZ is offline   Reply With Quote
Old 05-27-2013, 07:55 PM   #104
mad_sb
No, it is transient retard, timing gets pulled when you lift off the throttle for the shift. Should not affect power at all.
The Following User Says Thank You to mad_sb For This Useful Post:
RAWR BRZ (05-27-2013)
Old 05-27-2013, 08:30 PM   #105
RAWR BRZ
Any one in North America have the injector seals replaced yet? How long did it take? I need mine replaced and service isnt open today because of memorial day... I need it done before Saturday for a track day...
Old 05-27-2013, 08:40 PM   #106
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
I will soon lol
And i got no warranty
Old 05-27-2013, 09:12 PM   #107
Dezoris
Dezoris's Avatar
It is stupid simple to fix on your own. Download service manual pull intake manifold pull injectors
Old 05-27-2013, 09:35 PM   #108
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Dont we need a special tool sst somethihg
Old 05-27-2013, 10:17 PM   #109
romin
romin's Avatar
Drives: BRZ, STI, 535, Tiffin Allegro
Originally Posted by whitefrs View Post
Does any one know how much a shop will charge to replace all 4 seals
Sent from my HTC One using Tapatalk 2
I was quoted $800 (labor only) by my local Subaru dealership.
I also called Scion and was quoted $750.
Given how long it's taking Subaru to acknowledge this issue and cover it under warranty I'm probably going to have my local mechanic replace all four seals.
romin is offline   Reply With Quote
Old 05-28-2013, 02:06 AM   #110
OrbitalEllipses
Drives: Attitude
Save the receipt and invoice for the work; you may eventually get it back from Subaru if they have a TSB or something.
Old 05-28-2013, 10:27 AM   #111
TemeCal
Drives: 86
@RAWR BRZ
I was the dark blue FR-S at SOW on Sunday. You had helped my buddy take his wheels to the tire shop. Anyway, I was hit by this issue on the drive home. CEL came on for about 3-5secs...then I soon noticed the firecracker popping noise. I can replicate it pretty easily at idle. I'm curious to see how long yours takes to get the warranty work done, because I don't want to leave my car at the dealership. Please keep me posted. Thanks!
TemeCal is offline   Reply With Quote
Old 05-28-2013, 02:15 PM   #112
RAWR BRZ
Originally Posted by TemeCal View Post
@RAWR BRZ
My CEL never turned on so it may also be another issue but I am not sure. I am taking it in around 12. I am sorry to hear you have the same issue. If you drive it granny style it shouldn't pop. I think every time it pops it damages the engine/remainder of the seal more. I will keep you posted.
The Following User Says Thank You to RAWR BRZ For This Useful Post:
TemeCal (05-28-2013)
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 04:26 PM
Need Help - 2 codes thrown jpit Issues | Warranty | Recalls / TSB 3 04-20-2013 12:41 AM
Bulb codes JDMenrique Cosmetic Modification (Interior/Exterior/Lighting) 1 02-17-2013 03:25 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 05:03 PM
