Old 06-26-2019, 12:30 PM   #1205
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Looks like I may jump on the destroker train. As long as I can just hone my block (If not I will sleeve it and go 4.125" bore).
3.267" 4.8ltr Crank
High Compression JE Pistons 1.304 Compression Height
Lunati 6.300" Rods
King Coated Main/Rod Bearings
ARP Head/Main Studs
Comp Cams Shaft Mount Rockers
Either BTR .685" Dual Valve Spring Kit or PAC .700" Dual Valve Spring kit
BTR Custom Cam
BTR Pushrods
Johnson Short Travel-Slow Leak Down Link Bar Lifters / or Morel MM5276/MM5294 (Though they are not to be used with oil weight over 5w/40)
Cometic Head Gasket Set
Will also need to change up my Crank Scraper/Windage Tray I just bought -_-
Doing research on cutting the LS journals down to 2.00" from 2.1". I can then use a Callies 6.44" Rod (Part# CSC6440CS2A2AH) and JE 1.165" CH Piston (Part# 324016). This would help cut weight from the Piston and help with RPM. I can also order the piston further lightened if I wish.
Possible Rod bearing: King CR803XPNC
DustinS is offline   Reply With Quote
Old 06-26-2019, 01:25 PM   #1206
all4spl
3.267" 4.8ltr Crank
Lunati 6.300" Rods
ARP Head/Main Studs
BTR Custom Cam
BTR Pushrods
Are you setup with anyone for these parts? I'm a dealer and can help you out if you'd like.
all4spl is offline   Reply With Quote
Old 07-01-2019, 12:18 PM   #1207
DustinS
DustinS's Avatar
Yes, but if there is anything he doesn't have access to, I'll hit you up and see what you can do! Thanks for the offer!
Picking up a 4.8 bottom end with a broken piston for $100 tonight. Hopefully I can machine the block and sell it and possibly the other pistons/rods if they are okay to make up some money.
I may be paranoid, but engine vibrations and a more serious lifter noise has popped up within the last couple days. I am hoping it's in my head though
Old 07-03-2019, 12:29 PM   #1208
DustinS
DustinS's Avatar
I will need to get the crank out, but it looks decent. No discoloration or any other bad signs, other than the broken pistons and bad cylinder walls. Those I already knew about. Should be able to be bored out to fit 5.7 pistons and sell off.
I have been doing more research. Mostly on compression ratio using off the shelf parts.
Going off the assumption my cylinder head cc is 64cc, deck clearance is factory 9.4", and using a .040 compressed gasket. (all those will be double checked)
The 6.3" Rod with JE 9.7cc Dome piston (CH 1.304") = 12:1 CR - 1.92 Rod Ratio
The 6.44" Rod with JE 7.1cc Dome piston (CH 1.165") = 11.6:1 CR - 1.97 Rod Ratio
Currently trying to figure out which would be more beneficial. Of course I also have to throw in that I may end up toss on some turbos in the future if I don't quite get the results I am after.
The Following User Says Thank You to DustinS For This Useful Post:
zeal86 (07-05-2019)
Old 07-05-2019, 04:59 PM   #1209
DustinS
DustinS's Avatar
After thinking it over, Think I have decided to go with the 9.7cc piston configuration, mostly for the extra compression, and less work required with the crank.
Currently have a cam being spec'd by BTR, just waiting to hear back. Also talking with Comp Cams about their conical valve springs. Not a lot of info on them, but seem to get a great ticket for a build like this.
Basic Parts list for now, subject to major change.
The Following 2 Users Say Thank You to DustinS For This Useful Post:
zeal86 (07-05-2019), Zer0 (07-06-2019)
Old 07-09-2019, 04:04 PM   #1210
DustinS
DustinS's Avatar
If I decide to stay 418ci (still can't make up my mind).
Low 13:1 or High 12.X:1 compression depending on head milling and gasket thickness.
