Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Commercial Classifieds > Exterior Parts - Lighting
Old 10-30-2014, 12:44 PM   #99
BabaYaga
BabaYaga's Avatar
Drives: FRawSome Hot Lava
2 issues with DD conversion.
Originally Posted by wrb View Post
Looks great, but there's a slight delay/lag with turn signal when running light is on.
I second that!
There is couple of issues I have with this conversion:
First: Delay/lag when using turn signal. It feels like it is "thinking" for a second before actually start blinking. OEM blinking is starting with light ON, then OFF, then ON. DD upgrade starts blinking on the second ON compare with OEM. So, the lag is first cycle of blinking. That is might be issue with CF18 blinker, I do not know.
Second issue – more annoying: When turn signal is ON the blinking rotates between front lights and rear lights. They are not blinking together! When rear blink is ON front is OFF and vice versa.
I will try to make a video and posted later today or tomorrow.
BabaYaga is offline   Reply With Quote
Old 10-30-2014, 03:08 PM   #100
mush
mush's Avatar
Originally Posted by BabaYaga View Post
I second that!
are u serious?! thats annoying...
Old 10-30-2014, 05:05 PM   #101
Alain
FRSKEE
Alain's Avatar
Drives: 2014 Monogram Series Whiteout
I second that!
I may know the answer to that. As i am testing mine. I believe, correct me if im wrong, if you have stock turn bulbs up front that might be causing the delay. I know thats how my is acting.
Alain is offline   Reply With Quote
Old 10-30-2014, 07:40 PM   #102
BabaYaga
BabaYaga's Avatar
I have aftermarket LED turn lights in front and stock in the rear and before DD conversion they worked together without hyperblinking.
Old 10-30-2014, 11:49 PM   #103
Struckbylitenin
Struckbylitenin's Avatar
Drives: 10 Series FR-S
I second that!
I received mine today but didn't install yet... and ON TOP, have to wait a month for their LED bulbs.
I really hope this isn't the case...
Struckbylitenin is offline   Reply With Quote
Old 10-31-2014, 12:00 AM   #104
captain_jack
captain_jack's Avatar
Got mine today at work but I'm off to move this weekend so it's going to be a few days.
Old 10-31-2014, 01:02 PM   #105
Diode Dynamics
Diode Dynamics's Avatar
Got mine today and installed it.
Is this a known problem?
Hmm, that is not normal at all. What do you mean by "delay" exactly? It wouldn't have anything to do with the tail as turn modules. There is an issue with the flasher- that is what controls blinking function and speed. Are you using our flasher module? Please feel free to email or PM if it is easier to discuss, thanks!
I second that!
Any delay in the turn signal would be the result of the flasher, not the tail as turn mod. Are you using our flasher or a different one? If there's some issue with our flasher, we'll be glad to replace it. The flasher is what controls all blinking function and speed.
Regarding the alternating flashing, that is a very simple explanation, and it is necessary for safety, actually. Here's how it works: If you have brake lights on and hit your turn signals, the light will be already illuminated from the brake light, so the turn signal flashes by switching the light OFF first. You don't want to wait for a blinking cycle (about a second) for the light to "catch up" to the next on/off cycle. We did it this way because this is how OEM vehicles work as well, again, for safety reasons. You need to indicate your turn signal immediately, not a second after you hit it.
It's actually pretty hard to even notice unless you're purposely looking for it, no one sees the front and back of your vehicle at the same time.
Front and back blink together normally, this only happens when you hit the brake and turn at the same time. To be honest, the guys here actually thought it was pretty cool.
Thanks!
John C.
Diode Dynamics
Old 10-31-2014, 07:32 PM   #106
Akari
Drives: 2013 DGM BRZ
Was going to place an order but it looks like you're out of the flashers. Any idea when these will be available again?
Akari is offline   Reply With Quote
Old 10-31-2014, 09:16 PM   #107
Diode Dynamics
We're out of just about everything thanks to you guys! Totally cleared out of backup bulbs too.
We're expecting a big shipment towards the end of this coming week. Thanks!
John C.
Diode Dynamics
Old 11-01-2014, 01:04 AM   #108
Struckbylitenin
Any reason as to why the XP80's are no longer on your site?
If you're getting something better/brighter let me know so I can cancel my backorder.
Old 11-01-2014, 03:02 PM   #109
Diode Dynamics
Because they are out of stock. With 510 measured, actual lumens, that's the brightest possible bulb that will be on the market for quite some time! Just not visible on the site since it's out.
John C.
Diode Dynamics
Old 11-01-2014, 05:00 PM   #110
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
Just installed mine today. Awesome job on this DD!
Thankfully, I had some LED bulbs sitting around the where originally for turn signals... Waiting on the back order LEDs
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 11-01-2014, 10:57 PM   #111
NIN69
Izzy Gure (Senior Member)
NIN69's Avatar
Drives: FR-S TRD Release Series 1.0 / #1459
Received and waiting on LEDs.
Visit me on Facebook:
http://www.facebook.com/izzygure
NIN69 is offline   Reply With Quote
Old 11-02-2014, 04:44 PM   #112
Diode Dynamics
We are sad too. And just so frustrated we ran out of bulbs. Not the type of customer experience we aim to provide. Big mistake on our part not having enough. But we decided it was best to at least ship the modules out first.
John C.
Diode Dynamics
FR-S / BRZ Turn Signal LEDs! No Resistors! Switchbacks! Plug & Play Install! Diode Dynamics Interior Parts (Incl. Lighting) 158 08-08-2018 06:52 PM
Adjustable TURN SIGNAL LEDs for FR-S & BRZ ~Choose color & brightness~ Plug-N-Play KI_ZN6 Exterior Parts - Lighting 685 02-18-2016 11:03 PM
** INTRO PRICING** JWM Switchback Turn Signal LEDS For FR-S Owners JWMotoring Exterior Parts - Lighting 212 04-06-2014 11:24 PM
Quickets AND Cheapest Turn signal and DRL LEDs? BlackyRose Cosmetic Modification (Interior/Exterior/Lighting) 2 06-17-2013 09:52 PM
