#99 |
#100 |
Drives: Toyota GT86
#101 |
Ah, apologies. I reply to hundreds of messages/emails a day, and don't look for context unless clued in!
For your setup, CP front and rear would get the job done without issue, and also be pretty quiet. The only caveat will be that you will want to FULLY cool your brakes down after each lap before parking, so that you do not get unwanted brake deposits from the pad sticking to the rotor, as the CP is ultimately a supremely capable street pad. It doesn't like being parked hot. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Ruben_86_ (11-24-2023) |
#102 | |
Drives: Toyota GT86
Thank you very much, I had no idea of that characteristic, I will try them next year |
#103 |
Drives: 22 BRZ limited
I checked my CSG CP pads on stock sliders after about 2 years of dd and autocross. I have just under 20k miles on these pads.
The material left is between 9.5-10mm because of slight pad taper. They have always had a slight bit of noise likely because I put them on stock rotors that had been run for 6k miles.
#104 |
@dragoontwo two those look basically new!
#105 | |
#106 |
| The Following User Says Thank You to CSG Mike For This Useful Post: | dragoontwo (11-27-2023) |
| Tags |
| csg brakes, csg spec |
| CSG Brake Thread - Expert Tuner/Motorsport Brake Advice & Experience | CounterSpace Garage | Brakes, Suspension, Chassis | 14 | 10-23-2019 01:54 PM |
| D1 Spec Big Brake Kit W/ SS Brake lines | Sweet48 | Canada Classifieds | 1 | 11-19-2017 04:31 PM |
| Khumo V710 R Compounds $150 | Deep Six | Wheels and Tires | 0 | 10-17-2016 08:44 AM |
| Wtb: 245/45/17 r compounds | SterlingBrz | Want-To-Buy Requests | 2 | 08-31-2014 01:48 AM |
| Suggested R compounds and wheels for CS | Oldfatguy | Tracking / Autocross / HPDE / Drifting | 36 | 09-11-2013 12:14 PM |
