Old 06-17-2019, 07:32 PM   #1191
Zer0
Drives: 2015 frs
Good luck Dustin. You deserve this to be a good reliable car with all of the effort you put into it. Sad to see you getting engines with issues the rest of the car is so nice. Hopefully you get this resolved.
Zer0 is offline   Reply With Quote
The Following User Says Thank You to Zer0 For This Useful Post:
DustinS (06-18-2019)
Old 06-18-2019, 11:20 AM   #1192
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Originally Posted by DustinS View Post
Yes, and I haven't heard back on that just yet, but I am 99% sure they are only going to offer to fix it on my dime, or maybe a slight discount on getting it fixed?
At this point, I really just want a new engine or partial refund. This one obviously has issues, but I am not holding my breath. With as much money and time I have spent working on this engine, I don't feel it's worth continuing with TSP products. Especially with @ILLSMOQ having similar issues and finding the heads cracked with only 2500? miles on the car.
1500 miles lol. The engine builder said those cracks were common and superficial on the PRC heads though.
ILLSMOQ is offline   Reply With Quote
The Following User Says Thank You to ILLSMOQ For This Useful Post:
Old 06-21-2019, 03:46 PM   #1193
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Left to Right - Front to Back
Passenger Side:
Driver Side:
Lots of buildup
Scoring on cylinder wall. I only checked the first two cylinders on the drivers side, but both had them.
DustinS is offline   Reply With Quote
Old 06-21-2019, 04:05 PM   #1194
Lantanafrs2
Drives: 2013 frs red
Dude, you need a new motor. These fucking rebuild shops are an expensive crap shoot. God bless what comes in a crate.
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
DustinS (06-21-2019)
Old 06-21-2019, 04:38 PM   #1195
Lantanafrs2
You've put so much into this, you deserve a reliable driver.
Old 06-25-2019, 12:53 PM   #1196
DustinS
DustinS's Avatar
Found a company offering a 2JZ to FRS harness for the ECU Masters EMU Black. Interested in how well the canbus works.
I am still weighing the options of staying LS and rebuilding it, or switching to K20 or 2JZ. I like the idea of 2J sounding great with good power, and being able to use my current transmission easily. I just don't like how heavy and large it is. It's also considerably more expensive to build over the K20.
K20 is small and light, but I am worried the power I am looking for will make it lazy. I know there are way around this, but something I really enjoy about the LS is how easy it is to drive.
I will need to get custom bellhousing and clutch setup, but I think quicktime should be able to handle the bellhousing. Plan is to call them here in a bit on lunch.
Old 06-25-2019, 01:40 PM   #1197
vladniko86
vladniko86's Avatar
Drives: FRS
Can you DM me their contact info?
vladniko86 is offline   Reply With Quote
Old 06-25-2019, 03:28 PM   #1198
DustinS
DustinS's Avatar
Found they don't actually sell it. Website doesn't actually work, it's just up while they work on a few things.
Old 06-25-2019, 03:36 PM   #1199
wutsaiu
wutsaiu's Avatar
Drives: 2015 Raven V8
Just stay LS, changing now would cost more than fixing it. I spun a bearing on my 6.2 LS; took it out, flipped it upside down without taking the heads off, new crank and bearings and threw it back in the car. Been working for two years now including track days. I know your issue is totally different but my point is just replace what's broken and push forward. I must comment I'm only using GM parts though, no aftermarket stuff. Don't give up on LS, maybe just give up on certain companies.
wutsaiu is offline   Reply With Quote
Old 06-25-2019, 03:48 PM   #1200
DustinS
DustinS's Avatar
Just looking at all options. It will be expensive, but at this point it may be expensive to stay LS as well.
If the scoring is as bad as it looks, block is toast (won't know until I get it apart). Pistons were extremely worn last time the engine was apart, so I can't imagine what they look like now the second time around. Then add in rods and crank to get rid of the TSP products that will sell for next to nothing because they are used.
I also like the idea of gaining space and losing weight, especially the heavy convoluted dual 3" exhaust that doesn't really fit under the FRS. Getting rid of drone is going to be an expensive quest as well. Speaking of which, if I stay LS I am going to buy the Corsa Extreme Camaro Axle Back. Seems it will cut the drone, and should sound decent with my current muffler in the center.
Old 06-25-2019, 03:53 PM   #1201
vijay.dy06
Drives: Red BRZ
Just get a cammed 6.0 LS2, 3in y pipe with a cutout to stock mid pipe back. No drone but can open it up to flow freely on command, and you'll have ground clearance for the exhaust. You have all the supporting mods already for an LS. Just seems counter intuitive and more expensive to start over. Just my 2 cents though.
Sent from my SM-G950U using Tapatalk
vijay.dy06 is offline   Reply With Quote
Old 06-25-2019, 04:11 PM   #1202
DustinS
DustinS's Avatar
No sense in going backwards. 500whp or it's not worth it.
Old 06-25-2019, 04:31 PM   #1203
Swift
I just Drive.
Swift's Avatar
Drives: in the womb still
Well if anyone knows how to google search properly I don't think TSP is going to get much work after this....
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project
Swift is offline   Reply With Quote
Old 06-25-2019, 05:10 PM   #1204
kurty85
Drives: 2014 FRS LS Swap
I would get a used ls3 oem, nice heads, cam, and call it a day. Just an example My LS2 402 made 507rwhp/491 rwtq all day long without breaking a sweat. 400 lb ft of tq from 2500 rpm up to 6800. This would give you exactly what you are looking for. I had mediocre heads too. Dart pro1's. Cam was an LG G6X3. Kooks 1 7/8 headers.
Sent from my SM-G950F using Tapatalk
kurty85 is offline   Reply With Quote
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 04:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-22-2015 12:38 AM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 12:14 PM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 08:32 PM
