Old 06-08-2013, 06:51 PM   #99
TRD_07
TRD_07's Avatar
Drives: Firestorm 6MT
Has anyone installed the radiator?
TRD_07 is offline   Reply With Quote
Old 06-09-2013, 02:05 PM   #100
TRD_07
TRD_07's Avatar
Hi, would anyone happen to know if you need to remove the front bumper to install the radiator or just loosen the top front bolts of the bumper to remove the radiator support? I didn't see a DIY. Thanks.
Old 06-09-2013, 02:32 PM   #101
pmccut
Drives: Blue Subarus
See a few posts up from @King Tut. I'm waiting on the hoses to come in to try it out.
I just don't like the idea of using hot coolant to cool hot oil. I am buying the Full Blown oil cooler this week.
I installed the radiator this week. I can tell you that this job is not a simple job. It took me about 6 hours to install it. Getting the OEM radiator out is not easy as there is barely enough width to get it out. Leaving the drain plug out helps and you kind of have to watch the A/C lines on the driver side so the radiator doesn't get hung up on them. The Full Blown unit bolted in place perfectly and the Perrin hoses fit it perfectly. The A/C condensor easily bolted in place on the front. I have the dual 16" slim electric fans, so I can't comment on the OEM fan fitment. I will say that I can now see why this radiator might not work on other forced induction kits that utilize a wider radiator than the Full Blown unit. As mentioned the connections for the A/C lines on the driver side of the A/C condensor are moved forward the extra width of the radiator. The Full Blown intercooler is not wide enough to make contact in that area. I filled it up and bled the system with no leaks. Hopefully (well not really) I will hit some bad traffic on the way home this week to see if my temps still start rising.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 06-09-2013, 02:43 PM   #102
robispec
Drives: Black frs project
Bumper off.
robispec is offline   Reply With Quote
Old 06-09-2013, 08:30 PM   #103
TRD_07
TRD_07's Avatar
Ahh, crap. I thought about doing this at my buddy's house but after reading this I think I'll take it to a shop and save myself the hassle.
Old 06-10-2013, 12:59 AM   #104
pmccut
I'm thinking the same Only had the kit on a few days and I've noticed it likes to run pretty hot if stopped for a few minutes. AC on max cold was quite hot at a stop light.
Old 06-10-2013, 09:32 AM   #105
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I don't think there is anyway you can get the A/C condensor disconnected from the radiator without pulling the front bumper off. If you have the capability to install it, then I would still rather spend a day installing it then worry about a shop properly installing it.
Old 06-10-2013, 03:35 PM   #106
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
@FullBlown @Brian@Vortech
Ok tried to fit the full blown with vortech IC, it does not fit the with the vortech alot of fab work is required on the vortech IC and tubing, the mouting points all need to change, and the bracket that the vortech IC uses at the bottom needs to be extended or gotten rid of.
Once again this radiator does not fit a vortech.
In other news anyone want a new FBM intercooler that has never been used? 245 and its all yours, unless FBM will allow me to return it..
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 06-10-2013, 06:27 PM   #107
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Sent from my Nexus 4 using Tapatalk 2
Nolan
pheoxs is offline   Reply With Quote
Old 06-10-2013, 07:33 PM   #108
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Shit.... I'm pretty sure it will be the same with AVO......
Old 06-10-2013, 07:45 PM   #109
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Noo I bought it so I could install it with the avo turbo... hmm may have to return or sell off now.
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 06-10-2013, 07:50 PM   #110
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
@FullBlown @Brian@Vortechalot of fab work is required on the vortech IC and tubing,
For a capable person.
Easy work.
Somebodies getting a decent deal.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 06-10-2013, 08:03 PM   #111
dabocx
dabocx's Avatar
Drives: Scion FRS
If possible can some one do a before and after temp comparison?
dabocx is offline   Reply With Quote
Old 06-10-2013, 08:08 PM   #112
Sportsguy83
Drives: Limited BRZ
I will be taking measurements on it by the end of the week. Will let everyone know.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Draco_PR23 (06-14-2013)
Where are the aluminum driveshafts? post_break Engine, Exhaust, Transmission 22 04-01-2013 05:31 PM
Black Friday @ CMS - Coilovers - Exhaust - Radiators - Suspension - Gauges + More! Circuit Motorsports Announcements, Contests, Giveaways 1 11-26-2012 05:43 PM
Why no aluminum??? epson1 Engine, Exhaust, Transmission 41 08-01-2012 01:18 PM
Steel Vs Aluminum in the FT86 blur Scion FR-S / Toyota 86 GT86 General Forum 72 06-08-2011 03:35 AM
