#1205 |
Orlando is where it's at when it comes to gas selection lol.
#1206 |
King of Kiwi Palace
Drives: Faster than you
Can add full blown to that
#1207 |
#1208 |
King of Kiwi Palace
Some guy on a corn diet made it for me
#1209 |
Those of you running a gtx series turbo. How are you pulling and returning coolant? Do I need additional fittings outside of the ones that feed the turbo? Links to relevant parts that will be needed would be greatly appreciated as well. Thanks
Sent from my SPH-L710 using Tapatalk |
#1210 |
Drives: 85 corolla gts
Ryan are you looking for spats to tap into the cooling system or are you looking for the required fittings to go to the turbo? Also let us know what fittings you currently are using so we can help with proper selection for the rest of the parts you will use so things match up properly, such as type of hose being used, as well as sizing being used.
#1211 |
NASA SpecE30 Racer
Shouldn't the FA20Club kit be coming with all the needed hoses and fittings along with instructions or are you adding a GTX turbo to the kit when you ordered it with a non water cooled turbo? I can tell you that I pulled the coolant from the flat coolant jacket that goes over the top of the block and returned the coolant to a vertical fitting on the back of the driver side of the block. I essentially used the coolant hose locations that would normally warm the throttle body to instead cool my turbo.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#1212 | |
Boosted
Drives: Not a supra....yet
Only thing that comes with this kit is a pile of sh** Sent from my IBrick
#1213 |
Ross I was supplied with banjo fittings for the turbos coolant supply/return. im lacking the necessary hardware into the cooling system. Im also lacking the knowledge of where and how to do so haha. My last install only required an oil feed.
#1214 |
The instructions I recieved were for oil only systems
#1215 |
NASA SpecE30 Racer
The instructions I just gave you are the best way to do it in my opinion without requiring a bunch of tees into the throttle body cooling hoses which is what the Full Blown kit comes with.
- King Tut
#1216 |
Thanks man I appreciate it
#1217 |
Kingtut is on the money on this, just below the throttle body there is a port and along the back side of the engine on the driver side there is a port. Both have hoses feeding to the throttle body. Are your banjo fittings to push lock or a/n hose?
#1218 |
push lock. Taking any suggestions on better hardware though, I will upgrade as needed haha.
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| FA20CLUB TURBO KIT T3/T4 60 | 86pro | Forced Induction | 50 | 07-26-2014 11:48 AM |
| Fa20club turbo install issues | Mikegraves777 | Forced Induction | 8 | 07-25-2013 12:56 AM |
| FA20CLUB 60 Trim Turbo 16 PSI Results Are In | FA20Club.com | Forced Induction | 148 | 07-22-2013 08:00 PM |
| FA20CLUB V2 Turbo Kit Progress | FA20Club.com | Forced Induction | 40 | 05-17-2013 01:26 PM |