Lightweight Rotating assembly
Old 07-11-2019, 10:27 AM   #1211
DustinS
DustinS's Avatar
Started working on the A/C after an oil change last night. Messed up and double ordered a set of fitting yesterday because I forgot I had already ordered them, and they wouldn't let me cancel the order. So on top of having to send them back, I also had to order the correct fittings. The fittings I did buy weren't actually for my compressor.
I also found that the factory condenser is the same size and fits better than the aftermarket one I bought. Also allows me to use factory fittings, which is good because I was going to need to have custom fittings made. On to pictures
Using Factory hardline up the passenger frame rail. Going to have to extend the wiring, best done when engine is out getting rebuilt Going to get a hose end welded on. All of the lines will get some kind of heat protection around the manifolds.
Using the FRS Compressor fitting on the compressor as well. Fits a lot better than the universal kit parts. It also seals correctly. Will need modified slightly with a new hose end welded on shorter, same for the condenser side of the #8 line.
Not a ton of room, especially out back.
Probably going to end up having extra fitting welded on so the hose isn't so kinked. I need to do a little filing on the back of the head to make sure it doesn't puncture the line.
Oh and on the oil change. Just as much metal as last time, only 550 miles on this oil. Have a sample to send to blackstone to see what they say. I am betting its cylinder walls and I am screwed. Maybe I get lucky and it's just the rings?
Old 07-11-2019, 07:07 PM   #1212
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
Why not...
3.267" 4.8ltr Crank
Lunati 6.300" Rods
ARP Head/Main Studs
BTR Custom Cam
BTR Pushrods
as I was considering different options, I considered taking a 6.0l block and throwing 4.8 rods and crank in it. End up with a high revving 5.3.
Jaden
Jaden is offline   Reply With Quote
Old 07-12-2019, 11:33 AM   #1213
Cookiemonster
Cookiemonster's Avatar
Drives: '17 BRZ M6 & '17 Corvette Z06 M7
Sucks about the metal in the oil...best of luck to you
Cookiemonster is offline   Reply With Quote
The Following User Says Thank You to Cookiemonster For This Useful Post:
DustinS (07-12-2019)
Old 07-17-2019, 11:29 AM   #1214
DustinS
DustinS's Avatar
Playing with ideas in my head and I think I figured out the T56 to K series issue. Quicktime sells a M52 to T56 Magnum bellhousing. The M52 had the ZF transmission (if I am seeing it correctly). K Miata sells an adapter plate to mate the ZF to the K series.
SO I should be able to purchase the bellhousing AND adapter plate and mount the T56 to the K series. Would need a custom clutch disk for the GM 26 spline input shaft on the transmission, but that is as easy as a call pretty sure.
Old 07-17-2019, 12:16 PM   #1215
jflogerzi
jflogerzi's Avatar
So your heading down the k-swap motor? NA or boosted? Either way I am excited to see the final product when ever it's done.
2013 Series 10 FRS #553
Old 07-17-2019, 12:35 PM   #1216
DustinS
DustinS's Avatar
Would be turbo for sure.
Still undecided though. Waiting to hear back on oil sample I sent out. I have a feeling the block is toast. Hoping it's just the cam/lifters haha
I did realize the clutch would be a bigger issue. The Adapter kit comes with a custom flywheel and I wouldn't be able to use a twin disk setup as I planned. So that would still needs to be figured out.
jflogerzi (07-18-2019)
Old 07-18-2019, 01:09 PM   #1217
gtpvette
Drives: 2015 FRS - FFR GTM
Where did you find that block/adapter you have mounted to the expansion valve on the firewall????
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
Old 07-18-2019, 01:42 PM   #1218
DustinS
DustinS's Avatar
AMG Fuel Design on Instagram.
I believe there will be another option on the market in a bit as well, but because of how I set mine up, it didn't sound like It would work for me.
For future reference, If anyone gets the CTS-V accessory drive with A/C. These are the compressor fittings needed:
Part #AA1277-AA1278 from Cold Hose
gtpvette (07-18-2019)
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 04:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-22-2015 12:38 AM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 12:14 PM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 08:32 PM
