#113 |
Boosted Member
Drives: 2013 SWP BRZ Limited
so with the rear shock top, the car height will be 2 inches lower with any coils? Or is that only when I adjust the coil ride height, in that I get extra shock travel when the shock is dampening? Just seeing what the difference is if I get LCA's instead which gives like a inch drop without touching the coil overs height adjustment. Sorry for the noob question, never purchased a shock top before.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12 |
#114 | |
AutoX-10/10ths every run
| The Following User Says Thank You to whataboutbob For This Useful Post: | DAEMANO (01-26-2014) |
#115 |
Drives: WRB BRZ '13
is there going to be raceseng camber plate available for stock shock?
| The Following User Says Thank You to JDM-dono For This Useful Post: | DAEMANO (01-13-2014) |
#116 |
| The Following 4 Users Say Thank You to Raceseng For This Useful Post: |
#118 |
Ran my first autox event with these new parts, RCE T2s, and BFG R1-S. Car never pushed!
#119 |
| The Following 2 Users Say Thank You to Raceseng For This Useful Post: | Godzilla35 (03-01-2014), sc0urge (03-06-2014) |
#120 | |
Time Traveller
Thanks for all the hard work and great products. |
| The Following User Says Thank You to DAEMANO For This Useful Post: | Raceseng (02-04-2014) |
#121 |
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
bump for stock strut compatibility.
| The Following User Says Thank You to Ranatsu For This Useful Post: | Raceseng (02-04-2014) |
#122 |
The 90mm spring perch is done and works great... Except for the fact that the spring perch is much larger in diameter then our other spring perches. I need the change the t nut design to be flush with the bottom of the caster/camber plate to allow for the larger spring perch. The changes are made and will be introduced into our next production run of plates which is happening next week. Thanks for your patience!
#123 | |
Cone basher
#124 |
Absolutely! You can purchase a new spring perch or the other parts necessary to make the CasCam work with any coil over. I'm in the process of creating those product pages on the site now.
| The Following User Says Thank You to Raceseng For This Useful Post: | DAEMANO (02-27-2014) |
#125 |
Cone basher
#126 |
Drives: 2005 Toyota Camry
Cascam for Ohlins RT:
![]() ![]() ![]() ![]() ![]() Jarrett at @Raceseng decided to make these upper mounts without the spring perch. The Ohlins RT upper perch will be reused. Install pics to come once this rainstorm in LA passes. -alex |
| Tags |
| billet, billet aluminum, caster adjustment, caster camber plate, raceseng |
| Tein Flex Z Coilovers | Evasive Motorsports | Brakes, Suspension, Chassis | 54 | 07-16-2017 01:21 AM |
| Raceseng | Billet Aluminum Engine Pulleys | Raceseng | Engine, Exhaust, Transmission | 174 | 07-24-2014 12:24 AM |
| Raceseng | Lightweight Billet Aluminum Tow Hook | Raceseng | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 08-27-2013 01:48 PM |
| Question about adjustable LCA's vs Camber Plates vs Camber Bolts | djdnz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 03-27-2013 11:38 PM |
| SRP Billet Aluminum Door Sills | pedalpusher | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 09-20-2012 06:44 PM |
