Old 05-16-2019, 09:46 AM   #1163
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Trying to Kill the drone at 2000 rpm. Should help quite a bit. Just going to have to get creative with a brace for the end to make sure I don't break the welds or anything.
This way, or possibly one right behind the other one:
DustinS is offline   Reply With Quote
Old 05-17-2019, 01:55 PM   #1164
DustinS
DustinS's Avatar
More partial projects:
A/C Condenser acquired. It has an odd twist to it that I may try fixing, but besides that everything looks decent. I just need to figure out the mounting and get some lines made. I also need to figure out wiring. Seems Colin no longer works for MRS, which is probably the reason I haven't seen anything from him in a while; but that also means there probably isn't any hope of product updates. Can't even find them on their website any more.
Old 05-17-2019, 02:10 PM   #1165
gtpvette
Drives: 2015 FRS - FFR GTM
Saw a thread earlier this week that implied this. This isn't good. What are you thinking about for wiring???
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
Old 05-17-2019, 02:27 PM   #1166
DustinS
DustinS's Avatar
Going to see if the MRS device allows A/C to work, but I need to move the pressure switch from passenger side to the drivers side. Hopefully that works.
If the MRS device doesn't work with A/C I am going to have to look into switching canbus/going standalone
Old 05-17-2019, 04:40 PM   #1167
toast
Drives: 14 BSP Edelbrock BRZ
What happened to your hood vents?
toast is offline   Reply With Quote
Old 05-17-2019, 04:45 PM   #1168
DustinS
DustinS's Avatar
Printed in PLA as a test print. Has a very low tolerance for heat/uv light. I have PETG which will withstand the heat and UV much better. I just need to get them printed.
The Following User Says Thank You to DustinS For This Useful Post:
zeal86 (05-17-2019)
Old 05-17-2019, 04:48 PM   #1169
Zer0
Drives: 2015 frs
Swap time makes a canbus module for gm swaps. You may look into contacting Mitch he is the one who made my harness. Gerald also may have a solution for you he is on this forum.
Zer0 is offline   Reply With Quote
Old 05-17-2019, 09:22 PM   #1170
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
I would still reach out to Colin, quietly, on the side.
I see him about once every other week or so at car meetups.
spitsnaugle is offline   Reply With Quote
Old 05-24-2019, 02:09 PM   #1171
DustinS
DustinS's Avatar
Fitting and hose came in, I will need a few more fittings, mainly ones for the factory pressure switch, and with fill ports.
Also need the fittings for the condenser:
Old 05-24-2019, 02:38 PM   #1172
vijay.dy06
Drives: Red BRZ
Where and how much did you get those fittings and hoses for? Does it require a specific tool to crimp the ends or are you taking them to a shop to get crimped?
Sent from my SM-G950U using Tapatalk
vijay.dy06 is offline   Reply With Quote
Old 05-24-2019, 02:47 PM   #1173
DustinS
DustinS's Avatar
$70 from ebay. and I will take it to a shop to get crimped. Though I don't think the crimp tools are too crazy to buy from amazon or ebay.
Old 05-24-2019, 02:49 PM   #1174
vijay.dy06
Drives: Red BRZ
Specific to any certain vehicles or just custom?
Old 05-24-2019, 02:50 PM   #1175
DustinS
DustinS's Avatar
A/C Fittings
Old 05-24-2019, 02:54 PM   #1176
vijay.dy06
Drives: Red BRZ
Awesome. Thanks. Give us updates. I might end up using the same kit.
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) -- General Topics 13 03-22-2016 03:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-21-2015 11:38 PM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 11:14 AM
Should I swap? michaelahess BRZ First-Gen (2012+) -- General Topics 8 06-12-2012 07:32 PM
