Old 11-23-2023, 06:32 PM   #99
CSG Mike
CSG Mike's Avatar
Originally Posted by Ruben_86_ View Post
Any recommendations for my setup?
You'll want to email CSG with your setup and use case, for a recommendation. I have no idea what your setup is or what you do with the car, so any recommendation I make is just a blind shot in the dark.
Old 11-24-2023, 02:14 AM   #100
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
I had put it above😅
Ruben_86_ is offline   Reply With Quote
Old 11-24-2023, 03:33 PM   #101
CSG Mike
CSG Mike's Avatar
I had put it above😅
Ah, apologies. I reply to hundreds of messages/emails a day, and don't look for context unless clued in!
For your setup, CP front and rear would get the job done without issue, and also be pretty quiet.
The only caveat will be that you will want to FULLY cool your brakes down after each lap before parking, so that you do not get unwanted brake deposits from the pad sticking to the rotor, as the CP is ultimately a supremely capable street pad. It doesn't like being parked hot.
Ruben_86_ (11-24-2023)
Old 11-24-2023, 05:28 PM   #102
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
Thank you very much, I had no idea of that characteristic, I will try them next year
Old 11-25-2023, 12:55 PM   #103
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
I checked my CSG CP pads on stock sliders after about 2 years of dd and autocross. I have just under 20k miles on these pads.
The material left is between 9.5-10mm because of slight pad taper. They have always had a slight bit of noise likely because I put them on stock rotors that had been run for 6k miles.
The Following 2 Users Say Thank You to dragoontwo For This Useful Post:
Jdmjunkie (11-25-2023), Ruben_86_ (11-28-2023)
Old 11-26-2023, 12:16 PM   #104
CSG Mike
CSG Mike's Avatar
@dragoontwo two those look basically new!
Old 11-26-2023, 06:13 PM   #105
dragoontwo
dragoontwo's Avatar
If you say so. What is the new thickness supposed to be for the CP on the stock calipers?
Old 11-27-2023, 12:25 AM   #106
CSG Mike
CSG Mike's Avatar
18mm front 17mm rear, including the backing plate.
dragoontwo (11-27-2023)
csg brakes, csg spec
CSG Brake Thread - Expert Tuner/Motorsport Brake Advice & Experience CounterSpace Garage Brakes, Suspension, Chassis 14 10-23-2019 12:54 PM
D1 Spec Big Brake Kit W/ SS Brake lines Sweet48 Canada Classifieds 1 11-19-2017 03:31 PM
Khumo V710 R Compounds $150 Deep Six Wheels and Tires 0 10-17-2016 07:44 AM
Wtb: 245/45/17 r compounds SterlingBrz Want-To-Buy Requests 2 08-31-2014 12:48 AM
Suggested R compounds and wheels for CS Oldfatguy Tracking / Autocross / HPDE / Drifting 36 09-11-2013 11:14 AM
