Old 04-17-2013, 01:30 AM   #1205
RavSpec
Drives: Rx7
Originally Posted by OmarGC View Post
I'm wondering if I'm going to need at least a 3mm spacer up front for the set I ordered from ya... Might end up buying some 5-10mm's for the rears, but kinda worried about maybe not clearing up front and having to scramble some up 3 days before an event.(when I hit us soil). If you ever get the chance to throw one up front in the sizing I ordered could you let me know how the clearance is? I'm sticking 245s up front aswell...
You should be good. Want me to test them ???
RavSpec is offline   Reply With Quote
Old 04-17-2013, 01:39 AM   #1206
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Would be awesome if you could! BTW have they shipped out already? Sorry, I'm lost on my days working 14 hr days mostly at night... 7 hrs ahead of est.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 04-17-2013, 10:04 AM   #1207
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by sweetfrs View Post
they are going to be strictly for autocross
Are you looking to run cheaters? (Extreme Performance Street, i.e. 140 treadwear or higher)
or a true R-compound slick tire? (V710, Hoosiers, Hankook Z214)
Heard great things about the new BFG for Streets, but someone currently competing in autocross can probably suggest better tire choices.
(been away from autocross for a while, I used to run RA1 and Victoracers in my time...)
Slick is offline   Reply With Quote
Old 04-17-2013, 12:17 PM   #1208
t00n3wb
t00n3wb's Avatar
Drives: 2013 Hot Lava Scion FR-S
Would this square set up fit nicely on eibach sport line springs? And what off set should be good?
18x9 Front and Rear.
t00n3wb is offline   Reply With Quote
Old 04-17-2013, 01:01 PM   #1209
sweetfrs
sweetfrs's Avatar
Drives: 2013 FRS
Im not even sure probably cheaters, definetly not slicks lol
sweetfrs is offline   Reply With Quote
Old 04-17-2013, 01:26 PM   #1210
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Need offset
ill86 is offline   Reply With Quote
Old 04-21-2013, 06:41 PM   #1211
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
I got 18x9.5 +45 and coilovers, Will I be fine running 255/35/18 square ?
adprokid is offline   Reply With Quote
Old 04-23-2013, 08:12 AM   #1212
vinnie86gt
Drives: Pearl White 86 GTS
How would 18x8 +30 go all round? This would be on stock suspension and eventually lowered with the eibach 1" drop springs
Thanks guys
vinnie86gt is offline   Reply With Quote
Old 04-23-2013, 08:33 AM   #1213
white_knight
white_knight's Avatar
Drives: 2013 86 GTS - Pegasus White
Thanks guys
No problems with that setup. The rears will be tucked a bit.
white_knight is offline   Reply With Quote
Old 04-23-2013, 08:40 AM   #1214
vinnie86gt
Thanks for that..
Ye i thought so but CST Hyper Zeros only come in 18x8 for 5x100pcd
I could put a 5mm spacer on the rear i guess.
The fronts shouldn't poke at all ye?
again thank you
Old 04-23-2013, 09:08 AM   #1215
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Thanks for that..
again thank you
Front should be about flush.
Killerbee is offline   Reply With Quote
Old 04-24-2013, 07:58 PM   #1216
GTS86
GTS86's Avatar
Drives: Black GTS86 Aero
Hi guys,
I'm looking at a set of 19x8 with an Offset/ET: - 50
It appears the rims have a negative offset, does that sound right? It seems like an extreme amount of negative offset. I'm guessing they won't fit an FRS/BRZ/86?
Would I be able to flush them to the fender with some spacers?
Thanks guys!!
GTS86 is offline   Reply With Quote
Old 04-24-2013, 10:05 PM   #1217
Slick
Slick's Avatar
Originally Posted by GTS86 View Post
Hi guys,
Thanks guys!!
They must be positive offset. But even a +50 will probably hit the struts on an 8" wide rim.
Spacers will help, but not ideal. Just look at getting correct offset wheels. On an 8 inch wheel, ideal offset would be +40 +\- 5mm in either direction.
Old 04-24-2013, 10:08 PM   #1218
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Spacers would make that MORE negative. Only way to add offset (+) would be machining off some of the wheel's hub surface (if it can be done on that wheel) or I think if it's a 3pc wheel, you can swap the rims around and change the offset, but I've never dealt with those wheels and can't say for sure.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
