Old 02-06-2019, 12:28 PM   #1093
fika84
fika84's Avatar
Thanks @DustinS and @Sportsguy83 for all of the helpful posts.. I just lost all faith in the FA20 the other day when it started knocking with less than 35k on the odo and stock internals.. up until that time I was planning on building an NA FA20 after following @celek for so long.. I even have the spare FA20 with spun bearing in my garage that I was going to build... but now I think I'm going to sell all the FA20 stuff and go with something a bit stronger... time for an LS! I am going to do one part a bit different though and opt for the Tremec T5 transmission since I have 4.88 rear end and the T56 would be crazy short. https://ls1tech.com/forums/manual-tr...-can-here.html Do you guys have any thoughts on that path? I've read that it's a bit more compact, doesn't handle high RPM that well, but I think it'll do the job. My buddy in college had a supercharged 5.0 mustang with the T5 and it handled all that power pretty well.
fika84 is offline   Reply With Quote
Old 02-06-2019, 01:21 PM   #1094
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
@fika84 I have never worked with a T5 so I wouldn't know. The link you posted is showing a mid 3.XX final drive. I think the 4.88 will still be way too short. I would look for at least an OEM final drive.
On build news. Ordered the new radiator. After much research and searching I went with the Chase Bays S Chassis tuck radiator. It's the size I wanted with a dual pass, dual core and already has -20an fittings. Hopefully have that before the car gets taken down for a clutch job.
Also looking at a fuel cell. Kind of decided on a simple 15 gallon tank and installing an Aeromotive Phantom into it.
Only 7" tall. I will then cut a couple holes to mount the factory fuel level sensors so my factory gauges work as normal.
DustinS is offline   Reply With Quote
Old 02-06-2019, 01:48 PM   #1095
fika84
fika84's Avatar
@DustinS yeah you're right on this one... the 4.88 is way to high for these engines unless I want a top speed of 80mph in 5th. Are you rocking the stock 4.1 ratio?
Old 02-06-2019, 01:50 PM   #1096
DustinS
DustinS's Avatar
@fika84 Yes I still have the stock 4.1. Hesitant to get rid of it as it will be good if I can get traction haha. Traction is the current issue though. So if I can get a deal on an IS300 diff I will probably jump on it.
Old 02-06-2019, 01:54 PM   #1097
fika84
fika84's Avatar
I had one a while back with 3.91, but sold the gears out of it because I was just using the carrier for the lsd and 4.88.. I do still have the stock 4.1 though..
Old 02-06-2019, 01:55 PM   #1098
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I initially ran the stock 4.1 and it felt like 1st and 2nd were extremely short. I've since got a good deal on a IS300 3.73 and it's been a dream to drive the car since. All gears are much more usable now.
Old 02-06-2019, 01:57 PM   #1099
fika84
fika84's Avatar
Do you think you would consider going even lower (3.55 or so) after having the 3.73?
Old 02-06-2019, 02:00 PM   #1100
Sportsguy83
Drives: Limited BRZ
I think it will depend on your plans with the car on the long term.
Among other factors, consider that if you will be adding nice, grippy, wide tires and doing an NA build, I think 3.73 is the sweet spot. If you plan on boosting the car later, it may be needed to go even lower to try and offset tire spin when the boost kicks in.
Old 02-06-2019, 02:03 PM   #1101
fika84
fika84's Avatar
True story and good point. As it sits now, the car is fully gutted and will be a road race car pretty much 100% of the time. So N/A and 3.73 is probably the best way to go.. good thing is that now I'll have more parts to sell! Thanks for the considerations!
End
Old 02-20-2019, 10:18 AM   #1102
DustinS
DustinS's Avatar
New Radiator Came in:
Old 03-01-2019, 09:32 AM   #1103
DustinS
DustinS's Avatar
Oil Pump came in yesterday. Will get better pictures later. Should help with the oil pressure issues. As soon as the weather quits giving us one 60 degree day and then a week of 20 degree days, I will start tearing the car apart to get everything buttoned up.
Old 03-01-2019, 11:55 AM   #1104
GrabTheWheel
Drives: 16' BRZ
End
You should go with the trans that is the best fit for the swap. That would be a TR6060 or a magnum XL if you can swing it. I went with a 3.73 final drive with a 2.66 first gear as it was the shortest I could go without having to shift into 3rd for AutoX. You can get what ever ring and pinion you want from these guys.
https://www.justdifferentials.com/se...C-STV6&Submit=
GrabTheWheel is offline   Reply With Quote
Old 03-01-2019, 12:03 PM   #1105
GrabTheWheel
Drives: 16' BRZ
That is a bad ass looking radiator and nice Melling oil pump as well. Can I ask what size oil cooler you’re going with? What do you plan on doing with your car? Will it be running Hoosiers and full aero? If yes, I’m sure you’re aware oil pressure is a problem.
Old 03-01-2019, 02:35 PM   #1106
DustinS
DustinS's Avatar
Nice find! This will be helpful.
Something close to a Setrab Series 9 34 Row most likely.
Car is 99% Street Driven (Currently my DD besides when Ice/Snow is on the ground, or if I feel like driving the miata). The other 1% is autox (which the car group I am apart of puts on outside of local SCCA events) and backroad runs . Eventually a few trips to hallett will occur when I can get the car squared away. My car is the definition of "Track Inspired build" as it's not feasible to make it to the track yet.
I don't really ever plan to run slicks but I am aware of oiling issues. One of the reasons my first engine only lasted 8k miles. TSP assures me I don't have anything to worry about (As does a local drag car builder), but if I didn't, the first engine wouldn't have failed. Will eventually go Dry Sump when the funds become available.
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 03:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-21-2015 11:38 PM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 11:14 AM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 07:32 PM
