Old 10-19-2013, 01:54 PM   #113
J3TBLUE
Drives: 2013 BRZ Limited Galaxy Blue Silica
Originally Posted by Zoti View Post
Need a bit of clarification as to how to wire the camera.
Do we want power to the camera at all times we have ACC power on?
I'm sure the unit has a connection to power a camera. Just need to find it.
I connected power to the camera as suggested by tapping into wire #3 on the 10 pin connector and ground on the other side.
I'm not sure which connections are video signal and video ground in this drawing:
OK. Never mind. Tthis page explains everything pretty well.
http://ae64.com/Rear-camera-16p-operation.htm
I don't know how to do the "Thanks" thing, but for posting that link!
J3TBLUE is offline   Reply With Quote
Old 10-19-2013, 02:25 PM   #114
Zoti
Drives: BRZ Limited 6MT
I found it here myself. Just passing on the info along with my experience.
I had to fabricate my own connector from old PC motherboard connectors but it worked.
Zoti is offline   Reply With Quote
Old 10-22-2013, 02:24 PM   #115
Respect BRZ
Old Mechanic
Drives: 2013 Limited BRZ
Mine works pretty much flawlessly with my nexus 4 on 4.3. What phone and issues are you having?
Droid razr maxx HD 4.1.2, it seems to have a mind of its own... sometimes if i don't time it right i have to shut off the car and start over to get it to connect, with my old iphone4 it was all automatic and worked every time...
Respect BRZ is offline   Reply With Quote
Old 10-22-2013, 03:31 PM   #116
mid_life_crisis
Drives: FR-S 10 #103 AT
That sucks. My Note2 works great.
Has anybody done one of these write-ups for the anniversary edition FR-S with the base head unit? The head unit is a little different, I think.
Old 11-20-2013, 03:23 PM   #117
SilverTipp
SilverTipp's Avatar
Drives: Silver
Originally Posted by Flat Black VW View Post
Close-up:
Is the trunk button still easily usable in this location? I would much rather have it centered like this ...
SilverTipp is offline   Reply With Quote
Old 11-20-2013, 03:35 PM   #118
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
I have a premium so there is no trunk button. If it were there the camera would block it.
Flat Black VW is offline   Reply With Quote
Old 12-04-2013, 03:52 PM   #119
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
so anyone solve the bypass issues?
Jive Turkey is offline   Reply With Quote
Old 12-17-2013, 12:43 AM   #120
deconzme
I was looking into this mod as well. Wam0nt to olay music videos while driving. But I dont want to cut the wire if it wont work. I have a late model year brz limited. Anyone figure our a fix yet?
deconzme is offline   Reply With Quote
Old 02-03-2014, 11:24 PM   #121
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Is it possible to disable the backup cam guide lines on the OEM HU? The camera I bought has them, so I have 2 sets of lines. I want to disable the radios lines. I went into diag mode but cant find anything regarding camera settings.
Old 02-04-2014, 08:12 AM   #122
Foobar
SLO NO MO
Foobar's Avatar
No known way to disable the stock lines.
Old 02-07-2014, 11:36 AM   #123
deconzme
pins
where can i find the pins that go in the connector? i see some of you ordered the add on, and others used pins from an extra connector you happened to have... does radio shack or something carry those pins to fit in the connector?
thanks in advance..
Old 02-07-2014, 11:20 PM   #124
deconzme
all I did is strip the two (RCA) wires longer, and shove them in the holes on the 16 pin connector, and everything works just fine. Guess I won't bother to do more. Thank you for your write-ups
Old 02-08-2014, 12:56 AM   #125
B-R-Z
B-R-Z's Avatar
Lol good luck with that
The Following User Says Thank You to B-R-Z For This Useful Post:
sure74 (02-10-2014)
Old 04-01-2014, 06:29 PM   #126
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
So after spending my day off of work at work working on my car I have completed a back up camera and the DVD/NAV/VIM bypass.
If anyone tries this, I am NOT responsible for you blowing up your radio or car, try this at your own risk.
I started with running the backup camera, and was happy to find this perfect grommet for the wire. I will be using this grommet for my passport 9500ci also when I install that.
@Flat Black VW
What size is Grommet? looks like perfect location for BRZ Premium people for rearview camera
DIY Nav unit in FRS with e-brake bypass and iPhone cable by cupholders Nitro DIY (Do-It-Yourself) Guides 42 07-02-2016 12:10 PM
Name that spoiler! (SOLVED) WingsofWar FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 12-06-2014 02:22 PM
BRZ NAV/DVD bypass Scooby South Electronics | Audio | NAV | Infotainment 88 02-24-2014 04:41 PM
how I solved my gilrfriend's problem with headrest angle alexmotrix Cosmetic Modification (Interior/Exterior/Lighting) 8 08-08-2012 09:00 AM
Drove the 86GT and NC miata back to back on GT5 Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 39 01-07-2012 01:56 PM
