Old 04-25-2017, 07:17 AM   #113
M1K3
M1K3's Avatar
Drives: vrooom...
Looks great. High quality!!
David Thanks, it looks Sweet! If you don't mind and you have a chance could you take a pic of the oil drain side. Also is that the standard setup for the fittings on the Oil Pan itself for the remote oil filter? Thanks again, I think this is the pan I want to go with and I hope it will not interfere with the sway bar.
M1K3 is offline   Reply With Quote
Old 04-25-2017, 07:45 AM   #114
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Supposedly CXRacing mounts and their pan does not interfere with sway bar, this pan should work too. I don't have it with me anymore as I left it yesterday at the mechanic.
Yes those are the standard fittings.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
M1K3 (04-25-2017)
Old 04-25-2017, 07:45 AM   #115
Sportsguy83
Drives: Limited BRZ
Originally Posted by Zer0 View Post
Does the pan have trap door setup in it to keep the oil around the pickup tube supplied under cornering G forces? It looks good.
Yes
I thought I had taken a picture of them.
Zer0 (04-25-2017)
Old 04-25-2017, 09:22 AM   #116
Zer0
Drives: 2015 frs
I didn't see a picture of that part of the pan. Thanks for the info.
Zer0 is offline   Reply With Quote
Old 04-25-2017, 02:06 PM   #117
Sportsguy83
Drives: Limited BRZ
Yea I thought I had taken the picture but I didn't. Sorry good sir.
Old 04-25-2017, 02:28 PM   #118
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Pan looks really good!
The Following User Says Thank You to DustinS For This Useful Post:
Sportsguy83 (04-25-2017)
Old 05-04-2017, 11:53 AM   #119
Sportsguy83
Drives: Limited BRZ
About time...
[ame]http://www.youtube.com/watch?v=XsEOsUuyk1E[/ame]
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
Draco_PR23 (05-04-2017), DustinS (05-04-2017), M1K3 (05-04-2017)
Old 05-04-2017, 11:55 AM   #120
DustinS
DustinS's Avatar
Just taking me to Youtube front page.
Old 05-04-2017, 11:55 AM   #121
Sportsguy83
Drives: Limited BRZ
Fixed
Old 05-04-2017, 12:14 PM   #122
Sportsguy83
Drives: Limited BRZ
On the first picture you can peek at the Sikky Oil pan already installed.
On the second picture,
One of the plug wires hits the header. Is it possible to remove the aluminum spark plug boot and that makes the spark plug cable to fit? Is the boot necessary for OEM cables but not needed for aftermarket cables? Any ideas @DustinS
Old 05-04-2017, 12:19 PM   #123
Sportsguy83
Drives: Limited BRZ
Originally Posted by all4spl View Post
I'm wondering if this is a better option
https://www.summitracing.com/parts/h...FUw2gQodjhkJ6w
You can either have 1 7/8 and 2.5" collector or 1 3/4 and 3" collector with possibly no fitment issues as we all know corvettes have little to no room.
I got the header you suggested and it allows more room to work around the steering column. Thanks for the suggestion!
all4spl (05-04-2017), DustinS (05-04-2017), FRSToyota86 (02-28-2018)
Old 05-04-2017, 12:29 PM   #124
DustinS
DustinS's Avatar
Are those factory spark cables?
Sportsguy83 (05-04-2017)
Old 05-04-2017, 12:43 PM   #125
Sportsguy83
Drives: Limited BRZ
Thumbs up
Yes, the aluminum spark plug boot is what pushes the wire out. So I assume with the Holley EFI wires, I can ditch the aluminum boot (the Holley EFI cable itself is the boot over the spark plug). Thanks for your help always!
Old 05-04-2017, 12:57 PM   #126
all4spl
for shits and giggles, can you please mount the passanger side on the driver side and vice versa? I need pictures of both. I am thinking about doing these for the FRS but I'm also thinking about running them reversed for my turbo corvette.
all4spl is offline   Reply With Quote
Sportsguy's LS2 Swapped BRZ Sportsguy83 Member's Car Journals 2969 08-20-2018 11:12 AM
FS: (Sold) Sportsguy ArmRest kvnchu Interior Parts (Incl. Lighting) 22 03-13-2014 02:40 PM
Sportsguy's AVO Turbo experience, the Good the Bad and the Ugly Sportsguy83 Forced Induction 155 08-05-2013 06:17 PM
Motegi 126 customs kioton32 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-26-2013 12:34 AM
FS: NY - Sportsguy Handcrafted Armrest xxscaxx Interior Parts (Incl. Lighting) 43 05-04-2013 05:30 PM
