Old 07-04-2012, 01:10 PM   #99
Originally Posted by DarrenDriven View Post
You guys wanted some video of how the headlight looks, so here you go...
"...renders it completely useless,.... but I mean, it looks good so come on!..."
Yea, definitely because that is what matters!
I don't have a real issue with you not having high-beams. I can honestly say that I may use my high-beams once a year (I average about 30K a year driving), and usually only for a couple of minutes. I just have never liked them.
I have more of an issue with the yellow bulb in their place. That would seem to be a bad location for a yellow bulb if you decide to use them.
Old 07-04-2012, 01:51 PM   #100
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
I originally had 3000k HIDs in the high beam, but I felt they were too bright, so I replaced them with a 100W 9005 bulb with a yellow coating which was STILL too bright, so I have a yellow 9005 LED bulb on the way from Hong Kong via eBay.
I've said it like ten times, the blacked out high beam lens was an experiment that didn't really pan out like I thought.... but I only drive the car in town so I don't really need high beams. I can always revert back to chrome high beam reflectors or convert the projectors to bixenon.
The Following User Says Thank You to DarrenDriven For This Useful Post:
Dadhawk (07-10-2012)
Old 07-04-2012, 02:08 PM   #101
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
honestly... what did you expect ?
zAnSh1n is offline   Reply With Quote
Old 07-04-2012, 02:22 PM   #102
DarrenDriven
NW Region Moderator
Read the topic for yourself and find out... no reason to post it over and over and over. Seriously.
Old 07-04-2012, 02:39 PM   #103
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
what do you mean by "the topic," the thread title ?
Old 07-04-2012, 02:48 PM   #104
DarrenDriven
NW Region Moderator
Start on page one and read the questions and comments that other people have already asked and I have answered.
Page 1
I expect that I will have very poor high beam intensity because of the blacked out reflectors, but we'll see.
my high-beams are pretty much useless now, but it's worth it for the sexy, sexy look. I will install some HID spot light/driving lights in the near future that will replace the high-beam's job.
Originally Posted by Calum View Post
Why paint the reflector, won't that kill the high beams output?
Originally Posted by HunterGreene View Post
Agreed, looks way better, but your high beams could be totally ineffective.
That is just on page one... there ARE four more pages of information contained in this topic (another word for thread, this entire series of postings).
Old 07-04-2012, 02:54 PM   #105
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
Page 1
ahhh, gotcha...
just another case of form over function... as long as you're happy with it
Old 07-04-2012, 03:07 PM   #106
Ryuu0u
(=^・ェ・^=)
Ryuu0u's Avatar
Drives: 2013 FRS, '08 GSXR 600
To be honest i thought it was going to look cheap and ugly just reading the title but it looks really good!
Integrating the high beam into the low beam sounds and looks like it'll work but that empty space would bother me for some reason. Possible to make another projector for the high beam?
Ryuu0u is offline   Reply With Quote
Old 07-04-2012, 09:07 PM   #107
ragingSPAM
Photojournalist
ragingSPAM's Avatar
Drives: Firestorm FR-S, EG8 civic
If you're going to paint the chrome parts, you might as well wet sand them down so the paint sticks. The chrome parts are extremely slick and the paint over time may eventually flake off, doing some wet sanding with 1000 grit then to 1500 grit should do the trick of allowing the paint to stick to it.
Before you spray it and after its been sanded, get some wax and grease remover from auto zone or any auto parts store and go over the housing with a clean rag. it'll remove any oils/dirt that my have gotten on the plastic which is really the reason why fish eye's occur. If you don't have an air compressor then get some of the duster cans from fry's/best buy/electronics/staples/or even walmart type stores and blow of any dust before painting.
ragingSPAM is offline   Reply With Quote
The Following User Says Thank You to ragingSPAM For This Useful Post:
tripjammer (07-26-2012)
Old 07-04-2012, 09:11 PM   #108
Lil Abner
Drives: 2013 FR-S, 6MT, Ultramarine
For the sanding, you actually shouldn't use 1000 grit sand paper. I always sand everything down with 220 grit, then spray a coat of primer. The primer will grab the surface, and will give a smooth look. Sanding with 1000 grit will make the surface too smooth for anything to stick. You can also use etching primer.
The rest, with the oil/wax remover is a must!!
Lil Abner is offline   Reply With Quote
The Following 2 Users Say Thank You to Lil Abner For This Useful Post:
suaveflooder (07-09-2013), tripjammer (07-26-2012)
Old 07-04-2012, 09:26 PM   #109
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
this.
Old 07-04-2012, 11:37 PM   #110
ragingSPAM
Photojournalist
ragingSPAM's Avatar
On an already smooth surface i usually start with 600 grit to prep for paint but it depends on the material, and yes primer is definitely a must!
I think 220 may be a bit coarse so it may cause visible sand scratches (not much but visible) if you start with 220 then prime it, then 600 before paint it'll probably work out great. Yea i got a little ahead of myself with the 1000/1500 grit, that is more for color sand and polishing
Old 07-07-2012, 02:35 PM   #111
ThaBigUnit
Awesome Member!
ThaBigUnit's Avatar
Drives: 2013 Scion FR-S (Asphalt)
Like Everyelse has stated...LOOKS SICK!! Great job. I do have one quick question, i noticed in the video you also swapped out the lower parking lights. what kind of light did you use? I would like to get the same for my asphalt
ThaBigUnit is offline   Reply With Quote
Old 07-08-2012, 12:12 AM   #112
DarrenDriven
NW Region Moderator
Here is the eBay auction for the lights and the resistors that I bought to slow down the blinker once it was converted from incandescent to LED (speed blinkers).
http://www.ebay.com/itm/160828174884
http://www.ebay.com/itm/140540678602
HID Headlight Upgrade KIT - 1st MOD completed SpecPer Exterior Parts - The Rest 76 08-03-2012 11:13 AM
Is Anyone Else Tired of SOA Information Blackout geb2391 BRZ First-Gen (2012+) — General Topics 23 04-21-2012 10:37 PM
Headlight Swap Question nogaroblues4 Scion FR-S / Toyota 86 GT86 General Forum 9 02-07-2012 03:45 AM
headlight condensation MRZ415 Off-Topic Lounge [WARNING: NO POLITICS] 1 01-23-2012 03:24 AM
TRS headlight mod RRnold Other Vehicles & General Automotive Discussions 0 12-24-2011 05:20 PM
