Old 04-27-2014, 01:38 PM   #99
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
FRS uses a lot of coolant?
Ahhh I missed a few pages and I posted in haste as I was waiting a few weeks before posting anything on my findings.
I'm happy to see others arriving at the same conclusion.
CircuitJerk is offline   Reply With Quote
Old 04-28-2014, 09:44 AM   #100
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by CruiseZen View Post
I'm sure you lose a little, especially if you are in an arid environment. However, the amount should be negligible. I'd be surprised if evaporation through that hole exceeded a gallon per year.
If you are losing fluid, you may have a slow leak somewhere. Just keep an eye on fluid levels and top off when necessary.
Well I bought a gallon of coolant from the dealer and the reservoir only took a few ounces.
Old 04-28-2014, 12:19 PM   #101
Pablitomarrero
Pablitomarrero's Avatar
Drives: FR-S 10 series
so if we are loosing coolant by evaporation... shouldn't we be adding only distilled water to the reservoir? Seems to me if the problem is evaporation you are only concentrating the solution everytime you add more coolant
Pablitomarrero is offline   Reply With Quote
Old 04-28-2014, 12:30 PM   #102
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Yeah, that's mostly what I do. I just top the reservoir off with distiller water whenever the level goes down.
Tye300 is offline   Reply With Quote
The Following User Says Thank You to Tye300 For This Useful Post:
Pablitomarrero (04-28-2014)
Old 04-28-2014, 12:33 PM   #103
Pablitomarrero
Seems logical, water evaporates so the concentration of coolant is much higher. If you just add coolant you are increasing concentration even more when water keeps evaporating
The Following User Says Thank You to Pablitomarrero For This Useful Post:
Tye300 (04-28-2014)
Old 04-28-2014, 01:19 PM   #104
victorb
Drives: Black 86
Totally agree with tye300. That's the culprit, the small hole which causes the fluid to evaporate
victorb is offline   Reply With Quote
The Following User Says Thank You to victorb For This Useful Post:
Tye300 (04-28-2014)
Old 04-30-2014, 03:57 PM   #105
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
I couldn't see the coolant at all throughout winter, nowhere near "low" even after a drive. But my temperature gauge is still fine, max was like mid point, so I figured it's fine.
Recently, I checked after a drive home from work (10-15C~ outdoor temp.), I see it 2-3" above "low" mark in the reservoir tank. So it definitely did contract a lot during the cold temperatures. I just can't remember what it was like when I first got the car, I only checked because I read this thread a year ago lol
Myv is offline   Reply With Quote
Old 04-30-2014, 05:27 PM   #106
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
When I first got my car, it was at half.
N1rve
Old 06-16-2014, 12:24 PM   #107
fredfromnh
Drives: 2013 scion frs
After new motor installed I noticed that the bottle was low. I filled radiator and bottle and haven't had problem since. I always check when cold. Imo new and serviced cars have to be burped. These things run hot. I am now looking at aftermarket radiator and cooler thermostat.
fredfromnh is offline   Reply With Quote
Old 06-16-2014, 03:52 PM   #108
calibrz
Turbo 86
Drives: GT86
this is an issue...should recall the car.
10 - 1 = 0
real math
calibrz is offline   Reply With Quote
Old 06-20-2014, 01:13 PM   #109
sluflyer06
Drives: 2014 BRZ Ltd - DGM
People need to also remember that in addition to evaporation, even in a sealed system you would still have a low rate of loss through anything plastic or rubber. These materials are not completely impermeable.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
Old 06-29-2014, 10:14 PM   #110
Evil Jesus
Evil Jesus's Avatar
Drives: '13 FR-S Raven 6MT
Any new developments on this for anyone?
Evil Jesus is offline   Reply With Quote
Old 07-25-2014, 09:07 AM   #111
FR-S Matt
I installed my Mishimoto Radiator last week and Mishimoto hoses. Filled up the coolant, burped the system. Radiator is still full. I keep checking the overflow tank and I swear my car is just drinking coolant. I'm going to check the water pump connection by the crank, but I'm pretty sure I am not seeing any leaks.
About to have to buy a third gallon of coolant because the aftermarket ones take a ton!
Old 07-25-2014, 09:20 AM   #112
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
that's a whole jug of coolant!!
Checking and Changing BRZ/FR-S Engine Coolant GrimmSpeed DIY (Do-It-Yourself) Guides 39 05-29-2023 08:15 AM
Blue Coolant Boosted2.0 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 108 07-12-2016 05:13 PM
Coolant Levels DriftEightSix AUSTRALIA 17 01-29-2013 09:19 AM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 12:03 PM
European fuel/coolant gauge face arbnpx Cosmetic Modification (Interior/Exterior/Lighting) 0 05-31-2012 12:23 AM
