#99 | |
I don't want to argue with anyone, just seemed like he's waiting for an "expensive" kit with a bunch of features he doesn't want when he can do the swap right now for maybe a couple grand on top of the motor. Taking the CAN electronics out of the picture makes this whole thing so simple |
#100 | |
Drives: Track preped NA FRS
#101 |
Drives: Q5 + BRZ + M796
Exactly, he could do the swap now and cheaper if he wants or put that same money into the FA20 with some weight reduction mods and be in a similar situation.
#102 | |
#103 |
I noticed that after posting and deleted the statement.
#104 | |
#105 | |
#106 | |
Drives: 13 FRS Firestorm
![]() Sent from my SM-G9600 using Tapatalk |
#107 |
Drives: 2013 Subaru BRZ
#108 |
Drives: 2JZ FRS
same as LS/2J. cluster, drive by wire, stock fuel pump controller, stock fan controller, abs, custom traction control, push button start, cruise control, etc.
#109 |
What will the header, mounts, motec setup run?
I know it sounds like a shifter will be an issue, is the S2K trans further forward? I know many KMiata guys are starting to use the BMW 5 speed, thoughts on using those in the 86? |
#110 |
Only users lose drugs.
Drives: All the time
For those of us who plan to stay NA, I think having the option to purchase an adapter to keep the 86 transmission would be well worth it, compared to the headache of modifying the S2000 shifter, on top of the purchase price for that transmission, plus the need to use a different adapter anyways to connect the K motor and S2K trans... I get that the S2000 trans is stronger, but not everyone necessarily needs that in the first place.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#111 | |
#112 | |
An adapter is already being used to connect the fwd K motor to the S2K transmission anyways, so the cost of the kit should theoretically be the same. Plus you'd be saving the actual cost of the S2K transmission, plus whatever shifter/console modification would be necessary. There would also be the chance of the 86 transmission actually staying in the same position in the car, further eliminating the need/cost for a custom driveshaft. That one I'm not sure of, but it'd be a nice perk if so.. For those of us whom this swap appeals to for the sake of losing weight and cleaning up the engine compartment, rather than being the basis for a high horsepower build, this would seem to be a much more attractive option.
| Pure Auto's Swap Compilation Thread - 2JZ and LSX ! | Pure Automotive | Engine Swaps | 29 | 01-10-2018 01:20 AM |
| SwapYour86.Com Pure Automotive 2JZGTE Billet Intake Manifold For 2JZ FT86 Swap | Pure Automotive | Engine Swap | 0 | 12-01-2017 11:57 AM |
| SwapYour86.Com Pure 2JZ MoTeC Plug & Play Wiring For FT86 !! | Pure Automotive | Engine Swap | 0 | 12-01-2017 11:49 AM |
| SwapYour86.Com Pure LSX MoTeC Plug & Play Wiring For FT86 !! | Pure Automotive | Engine Swap | 0 | 12-01-2017 11:23 AM |
| Pure Auto's 2JZ Swap Thread - The DRAGFRS | Pure Automotive | Engine Swaps | 153 | 06-20-2016 06:33 PM |
