Old 05-07-2013, 09:04 PM   #99
kuhlka
Drives: 2013 BRZ Limited AT
Originally Posted by 86•BRZ View Post
You're missing the point. The speed signal helps with GPS accuracy / driving through tunnels etc.. Just cut it if you're not bothered about accuracy.
The Pioneer AVIC-Z3 in my STi doesn't use a speedo sensor and it operates just fine. I bypassed the e-brake lockout on that unit as soon as i bought it.
No point missed here. I've read every thread I could find related to this topic and the switch sounds like a temporary hack until the real solution is uncovered (like the Canadian software hack).
That no one has checked the voltage of that circuit bothers me.
kuhlka is offline   Reply With Quote
Old 05-07-2013, 09:22 PM   #100
kuhlka
I did a bit more research and I assume the VSS connection is only there to calculate trip time. I may just go ahead and cut it tonight and see how the GPS handles it. If it only seems to affect trip time, that's no big deal because I ignore those totally inaccurate time readings in favor of distance, which the GPS antenna handles.
Old 05-08-2013, 12:36 AM   #101
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
the VSS signal will ultimately produce more a more accurate GPS position as your vehicle moves, this is especially handy when you are going through tunnels where GPS signal is lost, with the VSS working you will continue at the signalled speed along the road, some units take this further with a gyro steering angle sensor, my old BMW work work fine in undercover carparks for example even without a signal.
If you had read every thread you would know you can just cut it and use your GPS that way with less functionality. no point messing around with VSS signal voltages to create a fake signal as that wouldn't achieve anymore than just cutting the VSS wire.
just cut the wire and see how you go
86•BRZ is offline   Reply With Quote
Old 05-08-2013, 12:49 PM   #102
kuhlka
Reading back through, it looks like some versions of the software actually crap out if the VSS is cut. My software version is this.
Navi
15:50/30.07 9.2.2.250040
Audio
08,07,2012 Ver.44.1004
Does anyone know what the latest US software version is? I'm going to hold off on cutting my wire until I know more. I'll probably do the e-brake cable this weekend since that seems to be a good fix across the board. Page 319 of the wiring diagram (http://www.ft86club.com/files/BRZwiringi.pdf) shows it's just a switched ground connection.
Old 05-10-2013, 10:52 AM   #103
pjinmaui
pjinmaui's Avatar
Drives: '13 SUBARU BRZ LMTD '95 DEL SOL Si
Guys I ordered the Beat Sonic BCUS2 harness for adding the backup camera, going to attempt this install this weekend, will post pics and any problems/tips once I'm done! Thanks, Ryan
pjinmaui is offline   Reply With Quote
The Following User Says Thank You to pjinmaui For This Useful Post:
Jive Turkey (09-04-2013)
Old 09-03-2013, 09:45 AM   #104
Zoti
Drives: BRZ Limited 6MT
Results?
Zoti is offline   Reply With Quote
The Following User Says Thank You to Zoti For This Useful Post:
Old 09-04-2013, 03:32 PM   #105
Zoti
I did the parking break and vehicle speed sensor switch today. Unfortunately, the GPS knows I am moving and is disabling the options in motion.
Sucks.
Old 09-10-2013, 06:51 AM   #106
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
hi. i must not be getting this right..... i have to buy a 16pin harness or can i just buy the rca wire?
NYCsubaruBRZ is offline   Reply With Quote
Old 09-10-2013, 06:52 AM   #107
NYCsubaruBRZ
whats the cheapest harness? i have a hard time paying 20 bucks just to hook up a cam
Old 09-10-2013, 06:54 AM   #108
NYCsubaruBRZ
can you hook up multiple sources? i wanted to be able to view a 4channel dvr system as well (it has vga and a 4 pin video out)
Old 09-20-2013, 05:02 PM   #109
Zoti
Need a bit of clarification as to how to wire the camera.
Do we want power to the camera at all times we have ACC power on?
I'm sure the unit has a connection to power a camera. Just need to find it.
I connected power to the camera as suggested by tapping into wire #3 on the 10 pin connector and ground on the other side.
I'm not sure which connections are video signal and video ground in this drawing:
OK. Never mind. Tthis page explains everything pretty well.
http://ae64.com/Rear-camera-16p-operation.htm
Old 10-07-2013, 05:27 PM   #110
stugray
Drives: 2013 GBS BRZ Limited
Has anyone found how to upgrade the firmware on the Fujitsu FA601us head unit?
I am wondering if the latest firmware will solve my bluetooth problems.
Old 10-15-2013, 09:25 PM   #111
Respect BRZ
Old Mechanic
Drives: 2013 Limited BRZ
Any luck finding out if a new upfate will fix the bloody crappy bluetooth functionality with android phones?
Respect BRZ is offline   Reply With Quote
The Following User Says Thank You to Respect BRZ For This Useful Post:
Grymm86 (10-17-2013)
Old 10-16-2013, 03:30 AM   #112
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Mine works pretty much flawlessly with my nexus 4 on 4.3. What phone and issues are you having?
DIY Nav unit in FRS with e-brake bypass and iPhone cable by cupholders Nitro DIY (Do-It-Yourself) Guides 42 07-02-2016 11:10 AM
Name that spoiler! (SOLVED) WingsofWar FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 12-06-2014 01:22 PM
BRZ NAV/DVD bypass Scooby South Electronics | Audio | NAV | Infotainment 88 02-24-2014 03:41 PM
how I solved my gilrfriend's problem with headrest angle alexmotrix Cosmetic Modification (Interior/Exterior/Lighting) 8 08-08-2012 08:00 AM
Drove the 86GT and NC miata back to back on GT5 Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 39 01-07-2012 12:56 PM
