Old 01-20-2014, 01:48 PM   #113
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
okay, i have made my first protype mount that puts a Go Pro in the center of the car at eye level
it is designed to fit into the cup-holder for easy installtion/removal
however, either due to my design or materials (which i will post later), it's just not stable enough.
i have begun testing another idea, but before i proceed, has anyone figured out a way to mount off the roof-line (inside the car) without any serious modification the liner?
Old 01-21-2014, 10:38 AM   #114
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
more questions! (and surprised why this thread doesn't get more hits)
i'm thinking of using a super adhessive to put a circular plastic plate on to the roof-liner in the middle of the car and swing the go-pro down using an e-bay suction cup with extra long arm
this puts the camera right along eye-level in the middle and i think will be sufficiently dampened for acceptable vibrations
i really don't feel like mounting the car on the windshield, so cliche
Old 01-28-2014, 10:08 PM   #115
karma003
auto-crosser/drifter
karma003's Avatar
Drives: 2013 scion FR-S black M/T
Originally Posted by Ranatsu View Post
I mean this with no disrespect, but you have horrible habits with your hands. You started fine and then it seems like you just let go.
Yea it's a bad habit I'm trying to get rid of. Mostly use my had on the center console to brace myself & to be ready to shift.
karma003 is offline   Reply With Quote
Old 02-18-2014, 12:22 PM   #116
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
Originally Posted by normancw View Post
@Scenic Driver
That looks great!
Did you use two Long Double Socket Arms (RAM-B-201U-C) with a Double Ball Adapter?
http://www.rammount.com/CatalogResul...7/Default.aspx
Or a single Long Double Socket Arm & Double Ball Adapter (RAM-B-201-201U-C)? I'm not
Thanks
It's a 3 inch arm and a 6 inch arm with a double ball adapter
Scenic Driver is offline   Reply With Quote
The Following User Says Thank You to Scenic Driver For This Useful Post:
normancw (02-18-2014)
Old 02-22-2014, 02:10 AM   #117
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
For the track, I suction-cup a GoPro just to the right of the rearview mirror. When it's necessary the video is reviewed after a session to see car placement, and then it's deleted. The system's data software will sync the session data with the video so you can see exactly what the driver and the car were doing at any point on the track. Just looking at the data is usually enough to review the session (e.g., minimum speed in T11, where the driver went to full throttle in T5, brake trace for T1 - whatever the driver is working on).
Occasionally I keep a video, use Dashware to merge the data with it, and then upload it to share with other drivers, students, or a coach. This is an example showing the driver inputs I want to see, as well as the line the car is following:
[ame="http://www.youtube.com/watch?v=skBtBia6b6g"]AP-2:04/3/2 - YouTube[/ame]
dradernh is offline   Reply With Quote
The Following User Says Thank You to dradernh For This Useful Post:
normancw (02-23-2014)
Old 04-24-2014, 12:50 PM   #118
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
I pretty much agree with the helmet cam being very distracting in general but I may have found a good compromise. Mounting it on the side of your helmet, towards the back, will give you a wider angle and so it's less busy. Let me know what you think.
Facebook video but you can watch this without a FB account.
https://www.facebook.com/photo.php?v...54543916499181
I haven't had good luck on the side of my race car with a direct tape mount and then a couple arms. It seems like when I hit 130+ mph it starts to get wavy.
Thanks,
Phil Grabow
Element Tuning is offline   Reply With Quote
Old 04-24-2014, 12:56 PM   #119
orthojoe
I actually like the helmet cams. You can see where the driver is looking and what he is doing with his hands.
[ame="http://www.youtube.com/watch?v=onaez6jCzNU"]1:41 lap time @ Laguna Seca with a Porsche Boxster Spyder - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=6PxFUqr9u3Y"]Skid pad practice at Thunderhill - YouTube[/ame]
2013 Subaru BRZ
orthojoe is offline   Reply With Quote
Old 04-24-2014, 01:13 PM   #120
Element Tuning
Yeah you ran the helmet cam where I did and I think it works well!
The Following User Says Thank You to Element Tuning For This Useful Post:
orthojoe (04-24-2014)
Old 04-24-2014, 01:39 PM   #121
wparsons
wparsons's Avatar
Here's some video I captured on my new GoPro with the same mount, using Harry's Lap Timer iOS app to start/stop recording and overlay data.
Settings:
  • 720p 60FPS
  • FOV set to Medium
  • Low Light set to On
  • Spot Metering set to Off
I probably should set Low Light to Off and Spot Metering set to ON (the video appears to be washed out).
Track is not really Calabogie, just a back road. If I was on the track, the green dot would be overlaid on a track map. Also, If I had a compatible Wi-Fi OBD2 reader, OBD2 data (throttle and RPM) would be displayed in the lower left corner.
The video capture, overlay, and upload is all done on the iPhone.
  1. Use Harry's Lap Timer to start/stop the GoPro.
  2. Use the GoPro app to save the video to the iPhone Photos.
  3. Select the lap in Harry's Lap Timer, link it to the video in the iPhone Photos album, and then click Overlay
  4. Use the YouTube Capture app to upload the video to YouTube (takes about 1 hours for the 6 minutes of video)
Brakes are squealing because they're not totally bedded in yet (will need to do that at the track). Needless upshifts/downshifts are for fun
Harry's Lap Timer app is pretty cool. By default it uses the phone's video camera, but can also control external cameras (GoPro and other iOS devices) for multi-camera support (i.e., picture in picture).
https://itunes.apple.com/ca/app/harr...363556704?mt=8
https://play.google.com/store/apps/d...ys.laptimerpro
http://www.gps-laptimer.de/Features.html
Looks like a neat app! What version do you have?
flickr
Old 04-24-2014, 02:25 PM   #122
normancw
normancw's Avatar
Drives: 128i
I got the Grand Prix version.
normancw is offline   Reply With Quote
Old 04-24-2014, 05:06 PM   #123
dradernh
Originally Posted by Element Tuning View Post
This has me thinking heated windscreen. I've had one for the last few years, and it's a total luxury to hit the switch five minutes before it's needed and never have the darned thing fog up in the first place.
Old 04-24-2014, 11:38 PM   #124
Element Tuning
Yeah that would be nice! Anti-fog works ok but we didn't treat the window since we really didn't think it would rain. LOL
Old 05-07-2014, 10:32 AM   #125
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Old 06-09-2014, 10:05 AM   #126
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
okay so I finally got some autocross footage from my custom built mount
the camera hangs in the middle of the car at head/eye level,
basically some trick suction cup usage and a cheap broom handle...
next version will probably be made from a wooden broom handle for added ridgidity
but so far I'm pretty satisfied... it focuses the perfect amount on the track while still giving you a view of the hand movements, vehicle speed, rpm and when I shift.
I have always found videos where 70% is the car's interior rather boring with little data for analysis, and pure windshield videos to give a false perspective on the action with again, no data on driver inputs etc.
[ame]http://youtu.be/ffKT6T7s-NY[/ame]
FS: Gopro HD Hero 2 kanundrum Audio/Visual, Electronics, Infotainment, NAV 6 12-18-2012 12:55 AM
GoPro Down - Shooting Videos and then.... FT-86 SpeedFactory Off-Topic Lounge [WARNING: NO POLITICS] 16 10-20-2012 11:04 AM
GoPro Pic.. _F-R-S_ FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 10-14-2012 05:27 PM
Radiator Mounting and Cap SupremeGunman Engine, Exhaust, Transmission 7 04-30-2012 05:16 PM
where are you mounting your plates??? poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 28 01-31-2012 04:41 AM
