Old 08-17-2013, 12:19 AM   #113
Do Boy
Turbo FR-S
Do Boy's Avatar
Send a message via ICQ to Do Boy Send a message via AIM to Do Boy Send a message via MSN to Do Boy Send a message via Yahoo to Do Boy
Originally Posted by grostoine View Post
Did you roll your fender ?
No, I didn't roll the fenders
Do Boy is offline   Reply With Quote
Old 08-17-2013, 12:20 AM   #114
Do Boy
Turbo FR-S
Do Boy's Avatar
Originally Posted by Figo View Post
Is it falt black?
Yes, it's flat black.
Old 09-07-2013, 09:32 PM   #115
ChandlerSwyng
ChandlerSwyng's Avatar
Drives: 2013 Red Subaru Brz
Thinking about getting these in white.. Is this setup safe with a 1 inch drop?
Old 11-14-2013, 04:30 AM   #116
86holic
Drives: 2014 lighting red 86
Top notch sir!
One quick question sir.
Are your cambers adjusted already?
And any wheel spacer added?
Because i would like to go for what you did.
Pro-kit means you used eibach lowering spring sir?
86holic is offline   Reply With Quote
Old 11-14-2013, 12:07 PM   #117
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by spiller View Post
Do those % take into account tyre stretch Jeff? If not id say the 35 would be just about spot on with stock since the 245 will stretch over the wider rim.
Stretching a tire does not change outside diameter. The 35 series in this case is the correct size to match the front tire.
Old 11-14-2013, 01:29 PM   #118
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
@Do Boy's topic has been merged with this one: same wheels with same specs
Old 10-22-2015, 10:35 PM   #119
newbrz
Drives: Limited Dark Gery Metallic BRZ
Originally Posted by Tylub View Post
+44 front +38 rears. you can get them from @WheelDude.com
no rub at all, if anything my rally armor scrapes just a little lol, which is why i didn't go the slammed route
I have the exact same setting except my front offset is at +38. Nevertheless my tires at the back are 265's. I am currently rubbing and have a drop of about 1 inch (maximum set height with KW's V3). How much did you lower your car? I finally need to change my tires and I want to make sure I won't have rubbing before I get the new ones.
Thank you!
newbrz is offline   Reply With Quote
Old 04-26-2019, 09:42 PM   #120
KingSpoon
Drives: 2014 BRZ limited Lightning red
Guess I'll necro this thread. Just got the same set of wheels today, but need some hubcentric rings. Anyone know the size I need?
KingSpoon is offline   Reply With Quote
Wheel Directory: Rota DPT 17x9.0 +42 Scooby South Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 90 06-16-2017 01:25 PM
OptionJDM- Rota Wheels OptionJDM Wheels and Tires 39 11-06-2012 01:14 AM
what are your thoughts on rota wheels? VenomRush Other Vehicles & General Automotive Discussions 46 11-24-2009 03:08 AM
