Old 03-13-2013, 11:04 AM   #99
motrsprt9150
Boss
Drives: asdf
Originally Posted by zooki View Post
Just to let you know, wiring it up this way will only let the foglights come on with the low beams. They will NOT come on with the running lights, and they will turn off when you switch to high beams. Just an FYI.
Is this the same on the US BRZ?
motrsprt9150 is offline   Reply With Quote
Old 03-13-2013, 01:08 PM   #100
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Most likely. The fogs function like that due to the DOT.
Sent from my Nexus 4
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 03-14-2013, 07:35 PM   #101
Willsonk
Drives: Scion FR-S Asphalt AT & XB
Yeah Zooki ..... We have to wire it that way or risk failing yearly state inspection on the car. For my state anyway. Thanks again PatGT86 and everyones input. Makes me more comfortable putting this in. Now I have to find DYI on taking the steeling wheel off.
Willsonk is offline   Reply With Quote
Old 03-14-2013, 08:39 PM   #102
zooki
Drives: waiting on a 2021...
I used this to get the airbag off:
http://www.ft86club.com/forums/showt...ghlight=Airbag
And this to remove & replace the switch:
http://www.trdsparks.com/install/81220-AACHRinst.pdf
Once you get the steering wheel off, the Tundra switches & FR-S switches are exactly the same. The only thing I had to do was reuse the spring clamp from the FR-S switch.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 03-14-2013, 10:54 PM   #103
PatGT86
Drives: 2013 Raven Scion FR-S
Brilliant! Thanks for that guide!
I'm slowly acquiring the parts I need to do this and a couple other mods, this will help me or immensely.
Probably won't be happening until summer as i have a trip to Hawaii that's taking top financial priority right now, but when i get around to doing this, I'll be sure to take lots of pics and show everyone how it goes
Sent from my Nexus 7 using Tapatalk HD
PatGT86 is offline   Reply With Quote
Old 03-16-2013, 05:06 PM   #104
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Has anybody looked into getting a Euro stalk w/ the front & rear fog light switches?
kmbkk is offline   Reply With Quote
Old 03-16-2013, 05:34 PM   #105
Sco2355
If I had the part number I'd order it. Anyone care to post it?
Sco2355 is offline   Reply With Quote
Old 03-16-2013, 08:05 PM   #106
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
X2
Parting out HERE
Old 03-17-2013, 11:30 PM   #107
b$m1th91
b$m1th91's Avatar
Drives: 2013 Asphalt Scion FR-S
Originally Posted by PatGT86 View Post
Thanks!
some minor updates:
Looking at this closely, shouldn't the switch go before the relay?? Why i say is because the coil should only be energized to complete the circuit. The way this looks is power is always going through the coil and will cause the fogs to always be on. Just wondering??
Current Mods- [Fog lights, Takeda CA Intake, LED swaps(Dome, Reverse, Trunk)..., Painted Calipers Red, Beatsonic Shark Fin Antenna] Future Mods- Takeda Exhaust, Perrin Crank Pulley, Reverse Fog light, Rota torque wheels, Custom Sound System:happy0180:
b$m1th91 is offline   Reply With Quote
Old 03-17-2013, 11:45 PM   #108
HRTROB
HRTROB's Avatar
Drives: Toyota 86
It's a negative trigger setup. When the switch is off, the white wire on the BCU/stalk harness tapped to pin 86 of the relay is not grounded - turning the switch on grounds that wire and completes the circuit to the coil.
HRTROB is offline   Reply With Quote
Old 03-17-2013, 11:53 PM   #109
b$m1th91
b$m1th91's Avatar
Is this a good way to wire a circuit though??
Old 03-18-2013, 12:02 AM   #110
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Yes. Where were you thinking of putting the switch?
Old 03-18-2013, 12:05 AM   #111
b$m1th91
b$m1th91's Avatar
I was going to wire mine up this way.
Old 03-18-2013, 12:14 AM   #112
HRTROB
HRTROB's Avatar
Drives: Toyota 86
That won't work with the OEM stalk. You would be feeding ground to both ends of the coil.
Who here has LEDs in their fogs/DRLs in their GT? RZ86 Cosmetic Modification (Interior/Exterior/Lighting) 10 03-30-2013 10:54 PM
Fogs wiring; Will this work? Khánh Cosmetic Modification (Interior/Exterior/Lighting) 12 02-16-2013 12:44 PM
BRZ HID Bulb + HID Fogs delusional DIY (Do-It-Yourself) Guides 4 02-05-2013 05:09 AM
new Camry fogs fit the frs?? hislargeness Cosmetic Modification (Interior/Exterior/Lighting) 3 09-26-2012 03:20 AM
for everyone thinking of using rear fogs xpicer Cosmetic Modification (Interior/Exterior/Lighting) 4 07-04-2012 12:53 AM
