04-25-2017, 07:17 AM | #113 |
Drives: vrooom...
David Thanks, it looks Sweet! If you don't mind and you have a chance could you take a pic of the oil drain side. Also is that the standard setup for the fittings on the Oil Pan itself for the remote oil filter? Thanks again, I think this is the pan I want to go with and I hope it will not interfere with the sway bar.
04-25-2017, 07:45 AM | #114 | |
I Love custom Turbo kits
Drives: Limited BRZ
Yes those are the standard fittings.
The Following User Says Thank You to Sportsguy83 For This Useful Post: | M1K3 (04-25-2017) |
04-25-2017, 07:45 AM | #115 | |
Drives: Limited BRZ
I thought I had taken a picture of them.
The Following User Says Thank You to Sportsguy83 For This Useful Post: | Zer0 (04-25-2017) |
04-25-2017, 09:22 AM | #116 |
Drives: 2015 frs
I didn't see a picture of that part of the pan. Thanks for the info.
04-25-2017, 02:06 PM | #117 |
Drives: Limited BRZ
Yea I thought I had taken the picture but I didn't. Sorry good sir.
04-25-2017, 02:28 PM | #118 |
Drives: 2013 Ultramarine FR-S
Pan looks really good!
The Following User Says Thank You to DustinS For This Useful Post: | Sportsguy83 (04-25-2017) |
05-04-2017, 11:53 AM | #119 |
Drives: Limited BRZ
About time...
[ame]http://www.youtube.com/watch?v=XsEOsUuyk1E[/ame]
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post: |
05-04-2017, 11:55 AM | #120 | |
05-04-2017, 11:55 AM | #121 |
Drives: Limited BRZ
The Following User Says Thank You to Sportsguy83 For This Useful Post: | DustinS (05-04-2017) |
05-04-2017, 12:14 PM | #122 |
Drives: Limited BRZ
On the first picture you can peek at the Sikky Oil pan already installed.
On the second picture, One of the plug wires hits the header. Is it possible to remove the aluminum spark plug boot and that makes the spark plug cable to fit? Is the boot necessary for OEM cables but not needed for aftermarket cables? Any ideas @DustinS
05-04-2017, 12:19 PM | #123 | |
Drives: Limited BRZ
05-04-2017, 12:29 PM | #124 |
Are those factory spark cables?
The Following User Says Thank You to DustinS For This Useful Post: | Sportsguy83 (05-04-2017) |
05-04-2017, 12:43 PM | #125 |
Drives: Limited BRZ
Yes, the aluminum spark plug boot is what pushes the wire out. So I assume with the Holley EFI wires, I can ditch the aluminum boot (the Holley EFI cable itself is the boot over the spark plug). Thanks for your help always!
05-04-2017, 12:57 PM | #126 |
for shits and giggles, can you please mount the passanger side on the driver side and vice versa? I need pictures of both. I am thinking about doing these for the FRS but I'm also thinking about running them reversed for my turbo corvette.
Similar Threads | ||||
Sportsguy's LS2 Swapped BRZ | Sportsguy83 | Member's Car Journals | 2969 | 08-20-2018 11:12 AM |
FS: (Sold) Sportsguy ArmRest | kvnchu | Interior Parts (Incl. Lighting) | 22 | 03-13-2014 02:40 PM |
Sportsguy's AVO Turbo experience, the Good the Bad and the Ugly | Sportsguy83 | Forced Induction | 155 | 08-05-2013 06:17 PM |
Motegi 126 customs | kioton32 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 06-26-2013 12:34 AM |
FS: NY - Sportsguy Handcrafted Armrest | xxscaxx | Interior Parts (Incl. Lighting) | 43 | 05-04-2013 05:30 PM |
