Old 12-31-2014, 10:23 PM   #99
troek
troek's Avatar
Drives: 2012 Toyota 86
Almost every single 86 race car here has a 4.5-5.1 final swap, depending on the track. Those who dont have 400ish hp.
Old 07-22-2015, 06:32 AM   #100
fooyc
fooyc's Avatar
Drives: GT86-JDM
http://www.supertaikyu.com/entrant/o...etin_no.08.pdf
may be this info will help on part number? sorry guys I don't read Japanese too...
page2 , page4 & page5 all hv diff FD ratio used by Gazoo racing & etc in the supertaikyu race.
fooyc is offline   Reply With Quote
Old 07-22-2015, 09:29 AM   #101
Wyattkb
Drives: 2014 Whiteout FRS
Just curious if someone has a link to where I can order this?
Most links in this thread are in another language or are terrible sites to navigate.
Wyattkb is offline   Reply With Quote
Old 07-23-2015, 04:55 PM   #102
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Do they remove the speed limiter (180 km/h)? If not, then it makes a sense. But if they remove it, then I cannot imagine driving a "race car" on a track using overdrive (6th gear). This is pretty much nonsense. With a 4.5-5.1 final drive ratio, the 5th gear is very very short. Don't forget that the gear box ratios are also quite short!
The short final drive ratio gives better results only in smaller gears like 1st and 2nd. It makes more sense in gymkhana events or for playing going sideways. That's the main reason they even install the 4.1 final drive ratio.
My car has a 3.7 final ratio and it is lighter and I am very happy with the result. Almost the same acceleration and a top speed in 5th gear! I'm using the 6th gear just for fuel economy! It is very funny to go side by side with a bmw 535d f11 (313ps και 630nm !!) in the autobahn up to 230km/h. And don't forget that such a bmw costs more than double! This is simply not possible with a shorter final drive ratio. Secret is to use the engine power band wiser
Old 07-23-2015, 11:23 PM   #103
troek
troek's Avatar
Not many tracks here go over 200kph. Fuji speedway and suzuka are about it. Cant speak for suzuka, but fuji and tsukuba, almost every car that is fast and na is running shortened final drives. On fujis strait even with the shortened final drive u would only hit 6th gear for a moment, and the benefit of getting there faster outweighs having to hit 6th gear for 1-2 seconds at 220kph.
Old 07-24-2015, 02:39 AM   #104
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
But you are not getting there faster. You accelerate faster up to the mid of 3rd speed and then you gain speed slower. I tried once with a 4.5 fd ratio in nurburgring gp and the final speed in the big straight was actual the same! And my tests were from full stop which give a favour to the shorter fd.
There is not such a magic thing that gives you more "power". The only thing that the fd ratio changes is the area in which you are stronger. Shorter ratio gives you more strength in lower gears and speeds. Higher ratio gives you more strength in higher gears and speed.
Old 07-24-2015, 03:47 AM   #105
troek
troek's Avatar
Damn, all these professional time attack teams have had it wrong all along. i'll go let them know they are wasting their time.
Old 07-24-2015, 11:54 AM   #106
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
This is an entirely different story. They are playing with the final drive ratio and the gear ratios for having better power bands in specific corners. It is about having the correct rpm when exiting the apex. With this way you have a better car for a specific track, but you have to change everything on another track. Such cars are pretty much useless in ordinary roads. They might make a lot of noise but nothing else. I am sorry if I seem a bit offensive, but we should understand that there isn't a magic solution. With such short ratios, you cannot even achieve the factory top speed.
Old 07-24-2015, 12:13 PM   #107
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Here are some calculations with changed final drive ratio and everything else stock:
Old 07-24-2015, 01:26 PM   #108
churchx
churchx's Avatar
Drives: 2014 GT86
nikitopo: even if there cannot be "one ratio fits all tracks best", there can be "one ratio mostly fits to most tracks (or way it's DD driven at particular tuned powelevels). And something tells me, that big numbers of NA track racers, that have installed different ratio final drive, signifies, that at least for them, at least relative to stock, it benefits them there.
Old 07-24-2015, 11:11 PM   #109
troek
troek's Avatar
Your wasting your breath. He wants to ignore the simple physics of the mechanical advantage of a shorter final drive. Its not something that is up for debate. Is there one final drive that is a perfect match for every track? No, no one is saying that. The simple fact here is that a 86 with a 4.5 will accelerate faster than one with a 4.1.
The Following 4 Users Say Thank You to troek For This Useful Post:
Aztec (07-26-2015), kingkenny (07-25-2015), NWFRS (07-26-2015), swarb (07-25-2015)
Old 07-25-2015, 07:54 AM   #110
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Please explain to me in simple physics why a 4.5 fd ratio car is accelerating really really faster in a higher gear comparing to a 3.7 fd ratio car.
3.7 fd ratio
5th gear 184 - 223
6th gear 223 - top speed
4.5 fd ratio
6th gear 184 - top speed
Can't you see that there is no thing such an overall improvement? You gain acceleration in lower gears (1st, 2nd, 3rd partially) and you loose in other gears (4th, 5th, 6th).
If you want to have an overall faster car try other things. Changing the final drive ratio is a waste of money for the majority of people. It might give a wow effect, but nothing really actual that worth the money.
And it is not about a debate. It is that we should be very careful of what we write and suggest. People over here are reading and spending money in modifications and we should be very clear of what to expect.
Thank you and bye.
Old 07-25-2015, 11:46 PM   #111
troek
troek's Avatar
first of all, your top speeds are horribly incorrect, 2nd of all top speed is not acceleration. Not sure why you keep getting that conused. And why on earth would the mechanical advantage dissapear after 3rd gear? If anyone besides this tool wants evidence of shorter final drivrd improving acceleration, and you cant find it on google, let me know id be more than happy to link to the plethora of articles and tests proving quicker acceleration.
Herrs one quick reference, i think you are not fully understanding the purpose of a final drive http://www.badasscars.com/index.cfm/...rod/prd398.htm
Old 07-26-2015, 12:14 AM   #112
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
You know it's useless trying to convince him of anything :P
Troek's right, EVERY gear will be putting more torque down directly comparing the stock 4.1 to a 4.56. For example, This is about a 10% increase in torque applied to the wheels and it WILL be faster ACCELERATING until you reach 100-120mph which at that point, it doesn't matter as the shorter gears would have either won the drag race or reached the next corner of a track.
On a side note, my 4.56 ring and pinion arrived yesterday going to have it installed August 6th
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
The Following 2 Users Say Thank You to Aztec For This Useful Post:
Lonewolf (07-26-2015), troek (07-26-2015)
Part Number help Sh944 Cosmetic Modification (Interior/Exterior/Lighting) 2 11-14-2013 03:10 PM
what's the part number for this? chenshuo BRZ First-Gen (2012+) — General Topics 11 10-07-2013 12:22 PM
Part number for Toyota 86 GT Limited red leather seats? iketiak Scion FR-S / Toyota 86 GT86 General Forum 8 04-10-2013 12:54 PM
I need a part number Bones36 Cosmetic Modification (Interior/Exterior/Lighting) 0 09-01-2012 06:25 PM
Part Number for this DriftEightSix AUSTRALIA 20 06-25-2012 09:30 PM
