Old 06-28-2017, 09:35 PM   #1149
illmatic_frs
illmatic_frs's Avatar
Drives: n/a
So this happened...
ESC stopped working. Internal voltmeter frozen at 28.7v. Tested dump batteries and they are fine. Connection between the two is OK (Running 3 PC680's).
Controller fan and aux unit fans go on, however the beeps weren't audible on startup.
So I looked at the connections from the controller to the turbine noticed the black and blue wires were singed and fused at the connection point. The electrical tape was melted. Managed to get them apart and they are blackened... See pics. The red connector is ok.
Anyone seen this before? Any idea of what could have caused this? What's the remedy?
Thanks.
Sent from my ZTE A2017U using Tapatalk
illmatic_frs is offline   Reply With Quote
Old 06-28-2017, 10:52 PM   #1150
Ultramaroon
not playing cards
Ultramaroon's Avatar
Moisture intrusion and a little bit of corrosion made the connection resistive.
Then dumping tons of current through it heated it.
No biggie. I'm guessing you'll just have to replace the connector.
Old 06-29-2017, 03:16 AM   #1151
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
that sounds likely, but I thought the connectors were gold plated to keep them from corroding. My first thought was maybe they were rubbing together from engine vibration and it wore the insulation enough to start arcing.
Old 06-29-2017, 05:00 AM   #1152
TM
TM's Avatar
Drives: DGM BRZ 6MT
Originally Posted by Carsnguitars View Post
I have PM'd Rob. Haven't heard back
Email and get a response within a day.
TM is offline   Reply With Quote
Old 07-03-2017, 07:29 PM   #1153
silent runner
Drives: 93'Camry, 82'Corolla, 76' Celica
I see you managed to fix this up on the other phantom thread. I did as well with a similar connection issue, after 3 years of use. This is still too much fun! ( even with my old fashioned unit on a 3.0l engine .
silent runner is offline   Reply With Quote
Old 09-27-2017, 06:59 PM   #1154
BuffDriver
Drives: 2016 Subaru BRZ
In the market for new set of Odyssey 680mj's batterys so I can get my new(used) Phantom kit up and running. I have a source locally which seems fairly cheap but wanted to know if any of you had some place that was really cheap (including shipping) before I order to compare.
There's Battery Mart and...?
Edelbrock SC kit w/ ECUtek tune, Oil Cooler, UEL catted header, Perrin 2.5 Overpipe n Catted midpipe, 3.0 Catback resonated (all exhst ceramic coated), TRD short shifter, MTEC clutch n trans springs, Trans: Pentosin MTF2, Diff: Motul 75W90, Whiteline trans bushing, 3/4" clutch slave cyl., Ferodo DS2500 pads w/Motul 600 fluid, 17x8 wheels n 235/45ZR-17 tires
BuffDriver is offline   Reply With Quote
Old 11-04-2017, 05:12 PM   #1155
vfrqqq
Ultra Senior Member
vfrqqq's Avatar
Drives: 2014 BRZ Premium, WRB
What sort of lifespan have owners been seeing with the Magna Power ETX16L batteries as the dump batteries. I'm having some activation issues with my ESC and am wondering if my two-year old batteries are the first thing to look at. The system is not giving me full boost, only about 2.4 psi max and the voltage meter is dropping to 18 to 17 V under activation, momentarily drops to 0.00 V and the boost is gone, and then reads 26 to 27 V with the throttle pedal still wide open. I have PM'd Rob and am waiting for a response, but was wondering if others have had this issue as well.
Here is a data log I took today
https://datazap.me/u/vfrqqq/log-1509...log=0&data=1-9
This was a WOT pull.
Also, just measured the voltage on my ETX16L dump batteries. 12.6 V and 13.05 V on each. Not sure if that is "low" though. Shouldn't they nominally be around 13.5 V to 14 V?
vfrqqq is offline   Reply With Quote
Old 11-04-2017, 08:12 PM   #1156
DAEMANO
Time Traveller
About 2-3 years before replacement. Yours are probably ready or will be soon. Time for new ones.
Old 11-05-2017, 01:16 AM   #1157
vfrqqq
Ultra Senior Member
vfrqqq's Avatar
So they may be failing even if the resting voltages for both batteries are around 13 V?
Old 11-07-2017, 10:26 AM   #1158
vfrqqq
Ultra Senior Member
vfrqqq's Avatar
For anyone that has noticed a smell (e.g., gas/oil odor) during/after the ESC is activated, have any of you installed a check valve on the PCV line and noticed a difference? I just installed the check valve, but have some activation issues with my ESC so I haven't been able to properly notice whether the smell I usually get is gone.
Old 11-07-2017, 03:08 PM   #1159
DAEMANO
Time Traveller
Hi, Sorry about the delay in the response. Didn't see it. This is beyond my knowledge of battery wear/decay and performance. I'd say, if you're in the 2-3 year window and the system isn't performing as it had prior. Battery wear/duty cycle in this application has been identified as one of the more likely issues.
Old 11-07-2017, 03:11 PM   #1160
DAEMANO
Time Traveller
I think you may be on to something. I also have a check valve installed in a PCV side catch can. It captures a fair amount of blowby and I have no oily smell from under the hood or while driving. Yep, this could be the source of an oily smell from anyone running an ESC (or any forced induction for that matter) without a PCV side catch can and check valve.
Old 11-07-2017, 06:22 PM   #1161
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
You may want to check to see if you are leaking oil above the overpupe.
Installed Mods:
Old 11-07-2017, 07:54 PM   #1162
vfrqqq
Ultra Senior Member
vfrqqq's Avatar
I’ll check that, but I don’t think that will prove to be an issue. So the weird thing that I have never figured out is that, after having activated the ESC and producing the odor, I’ve come to a stop shortly afterward, opened the hood and there is no odor. That, contrasted with the fact that if I have my windows open when using the system, the odor fills the inside of the car almost immediately. This was one of the first things I noticed and investigated after I used the system for the first time cause I was sure I’d screwed something up in the install.
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 03:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
