Old 08-28-2012, 09:46 PM   #99
BAE
BAE's Avatar
Drives: BRZ Ltd WRB
I was up for an event I help run (ITR Expo). I was just running AD08s in 235/40/17, stock suspension on one day, eibach sportline with whiteline top hats up front the second day.
How was the laptimes before and after Eibachs?
Enkei RPF1/K&N/Perrin crank pulley/Visconti Stg1/Perrin catback and overpipe/KW V3
BAE is offline   Reply With Quote
Old 08-28-2012, 10:15 PM   #100
FRSpdDmn
Drives: 128i, Z3 Coupe, Fiero GT
+1
How was the balance altered? Any alignment changes?
-Anthony
Former '13 Whiteout FR-S, BMW 128i, BMW Z3 Coupe, Pontiac Fiero GT
2017 Pirelli World Challenge TC Rookie of the Year
2012 NASA SpecE30 National Champion
www.DriveFasterNow.com
FRSpdDmn is offline   Reply With Quote
Old 08-29-2012, 11:12 AM   #101
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Eventually I'll post a review.. but.. my aim solo battery died after 1 lap with the springs, so going with the extremely accurate gopro video timer method the fastest lap with stock vs sportlines showed an improvement of approx 1.5 seconds and an average in the sessions of 2-3. I didn't do a ton of data measurement (surface temps, tire temps, etc) since I'm not that much of a detail person...
Alignment and video of a few laps with the springs is here (as well as alignment info for FRSSpdDmn): http://www.ft86club.com/forums/showthread.php?t=15789
Overall balance was changed to understeer/push but IMO that's the alignment I requested on purpose as I didn't want to risk the car 1,100 miles from home on a track not exactly known for being forgiving. Unfamiliar car and a rushed spring install.. seemed like a bit of push would be a good idea I also left VSC Sport on but besides flashing the light annoyingly every time ABS engaged and/or I used curbing it didn't really engage.
Yes, I was a wuss @ mid ohio Sebring in Oct (or maybe late September) I'll be able to explore the limits when I'm comfortable
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
FRSpdDmn (08-29-2012)
Old 08-29-2012, 11:42 AM   #102
BadCompany235
#TrackAddicts
BadCompany235's Avatar
Drives: The Dipped Car
FWIW i'm going to be trying out the Endless compounds for the last few months of the year. currently using DS2500 F and stoptech performance R with no problems. RBP600 fluid but thinking of trying AP600 also. i'll provide my feedback if you want it. total spent on "researching" compounds is around $900 now. smh
Racecomp Engineering / FT-86 Speedfactory / Essex / Counterspace Garage / Topspeed Motorsports / Forged Performance
Chadbee Photography / Passion Moves Photography
BadCompany235 is offline   Reply With Quote
The Following User Says Thank You to BadCompany235 For This Useful Post:
Takeshi (10-01-2012)
Old 08-29-2012, 11:42 AM   #103
FRSpdDmn
I assume you were on OEM shocks. Did you feel that the dampening was tolerable as the car was lowered and the spring rates were (I'm assuming) raised a bit?
-Anthony
Old 08-29-2012, 11:45 AM   #104
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Awesome, let me know your opinions on them.
The one thing I wish the XP10s had was more initial bite, damn Blues spoiled me there so many years ago and few pads have matched the bite those pads have, that I've used anyways. I'd love to find something with similar initial bite to the blues but without the rust dust problem.. and without the short life expectancy of blues.
The XP10s are much better than the last Cobalts I used though.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-29-2012, 11:56 AM   #105
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yeah, OEM shocks. This is a temp solution mostly, planning on running threaded body stuff eventually.
There's evidence to show that the OEM dampers are overdamped for the OEM springrate, and the car now feels ever so slightly underdamped, but on the edge. It's not in any way bouncy, no excessive motion, etc so on the high side it seems fairly well damped. The car is low enough now that you have to be careful though, it can bottom out. After almost 2,000 miles though the dampers are holding up fine though.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-29-2012, 04:27 PM   #106
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
What would you guys suggest for a daily driver? I will probably do new rotors and pads in the spring just curious if i should get something like the Stoptech sport kit, i don't see a need to change the lines though.
JoeBoxer is offline   Reply With Quote
Old 08-29-2012, 04:50 PM   #107
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Daily Driver? Stock pads, stock rotors, stock lines...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 09-10-2012, 08:38 AM   #108
BadCompany235
#TrackAddicts
so new feedback....the stoptech performance pads are fine front and rear. i dare say better than ds2500 f and stoptech r....brakes were more balanced this wknd and really slowed better even tho i didn't have as aggressive front bite. still load the front well and trail better actually because of how i changed my braking points and pressure. way less abs kick tho and it felt smoother.
did have fade but my brake fluid is really dirty so it may have been more fluid fade than pad. tear down tomorrow and i'll let everyone know... but for now i have to say i'm impressed with my 'backup' brake pads. this car just keeps me smiling.
for anyone looking for a good street pad, go ahead and try the stoptech, good cold bite, quick bedding, and decent endurance in a light car. when i change tires i may have a different opinion but if you're gonna be stock for a while it's a good upgrade. and the price is great too.
JoeBoxer (09-10-2012)
Old 09-10-2012, 10:50 AM   #109
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Originally Posted by Racecomp Engineering View Post
^ I agree on selecting the right heat range pad, but my problem with HPS pads is that they suck even as street pads and are often advertised as a "sport" upgrade to stock which is entirely false. There is no application where they are acceptable to me.
- Andrew
I agree. I was really disappointed with these pads. I mean, they aren't horrible but they're just sub-par in basically every way. They tend to squeak, dust a lot, and have a weak bite unless heated from very hard braking. But heat them up too much and they start sucking again... It's the worst modification I ever made to my car. Fortunately, I'm about to change brakes again and will likely be going with Endless.
Has anyone tried Akebono Performance pads? I hear they're pretty good all around street pads for the money.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
The Following User Says Thank You to Bristecom For This Useful Post:
Racecomp Engineering (09-10-2012)
Old 09-10-2012, 11:53 AM   #110
The stoptechs are great street pads for the money.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
acro (10-07-2012)
Old 09-20-2012, 03:55 AM   #111
ASSALBERT
ASSALBERT's Avatar
Drives: DC5
for those raving about the Ferodo ds2500s, id highly recommend you guys take a look into the new Project Mu HC+800 compound. So far, these are the only "dual purpose" track pad that I havent had fade on me at the track and the price point is right on.
ASSALBERT is offline   Reply With Quote
The Following User Says Thank You to ASSALBERT For This Useful Post:
BadCompany235 (09-20-2012)
Old 09-20-2012, 12:10 PM   #112
funbeatsfast
funbeatsfast's Avatar
Drives: '13 FR-S
Stock pads were fine with stock tires. I put on StopTech performance pads. Work great with Dunlop Star Specs. Good bite and modulation. Can't speak to fade, as auto-x runs are a minute or less. Maybe a little more dust and noise*.
Service and shipping from Strano was excellent.
*because racecar
funbeatsfast is offline   Reply With Quote
Brake cooling duct kit tranzformer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 12-14-2011 01:37 PM
FR-S Rear brake light... MF_DEUCE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 05-05-2011 03:53 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
Brake override system in the FT-86? mrKiKaZ Scion FR-S / Toyota 86 GT86 General Forum 10 02-22-2010 11:33 AM
