#1079 | |
BASE TIMING B KNOCK CORRECTION MAX A IAT COMPENSATION (2 tables) from wayno,s example maps into your tune should sort it as 98 ron is arround same as your 91 USA fuel |
| The Following User Says Thank You to steve99 For This Useful Post: | HLHachiRoku (04-16-2016) |
#1080 |
Drives: 2015 HL FR-S
So im to put 0.00 in all the spaces for base timing b? iat comp? I dont see where to get that info, is it in the zip file? Thanks again! I have been playing around with rom raider, hopefully not messing things up trying out things. lol.
#1081 | |
Nnnnooo don't put all zeros in. The 0.00 are their cause its showing a comparision not the absolute values. you will need to open the rom for 98 fuels at the end of wayno's post here http://www.ft86club.com/forums/showthread.php?t=83945 then copy the Base timing A Base Timing B Knock Correction MAX A Timing Compensation (IAT) Timing compensation IAT (Activation) into your rom. |
#1082 | |
Drives: Toyota 86 GTS
| The Following 2 Users Say Thank You to Wayno For This Useful Post: | HLHachiRoku (04-17-2016), steve99 (04-16-2016) |
#1083 |
#1084 | |
or WW v100 2016-04-15 A01G.UEL.zip I don't see a v98 one, all WW v100 other then the OFT defs.zip one. =o Sorry |
#1085 |
Drives: 2017 BRZ
Looks like I've still got many things to sort out. I spent quite a bit of time inspecting the exhaust and only found a small leak at the v-band on the midpipe, which I tightened. I snugged up the header/overpipe and header/head connections as well, and the O2 sensors which aren't moving and seem fully seated and snug.
I also seem to have knock across the board on 93 octane (Shell) with a 91 octane tune. Only 3rd gear pull as far as I could take it - traffic is crummy today because the weather is quite nice. Clear knock issues. http://datazap.me/u/cjd/post-exhaust...zoom=7975-8147 LFTF overall still seems to be bad news. Start of the trip (to Target) http://datazap.me/u/cjd/post-exhaust...data=1-2-5-6-8 From Target to the gas station http://datazap.me/u/cjd/post-exhaust...1&data=1-2-5-8 From the gas station to pick up bagels (I stayed in the car idling) and then home: assuming I can even save this log! Full 20 minute log and it's locking up trying to load it (can't even get to trying to save it.) - will update if it ever works The last few blocks after I was able to save the 3rd part at a light: http://datazap.me/u/cjd/part-4-after...data=1-2-5-6-8 |
#1086 | |
unzip the tune files and you will see a 98 version Last edited by steve99; 04-16-2016 at 09:24 PM. |
| The Following User Says Thank You to steve99 For This Useful Post: | HLHachiRoku (04-17-2016) |
#1087 |
Drives: Toyota GT86
This is a datalog with the new OFH tunes of Shiv, combined with some edits based on Wayno and Steve99 work.
This is a Euro GT86 OFT CalId A00G running on (good) Ron98. Datazap log There are 2 logs, Only some KC of -0.69 in the 3000 - 3500 rpm range with an engineload around 1.0 Mods: - OpenFlash Header - shorted intake snorkel (stock filter) - Crawford BPB - Milltek exhaust
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
#1088 |
So I installed the OFH tune and data logged a lot yesterday. I added commanded AFR and took out kc learned since that isn't really used to see knock and I wanted to see the difference between the two if there was much at all. I can tell you that it felt better down low, and up high. My adv mult also stayed at 1 the entire time!!! (been having issues with it dropping a ton =( Also noticed smoother revs, nothing jerky at all like in the ofs tune i was using. The car felt way more "alive" then before thats for sure. Let me know what you think of these. =D Thanks! (some of the roads were bumpy, not just a small bump, so not sure if that has anything do do with some of the cruising readings)
See below: Cruising: http://www.datazap.me/u/hlhachiroku/...data=1-5-11-12 This one has a bad dip of -2.55 flkc, but other then that everything is smooth from what I can see. http://www.datazap.me/u/hlhachiroku/...data=1-5-11-12 This had a dip of knoc corr but flkc stated at 0 entire time http://www.datazap.me/u/hlhachiroku/...data=1-5-11-12 Starting to see more flkc =o http://www.datazap.me/u/hlhachiroku/...data=1-5-11-12 Freeway bursts: This doesn't look good under WOT however. Not really sure what was going on, car felt super strong (when i went from 2nd to 3rd, the traction control kicked in for a bit (1st part of the polt and I had to let off and then punch it again) Adv mult stated at 1, knoc corr wasnt scary but flkc under WOT... ahhh... don't think thats good.. lol http://www.datazap.me/u/hlhachiroku/...data=1-5-11-12 http://www.datazap.me/u/hlhachiroku/...data=1-5-11-12 This was mainly cruising, with a WOT burst. Starting to get worried about these numbers =O http://www.datazap.me/u/hlhachiroku/...data=1-5-11-12 NEW logs today 4/17/16 What happened here?!?! http://www.datazap.me/u/hlhachiroku/...data=1-5-11-12 -1024 knock!? everything went to 0?!.... I didn't feel anything in the car while cruising along.... http://www.datazap.me/u/hlhachiroku/...zoom=7370-7733 ZOOMED IN.... that can't be good... http://www.datazap.me/u/hlhachiroku/...data=1-5-11-12 http://www.datazap.me/u/hlhachiroku/...data=1-5-11-12 freeway gear run through http://www.datazap.me/u/hlhachiroku/...data=1-5-11-12 http://www.datazap.me/u/hlhachiroku/...data=1-5-11-12 http://www.datazap.me/u/hlhachiroku/...data=1-5-11-12 http://www.datazap.me/u/hlhachiroku/...data=1-5-11-12 perfect here though.. grrr lol http://www.datazap.me/u/hlhachiroku/...data=1-5-11-12 Last edited by HLHachiRoku; 04-17-2016 at 10:54 PM. |
#1089 |
Drives: '22 BRZ
All of your links are messed up @HLHachiRoku
#1091 |
Drives: 2016 Scion FR-S
I tested out the latest OFH 91 UEL tune (on a 1320 UEL Header) can someone please pls interpret this for me...
http://www.datazap.me/u/dru670/ofh-t...1-2-3-5-6-9-12 And then I reverted back to the OTS stage 2 UEL 91 tune here http://www.datazap.me/u/dru670/stage...data=1-9-13-14 Am I running fine? BTW for some reason the Stage 2 91 UEL tune my OFT doesn't have any MAF voltage and IAM readings but when I flashed the OFH tune the OFT was reporting the MAF voltage and IAM. Last edited by Dru670; 04-18-2016 at 05:16 PM. Reason: added info |
#1092 |
@Shiv@Openflash @steve99 is my car (with a 1320 Performance UEL Header) running better with the latest OFH 91 UEL tune than the OTS Stage 2 91 UEL tune? Shiv mentioned that I was getting "too much knock retard (neg FLKC) above 7k RPM" on the OFH tune but looking at the OTS Stage 2 91 UEL my FLKC is all over the place. I even went back and looked at all my other logs with the OTS Stage 2 91 UEL tune and the FLKC is averaging at -5 through the entire log but with the OFH tune it seems to be at 0 for the most part.
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 02:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 01:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 10:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 05:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 10:27 AM |
