Old 01-07-2014, 11:04 PM   #113
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
so with the rear shock top, the car height will be 2 inches lower with any coils? Or is that only when I adjust the coil ride height, in that I get extra shock travel when the shock is dampening? Just seeing what the difference is if I get LCA's instead which gives like a inch drop without touching the coil overs height adjustment. Sorry for the noob question, never purchased a shock top before.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 01-07-2014, 11:20 PM   #114
whataboutbob
AutoX-10/10ths every run
I think the benefit here is that you don't have to sag the piston into the stroke as far if you want to run a lowered ride height. I suspect that this will give you more potential damping capability.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
DAEMANO (01-26-2014)
Old 01-09-2014, 07:35 AM   #115
JDM-dono
JDM-dono's Avatar
Drives: WRB BRZ '13
is there going to be raceseng camber plate available for stock shock?
JDM-dono is offline   Reply With Quote
The Following User Says Thank You to JDM-dono For This Useful Post:
DAEMANO (01-13-2014)
Old 01-10-2014, 09:55 AM   #116
Raceseng
Raceseng's Avatar
Yes, the OEM spring perches just came off the machine. I'm fitting and testing them next week.
Raceseng is offline   Reply With Quote
The Following 4 Users Say Thank You to Raceseng For This Useful Post:
DAEMANO (01-13-2014), JDM-dono (01-13-2014), sw20kosh (04-29-2014), whataboutbob (01-10-2014)
Old 01-26-2014, 01:42 AM   #117
DAEMANO
Time Traveller
How goes the testing?
The Following User Says Thank You to DAEMANO For This Useful Post:
Ranatsu (01-26-2014)
Old 01-27-2014, 03:00 PM   #118
whataboutbob
Ran my first autox event with these new parts, RCE T2s, and BFG R1-S. Car never pushed!
Build thread:Here
The Following 3 Users Say Thank You to whataboutbob For This Useful Post:
DAEMANO (03-18-2014), normancw (01-27-2014), Raceseng (01-27-2014)
Old 01-28-2014, 12:04 PM   #119
Raceseng
Raceseng's Avatar
Sub -5 degree weather and constant snow falling in the northeast has caused an issue in our testing schedule... Time to move Raceseng to Cali!
The FR-S is HORRIFIC in the snow!
The Following 2 Users Say Thank You to Raceseng For This Useful Post:
Godzilla35 (03-01-2014), sc0urge (03-06-2014)
Old 01-28-2014, 01:33 PM   #120
DAEMANO
Time Traveller
All the free beer you can handle when you do. Btw, it's about 75 degrees in Orange County right now
Thanks for all the hard work and great products.
Raceseng (02-04-2014)
Old 02-03-2014, 05:29 PM   #121
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
bump for stock strut compatibility.
Ranatsu is offline   Reply With Quote
The Following User Says Thank You to Ranatsu For This Useful Post:
Old 02-04-2014, 05:42 PM   #122
Raceseng
Raceseng's Avatar
The 90mm spring perch is done and works great... Except for the fact that the spring perch is much larger in diameter then our other spring perches. I need the change the t nut design to be flush with the bottom of the caster/camber plate to allow for the larger spring perch. The changes are made and will be introduced into our next production run of plates which is happening next week. Thanks for your patience!
DAEMANO (02-04-2014), Turbo Den (02-04-2014)
Old 02-04-2014, 07:32 PM   #123
Ranatsu
Cone basher
Will there be a provision to change from stock style to aftermarket later? Or will we have to purchase a different set?
Old 02-05-2014, 10:21 AM   #124
Raceseng
Raceseng's Avatar
Absolutely! You can purchase a new spring perch or the other parts necessary to make the CasCam work with any coil over. I'm in the process of creating those product pages on the site now.
The Following User Says Thank You to Raceseng For This Useful Post:
DAEMANO (02-27-2014)
Old 02-05-2014, 10:35 AM   #125
Ranatsu
Cone basher
Very nice, well hurry up and get that stuff up so I can order :p
Old 02-27-2014, 12:56 AM   #126
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Cascam for Ohlins RT:
Jarrett at @Raceseng decided to make these upper mounts without the spring perch. The Ohlins RT upper perch will be reused.
Install pics to come once this rainstorm in LA passes.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
normancw (02-27-2014), Raceseng (02-27-2014)
billet, billet aluminum, caster adjustment, caster camber plate, raceseng
Tein Flex Z Coilovers Evasive Motorsports Brakes, Suspension, Chassis 54 07-16-2017 01:21 AM
Raceseng | Billet Aluminum Engine Pulleys Raceseng Engine, Exhaust, Transmission 174 07-24-2014 12:24 AM
Raceseng | Lightweight Billet Aluminum Tow Hook Raceseng Cosmetic Modification (Interior/Exterior/Lighting) 13 08-27-2013 01:48 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
SRP Billet Aluminum Door Sills pedalpusher Cosmetic Modification (Interior/Exterior/Lighting) 2 09-20-2012 06:44 PM
