Old 02-02-2014, 10:00 PM   #1205
jamesm
Originally Posted by tg_1981 View Post
thanks again for the e-55...LOL i got back to orlando first station i hit brought the content up to 78!!!! I want to dyno the car again when we have a cold front in Florida. Making power in this heat ain't easy.
Orlando is where it's at when it comes to gas selection lol.
Old 02-02-2014, 10:00 PM   #1206
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Originally Posted by jamesm View Post
Fa20club, revworks, others I can't talk about lol.
Can add full blown to that
Ironsquid is offline   Reply With Quote
The Following 2 Users Say Thank You to Ironsquid For This Useful Post:
jamesm (02-02-2014), Sportsguy83 (02-02-2014)
Old 02-02-2014, 10:52 PM   #1207
tg_1981
That's a pretty sick pic on your avatar
tg_1981 is offline   Reply With Quote
The Following 2 Users Say Thank You to tg_1981 For This Useful Post:
Ironsquid (02-03-2014), jamesm (02-02-2014)
Old 02-02-2014, 11:12 PM   #1208
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Some guy on a corn diet made it for me
Old 02-05-2014, 01:37 PM   #1209
Ryan P
Those of you running a gtx series turbo. How are you pulling and returning coolant? Do I need additional fittings outside of the ones that feed the turbo? Links to relevant parts that will be needed would be greatly appreciated as well. Thanks
Sent from my SPH-L710 using Tapatalk
Ryan P is offline   Reply With Quote
Old 02-05-2014, 02:49 PM   #1210
Ross
Drives: 85 corolla gts
Ryan are you looking for spats to tap into the cooling system or are you looking for the required fittings to go to the turbo? Also let us know what fittings you currently are using so we can help with proper selection for the rest of the parts you will use so things match up properly, such as type of hose being used, as well as sizing being used.
Ross is offline   Reply With Quote
Old 02-05-2014, 03:14 PM   #1211
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Shouldn't the FA20Club kit be coming with all the needed hoses and fittings along with instructions or are you adding a GTX turbo to the kit when you ordered it with a non water cooled turbo? I can tell you that I pulled the coolant from the flat coolant jacket that goes over the top of the block and returned the coolant to a vertical fitting on the back of the driver side of the block. I essentially used the coolant hose locations that would normally warm the throttle body to instead cool my turbo.
Sportsguy83 (02-05-2014)
Old 02-05-2014, 03:16 PM   #1212
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Only thing that comes with this kit is a pile of sh**
Sent from my IBrick
The Following 2 Users Say Thank You to SmsAlSuwaidi For This Useful Post:
sid3way5 (02-07-2014), slowmo (02-16-2014)
Old 02-05-2014, 03:16 PM   #1213
Ryan P
Ross I was supplied with banjo fittings for the turbos coolant supply/return. im lacking the necessary hardware into the cooling system. Im also lacking the knowledge of where and how to do so haha. My last install only required an oil feed.
Old 02-05-2014, 03:17 PM   #1214
Ryan P
The instructions I recieved were for oil only systems
Old 02-05-2014, 03:19 PM   #1215
King Tut
NASA SpecE30 Racer
King Tut's Avatar
The instructions I just gave you are the best way to do it in my opinion without requiring a bunch of tees into the throttle body cooling hoses which is what the Full Blown kit comes with.
Ryan P (02-05-2014)
Old 02-05-2014, 03:19 PM   #1216
Ryan P
Thanks man I appreciate it
Old 02-05-2014, 03:23 PM   #1217
Ross
Kingtut is on the money on this, just below the throttle body there is a port and along the back side of the engine on the driver side there is a port. Both have hoses feeding to the throttle body. Are your banjo fittings to push lock or a/n hose?
The Following User Says Thank You to Ross For This Useful Post:
Ryan P (02-05-2014)
Old 02-05-2014, 03:25 PM   #1218
Ryan P
push lock. Taking any suggestions on better hardware though, I will upgrade as needed haha.
0-60 in 22million sec, beam, best of all, doyen done done it again!, fa20club header, fa20club.com, fa20crap, fa20crud.com, frs turbo kit, i like turbos, turbo frs, turbo kit, turbocharged brz, visconti 2.0?, welding4noobs, www.p&lclub.com, you'llneedamuletoride
FA20CLUB TURBO KIT T3/T4 60 86pro Forced Induction 50 07-26-2014 11:48 AM
Fa20club turbo install issues Mikegraves777 Forced Induction 8 07-25-2013 12:56 AM
FA20CLUB 60 Trim Turbo 16 PSI Results Are In FA20Club.com Forced Induction 148 07-22-2013 08:00 PM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 01:26 PM
