Old 04-11-2013, 11:48 AM   #1163
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
Originally Posted by Slick View Post
That tire is a whole inch taller in diameter than OEM.
So you will lose acceleration due to higher gearing from the tires.
And your actual speed will be 4.3% higher than what is indicated.
Depending on the weight of the wheel/tire combo you may lose additional acceleration from the extra weight. Always keep this in mind when running a plus-size set.
The wheel weighs 18.34 lbs if i get a good deal on the wheels and the guy will ship i guess i should just buy new tires
Lee358 is offline   Reply With Quote
Old 04-11-2013, 11:51 AM   #1164
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Wheel weight is pretty good for an 18" wheel. Good luck!
Slick is offline   Reply With Quote
Old 04-11-2013, 11:55 AM   #1165
Lee358
Lee358's Avatar
Thanks for your help!
Old 04-11-2013, 06:01 PM   #1166
Readytoxplod
Tire Destroyer
Drives: Firestorm+snail
Continental Extreme Contact DW in a 245/35R18 isn't too wide for an 18x8 wheel? How are the Hankook v12 evo 245/35?
Also I have +45 offset and have a 1.4 inch drop with springs. Will I need camber bolts? what about camber plates? Thanks
322whp/273wtq
Readytoxplod is offline   Reply With Quote
Old 04-11-2013, 06:57 PM   #1167
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
you can do 245s on a 17x8. +45 offset is nice and conservative.
I haven't gone lowered yet, but I got about 1.4 degrees with camber bolts.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 04-11-2013, 07:04 PM   #1168
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
An 8" wheel can fit a 245mm without issue.
ill86 is offline   Reply With Quote
Old 04-11-2013, 08:17 PM   #1169
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Will these work
They are 18x9.5 with a +35 offset (all 4 wheels).
The tires are 245x35x18
Old 04-12-2013, 12:36 AM   #1170
ill86
ill86's Avatar
Drives: iG FR-S
Originally Posted by whitefrs View Post
Will these work
Front,
Outside the fender by approx 15-20mm. Could be corrected with aggressive camber. But..
Very close to suspension on inside.
Rear, OK, some poke.
Grab a calculator and do some easy measuring. Or look back through this thread... Lots of info.
Old 04-12-2013, 07:04 AM   #1171
white_knight
white_knight's Avatar
Drives: 2013 86 GTS - Pegasus White
Loving this thread!
I just purchased a staggered set of 57Xtremes:
F: 18x8.5 +33
R: 18x9.5 +40
Just shopping around for the ideal tyres -- can you please confirm if 225/40/18 (front) and 255/35/18 (rear) will be the best?
I have the Eibach Pro Kit installed.
I understand this particular set up was designed specifically for the 86 -- can you confirm if this means it will be a flush setup?
white_knight is offline   Reply With Quote
Old 04-12-2013, 07:55 AM   #1172
ill86
ill86's Avatar
Drives: iG FR-S
Originally Posted by white_knight View Post
Loving this thread!
F: 18x8.5 +33
R: 18x9.5 +40
A little more than flush. Tire selection is your choice. But what you have listed is fine.
Old 04-12-2013, 09:19 AM   #1173
white_knight
I'm guessing you mean a perfect fit???
Old 04-12-2013, 11:11 AM   #1174
fred864
Drives: brz/fr-s
Need your help on this one!
Rays gram ligths 57xtreme wheels.
I currently have a stock BRZ on the suspension side, so it is not lowered.
I want to have a square set of 18x9.5 all around.
Just wondering I was thinking on having 255/35/18 tires (michelin super sport).
Will this fit? Any issues of rubbing in the rear or front with this kind of set?
thanks
fred864 is offline   Reply With Quote
Old 04-12-2013, 11:19 AM   #1175
Slick
Slick's Avatar
thanks
Need wheel offset.
You can fit 255's in front depending on the offset (edit: and tire brand) but still very tight, and 9.5" wheel is very aggressive for the front, no issues in the rear though.
With a stock suspension setup, you will either poke out or rub against the strut on the inside depending on the offset. Not an ideal fitment either way.
Old 04-12-2013, 11:48 AM   #1176
Slick
Slick's Avatar
example for reference:
This is my 18x9 +35 wheel on stock suspension (compressed to ride height).
On the inside, there is 12mm between the edge of the wheel to the strut. With a crash bolt installed, this reduces to about 9-10mm. Add the tire and the sidewall will be closer yet.
Also note how much the wheel sticks out of the fender.
With crash bolt and ProKit springs, was able to gain just enough camber to pull the top of the wheel in just enough (last pic).
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
