#99 | |
Yea, definitely because that is what matters! ![]() I don't have a real issue with you not having high-beams. I can honestly say that I may use my high-beams once a year (I average about 30K a year driving), and usually only for a couple of minutes. I just have never liked them. I have more of an issue with the yellow bulb in their place. That would seem to be a bad location for a yellow bulb if you decide to use them. Last edited by Dadhawk; 07-04-2012 at 01:21 PM. |
#100 |
NW Region Moderator
Drives: FR-S No More
I originally had 3000k HIDs in the high beam, but I felt they were too bright, so I replaced them with a 100W 9005 bulb with a yellow coating which was STILL too bright, so I have a yellow 9005 LED bulb on the way from Hong Kong via eBay.
I've said it like ten times, the blacked out high beam lens was an experiment that didn't really pan out like I thought.... but I only drive the car in town so I don't really need high beams. I can always revert back to chrome high beam reflectors or convert the projectors to bixenon.
| The Following User Says Thank You to DarrenDriven For This Useful Post: | Dadhawk (07-10-2012) |
#101 |
♥カレー大好き !!
Drives: ♿
honestly... what did you expect ?
#102 |
NW Region Moderator
Read the topic for yourself and find out... no reason to post it over and over and over. Seriously.
#103 |
♥カレー大好き !!
Drives: ♿
what do you mean by "the topic," the thread title ?
#104 | |||
NW Region Moderator
Start on page one and read the questions and comments that other people have already asked and I have answered.
Page 1 Quote:
That is just on page one... there ARE four more pages of information contained in this topic (another word for thread, this entire series of postings).
#105 | |
♥カレー大好き !!
Drives: ♿
just another case of form over function... as long as you're happy with it
#106 |
(=^・ェ・^=)
Drives: 2013 FRS, '08 GSXR 600
To be honest i thought it was going to look cheap and ugly just reading the title but it looks really good!
Integrating the high beam into the low beam sounds and looks like it'll work but that empty space would bother me for some reason. Possible to make another projector for the high beam? |
#107 |
Photojournalist
Drives: Firestorm FR-S, EG8 civic
If you're going to paint the chrome parts, you might as well wet sand them down so the paint sticks. The chrome parts are extremely slick and the paint over time may eventually flake off, doing some wet sanding with 1000 grit then to 1500 grit should do the trick of allowing the paint to stick to it.
Before you spray it and after its been sanded, get some wax and grease remover from auto zone or any auto parts store and go over the housing with a clean rag. it'll remove any oils/dirt that my have gotten on the plastic which is really the reason why fish eye's occur. If you don't have an air compressor then get some of the duster cans from fry's/best buy/electronics/staples/or even walmart type stores and blow of any dust before painting. |
| The Following User Says Thank You to ragingSPAM For This Useful Post: | tripjammer (07-26-2012) |
#108 | |
Drives: 2013 FR-S, 6MT, Ultramarine
The rest, with the oil/wax remover is a must!! |
| The Following 2 Users Say Thank You to Lil Abner For This Useful Post: | suaveflooder (07-09-2013), tripjammer (07-26-2012) |
#109 |
♥カレー大好き !!
Drives: ♿
#110 |
Photojournalist
On an already smooth surface i usually start with 600 grit to prep for paint but it depends on the material, and yes primer is definitely a must!
I think 220 may be a bit coarse so it may cause visible sand scratches (not much but visible) if you start with 220 then prime it, then 600 before paint it'll probably work out great. Yea i got a little ahead of myself with the 1000/1500 grit, that is more for color sand and polishing |
#111 |
Awesome Member!
Drives: 2013 Scion FR-S (Asphalt)
Like Everyelse has stated...LOOKS SICK!! Great job. I do have one quick question, i noticed in the video you also swapped out the lower parking lights. what kind of light did you use? I would like to get the same for my asphalt
#112 |
NW Region Moderator
Here is the eBay auction for the lights and the resistors that I bought to slow down the blinker once it was converted from incandescent to LED (speed blinkers).
http://www.ebay.com/itm/160828174884 http://www.ebay.com/itm/140540678602
| HID Headlight Upgrade KIT - 1st MOD completed | SpecPer | Exterior Parts - The Rest | 76 | 08-03-2012 10:13 AM |
| Is Anyone Else Tired of SOA Information Blackout | geb2391 | BRZ First-Gen (2012+) — General Topics | 23 | 04-21-2012 09:37 PM |
| Headlight Swap Question | nogaroblues4 | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 02-07-2012 02:45 AM |
| headlight condensation | MRZ415 | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 01-23-2012 02:24 AM |
| TRS headlight mod | RRnold | Other Vehicles & General Automotive Discussions | 0 | 12-24-2011 04:20 PM |
