Old 03-12-2014, 05:03 AM   #99
BRZranger
Originally Posted by FT-86 SpeedFactory View Post
Wilwood weight measurements we did in-house
http://www.ft86club.com/forums/showt...t=25550&page=2
Dead link, seems like it would be informative!
BRZranger is offline
Old 03-12-2014, 10:24 AM   #100
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Looks like it was a link to one of our older commercial ads that we have locked up.
Here is the information for future reference.
Got around to doing some housekeeping items around the shop, and took care of getting weights on the Wilwood BBK
Caliper = 4.6 lbs.
Pads = 1.9 lbs.
Rotor Hat = 1.7 lbs.
Rotor = 12.6 lbs.
Hat and Rotor = 14.4 lbs.
Rotor, hat, and hardware = 14.7 lbs.
Caliper mount = 1.5 lbs.
Total system weight = 22.7 lbs.
In stock and ready to ship!
FT-86 SpeedFactory is offline
The Following 2 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
BRZranger (03-12-2014), cgjeff (07-01-2016)
Old 03-12-2014, 01:17 PM   #101
acro
Drives: GT-86
Originally Posted by diss7 View Post
I've sold my Wilwood kit, and am planning on getting one of the AP kits. Hope to have a review up of the differences in the next month or two.
Any update on this. I'm very interested in hearing
acro is offline
The Following User Says Thank You to acro For This Useful Post:
CSG Mike (03-12-2014)
Old 03-12-2014, 09:36 PM   #102
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
One thing I'll add about the Wilwood kit that I've experienced on the track, they increase rear bias quite a bit. I thought it was my stock suspension I ran on the first track day I used the wilwoods on; but I've since tried used rsr coilovers, and more agressive front pads (poly d's then poly h's) and still too much rear bias.
And I only have the shitty non US spec rear brakes, with TRD pads (that are only marginally more agressive than stock.)
So the only thing I'm left with doing is installing a proportioning valve to reduce rear bias.
Bit disappoint TBH. When they say they work with stock rears, I expected they meant it maintained similar bias.
Just an FYI, you can adjust bias by changing front and rear pad compounds. I do it all the time with Cobalt pads, testing out different bias by adjusting compounds. Went from XR2 F / XR4 R then to XR2 square which gave a bit more rear bias for better rotation under trailbraking, and will be testing a XR1 F / XR2 R combo next.
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline
Old 03-12-2014, 10:32 PM   #103
diss7
Drives: AE86, 2x GT86, TE27
Not yet. I have some brembos I've bought off an r34 that I'm going to try next.
Yes tried all of that. Even with a very agressive pad in the front, and a TRD blue in the back (which is barely above stock) it still had too much rear bias.
diss7 is offline
Old 03-12-2014, 10:38 PM   #104
smbstyle
smbstyle's Avatar
Wow, that's not good.
Did Wilwood explain why this happens, or were you able to figure out why? You would figure a larger front caliper with MORE stopping force being a larger, 6 piston caliper vs. the OEM 2 piston clamp-style, would give MORE front bias, not the oppposite?
2013 SWP BRZ
smbstyle is offline
Old 03-13-2014, 02:22 AM   #105
diss7
Their solution was to tell me to buy the rear set as well.
I don't know the technical reasons what caused the issues, however I believe it has more to do with piston area.
diss7 is offline
Old 03-13-2014, 03:27 AM   #106
acro
Drives: GT-86
Ok cool. keep us posted if possible
acro is offline
Old 05-05-2014, 05:41 PM   #107
1Cor10:23
1Cor10:23's Avatar
Clean them and they'll be fine, but since they aren't painted, etc they aren't as ideal as the OEM stuff in the winter in terms of corrosion resistance.
You could swap them between seasons, kind of a pain in the arse but that's what I would do if I had to deal with salt/etc.
Are there any BBK kits for our platform that are winter safe?
1Cor10:23 is offline
Old 05-05-2014, 05:55 PM   #108
Malt
Drives: 2015 WRX
The only one's I've heard of that are not winter "safe" is the AP racing kits. That's due to the fact that there are no seals on the pistons and no coating on the calipers, both of which lead to corrosion issues. Keep them clean and you'll most likely have no problems.
Malt is offline
The Following User Says Thank You to Malt For This Useful Post:
1Cor10:23 (05-05-2014)
Old 05-05-2014, 06:01 PM   #109
Model Citizen
Lacking brains
Drives: frz
No dust seals isn't exactly uncommon for non street oriented calipers, most if not all wilwoods do not use dust boots either. Talked to a guy with an old looking set of wilwoods at autox yesterday. Said he's used through about 4 salty New England winters, rebuilt once.
I'll be pulling my ap kit for winter.
Oe sti brembos would be winter "safe"and a bbkish upgrade
Model Citizen is offline
Old 01-18-2016, 07:15 AM   #110
TCR
Drives: 2013 Toyota 86 GT
Anyone able to tell me what the piston sizes are in the Sprint Kit 4 piston caliper?
TCR is offline
Old 12-14-2017, 09:33 PM   #111
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
FWIW after posting in this thread in 2013, i bought the 6 piston front and 4 piston rear wilwood kit. they fit on my 17x9 +45 RPF1 but i had to move the wheel weights inboard because there is about 1.5mm clearance between the barrel of the wheel and the caliper
Surok is offline
Old 12-16-2017, 12:10 AM   #112
ShibusaTouge
ShibusaTouge's Avatar
Drives: 2300LB FRS
Why'd you choose Wilwood over Essex? I'm looking now, too, and would love some insight.
ShibusaTouge is offline
Stillen Brakes jdzumwalt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-16-2013 12:57 AM
KW Coilovers, Brembo Brakes, Cusco and more! at Vivid Racing vividracing Brakes, Suspension, Chassis 5 10-15-2012 07:23 PM
help on Wilwood brakes brackets Turbo Den Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-01-2012 09:14 PM
OEM Brakes? marinjim Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-20-2012 11:26 PM
GT brakes jello AUSTRALIA 2 06-10-2012 10:10 AM
