03-30-2013, 04:13 AM | #1093 | |
Drives: 2013 FRS/01 Tacoma
I was thinking about going 17" but after seeing others run them they look small. This makes them slam their ride which makes it look horrible because they sacrifice disability. Thanks again |
03-30-2013, 04:37 AM | #1094 |
Drives: BMW E84
I was having a hard time finding correct size tires for 18s so I ended up ordering 17s. With that being said, I'd only run Michelin Pilot Super Sport if my only option was running 18s among other "available" correct size tires.
The Following User Says Thank You to B L U E S L A T E For This Useful Post: | 20valvewynn83 (03-30-2013) |
03-30-2013, 09:02 AM | #1095 |
Drives: 2018 BMW M240i
Thanks for the help.
Vracer111 your post really breaks down the Kosei and is perfect for someone like (who is new to this) to see some of the things to look for when choosing a high performance/ high quality wheel. MVJ1975 yours goes without saying. I should have picked up on that myself. Japan made >>>> 90% of China made products any day. |
03-30-2013, 11:43 PM | #1096 |
Drives: 2013 Raven FRS
Would 18x9.5 et30 on coilivers be good? I have no idea what size tire to go with yet.
03-31-2013, 12:03 AM | #1097 |
Drives: BRZ LTD
TO sum it up .. i could easily go "touring"?
Any recommend?? |
03-31-2013, 01:57 AM | #1098 | |
Drives: None currently
http://www.roadandtrack.com/special-...transformation |
The Following User Says Thank You to tondelayo For This Useful Post: | 20valvewynn83 (03-31-2013) |
03-31-2013, 02:38 AM | #1099 |
Seņor Member
Drives: white BRZ 6MT
generally want advice as to what width/section tire would come close to stock diameter on 18x9
03-31-2013, 03:42 AM | #1100 | |
Only issue with the article is its running an 18x7.5 with only one type of tire. For instance the star spec. Tire weight is somewhere around 225lbs wich is pretty heavy. I would love to see this test done with a wider wheel and a lighter tire maybe the hankook EVO thats weight is 22lbs. So with the advans and tires they are at about 43lbs each wheel with a total of 172lbs. The factory wheel (20.4) tire (20) set up is 40.4lbs with a total of 161.6lbs which makes the advan set up 10.4 lbs heavier. I think that with the 57DR gram lights (18lbs) with the hankook EVO K110 (22) this setup will out perform the stock setup with different tires. Total weight is 40lbs and a overall weight of 160lbs which is lighter then stock by 1.6lbs. Now the star spec tires are at 22lbs which makes the stock wheel and star spec tires at 42.4lbs with an over all weight of 169.6lbs. So the gram lights with a wider wheel and lighter tire are 9.6lbs lighter. |
03-31-2013, 08:26 AM | #1101 | |
Drives: FR-S Firestorm 6MT
225/40 is a smidgen tall but also too narrow for these wheels, unless you're a fan of stretch. 235/40 are too tall, same for 245/40 255/35R18 are very close to factory diameter also and will be better suited for a 9" wheel. (if you can fit a 255 upfront, depending on offset you may not) 265/35 are pretty close too, but into uncharted territory, unless running just on rears. I verified my tire specs on TireRack.com before I purchased. Check the tires you like versus the OEM diameter (24.7") and revolutions per mile (844) and compare. Do this because all tire brands are a bit different. |
03-31-2013, 02:03 PM | #1102 | |
Seņor Member
I figure 225/40 is the way to go for the fronts. 245/35 seems to be perfect but it doesn't seem like there are many options in that size. Not to mention that the tire I was looking at (Dunlop DZ101) isn't offered in that size. 255/35 looks like it works well but I don't know if I want that much tire back there. I mean, this particular set is mainly for looks, so maybe I shouldn't sweat it.
03-31-2013, 04:34 PM | #1103 |
Winter is Coming
Drives: GBS BRZ
Recommendation on tire size...
I'm not sure what size tire I should go with on my BRZ without rubbing. I have the RCE yellows installed and am now looking to match some treads/wheels to my car. I have a set of four 18x8.5 rims (see specs below), I need to buy some rubber for them and I want some meat on my wheels, I'm not looking for low profile bricks. Can anyone give me some suggestions. I was thinking 235/40 18s square, so I can rotate my tires and also not rub my fenders or strut housing. I will post a pic once I get them mounted on the car. By the way, the wheels look so much better in person than the photos I've seen posted.
MRR/Eurotek UO3 Size: 18 8.5 bolt pattern: 5x100 offsets 38 Finish: Hyper black Hub centric 56.1 to the FRS/BRZ Last edited by Mango22; 04-01-2013 at 05:20 PM. |
03-31-2013, 05:16 PM | #1104 |
KCCO From Canada
Drives: Asphalt FRS
235/40 would be alright, 245/35 would be my pick though.
The Following User Says Thank You to FreshFRS For This Useful Post: | Mango22 (03-31-2013) |
03-31-2013, 07:50 PM | #1105 | |
225 sounds good on the front with 8" width wheels. |
The Following User Says Thank You to Slick For This Useful Post: | dori. (03-31-2013) |
04-01-2013, 11:28 PM | #1106 |
Bringing Hachiroku Back
Drives: 2013 Firestorm FR-S
Great thread. Subscribed.
Tags |
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
Similar Threads | ||||
Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
