Old 02-18-2015, 08:03 PM   #99
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Originally Posted by acj47 View Post
I am using the v2.06 Stg2_EL_E85_A01C.bin map.
When I am using launch control, the engine will rev to two different RPM values based on the transmission in neutral vs. in gear (tested with 1st gear).
EDIT: all testing values below are at rest, i.e. 0 mph.
For example, I have tested it with (3) separate LC RPM Delta values.
(Launch Control Disable Speed is set to the default value (6), and Flat-Foot Shift RPM Delta is set to the default value (0) for all tests.
Launch Control RPM Delta value set at 3600 (7600-3600=4000 RPM)
- clutch off, neutral: RPM=3600
- clutch on, neutral: RPM=3600
- clutch on, 1st gear: RPM=4000
Launch Control RPM Delta value changed from 3600 to 3100 (7600-3100=4500 RPM)
- clutch off, neutral: RPM=4100
- clutch on, neutral: RPM=4100
- clutch on, 1st gear: RPM=4500
Launch Control RPM Delta value changed from 3100 to 2600 (7600-2600=5000 RPM)
- clutch off, neutral: RPM=4600
- clutch on, neutral: RPM=4600
- clutch on, 1st gear: RPM=5000
It seems that no matter the setpoint, with the transmission in neutral the RPM value = LC delta - 400 RPM. Has anyone else noticed this, and/or is it an expected behavior? It doesn't do any harm, I'm mostly just curious why it happens more than anything.
I had noticed this a while back, but wasn't sure if I was doing something wrong or was using an older version or something. I only noticed, since I wasn't able to rev over 4k in neutral, while sitting still-clutch in/out didnt matter nor did being in 1st/neutral.
Old 02-19-2015, 11:18 AM   #100
cameronjones239
cameronjones239's Avatar
Drives: 2015 Subaru BRZ Series Blue
Originally Posted by AlexBinJackson View Post
Anyone know when the lc and ffs will be available for d00C cals just got oft today and cant wait to tune.
Curious how this is coming along as well, picked up the OFT excited to try these features out and a bit bummed when I saw it was not available for the 15's yet
@Shiv@Openflash
cameronjones239 is offline   Reply With Quote
Old 03-03-2015, 12:33 AM   #101
scarfo
Drives: gts 86
anymore word about this, im on the DOOG rom still nothing as of yet( altough its a new rom)
scarfo is offline   Reply With Quote
Old 06-04-2015, 12:00 AM   #102
einrejosh
einrejosh's Avatar
Drives: 2014 Scion FR-S
Bump.
With the new V2 OTS tunes do we have to wait for the new XML files for the V2 OTS tunes to get LC/FFS?
Because I understand that i'd have to use a V1.x tune with the XML V1.x files to get LC/FFS, but I just don't want to considering the V2 is the most updated.
einrejosh is offline   Reply With Quote
Old 06-04-2015, 12:30 AM   #103
einrejosh
einrejosh's Avatar
Originally Posted by cameronjones239 View Post
If you have a 2015, don't hold your breath...
Nah 2014, frs. B00C
Old 06-22-2015, 08:32 PM   #104
D_Thissen
D_Thissen's Avatar
Neeeeat! Thanks Shiv!
[ame]http://www.youtube.com/watch?v=DqqicIWZrO4&sns=em[/ame]
Old 07-30-2015, 09:57 PM   #105
poolboy54
Drives: Scion FRS. Silver with black badges
Do the same concept apply to the v2.067?
I want launch control at 3k. So 7600-4600=3000, I did that but when I put the tune on my car. It started then died...
poolboy54 is offline   Reply With Quote
Old 07-30-2015, 10:26 PM   #106
steve99
yes same patch
make sure your using the oft V2x definitions that come with V2 tune pack and not the V1.5x definitions.
Old 07-31-2015, 07:59 AM   #107
poolboy54
Thanks
Old 06-22-2016, 10:11 PM   #108
kingxix
Launch Control
Hey guys I have my car on the oft stage 2 uel tune and I'm trying to find the launch control setting. Now I've heard all you have to do is plug the oft in, put it in first and gas it but when I do that the launch control doesn't engage. What am I doing wrong?
kingxix is offline   Reply With Quote
Old 06-22-2016, 10:24 PM   #109
Songha
Songha's Avatar
Drives: 2013 Scion FRS
Mine works fine, there's no setting, it's just there preset at like 5.7k. Clutch in, hold, first gear, gas and wamwamwam, lol. To change it you go into RomRaider and adjust I believe.
2013 Scion FR-S | 6-MT | Raven Black | Performance Mods: Invidia N1 Catback, Invidia Catless Frontpipe, BC Racing Extreme Lows Coilovers, 1320 Performance UEL Catless Headers, 1320 Performance Overpipe, OpenFlash Tablet (Stage 2 UEL, 93 Oct. tune), Whiteline Front Swaybar, Whitelight Adj. Front Endlinks | Asthetic Mods: DS Style Front Lip, Rocket Bunny style flares, F1R F21s | MY BUILD THREAD!
Songha is offline   Reply With Quote
Old 06-23-2016, 12:34 AM   #110
steve99
not all oft rom calid have the launch/FFS software patch.
open your tune in romraider using the oft defininition and see in the launch and ffs tbles are in tune.
or else ring the oft guys on phone
Old 09-01-2016, 03:44 PM   #111
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
i think its time you upload a video showing how to edit launch control @Shiv@Openflash !!
Dr. BRZ is offline   Reply With Quote
Old 09-01-2016, 05:32 PM   #112
everythingsablur
everythingsablur's Avatar
Drives: 2016 Scion FR-S RS 2.0
Isn't it just:
  • Open RomRaider
  • Open a ROM file to edit that works on the calid of your car
  • Go to the Alpha BRZ LC/FFS settings
  • Edit Launch Control Delta RPM
  • Change value to xxxx (where 7600 - xxxx = your desired LC RPM)
  • Save
  • Copy to OFT
  • Plug into car and flash like any other ROM
2016 Scion FR-S Release Series 2.0 #170/1000
everythingsablur is offline   Reply With Quote
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
racerom flat foot shifting ft86me Engine, Exhaust, Transmission 10 07-25-2013 03:02 PM
EcuTek RaceRom Flat Foot Shifting ! Visconti Engine, Exhaust, Transmission 79 11-14-2012 09:36 PM
