Old 01-22-2013, 04:40 PM   #1079
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
I see where he's coming from about the MPG. Its really hard to give a fair figure unless you've put on a ton of kms and averaged out a few tanks. Browsing this forum I see some people averaging 40+ mpg and others barely cracking 30 mpg. Part of it is gas, driving habits, climate, driving distance etc.
Say he says its 35mpg on the highway, if its worst than that, everyone complains about false figures.
pheoxs is offline
Old 01-22-2013, 04:45 PM   #1080
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Would be good to get some beta tester types on fuelly
Huehuecoyotl is offline
Old 01-22-2013, 04:46 PM   #1081
TemeCal
Drives: 86
Originally Posted by industrial View Post
Ok.
Take the foot out of the equation. This is what we're asking. Say I average 32mpg over a tank of gas driving back and forth to work. Mostly (90%) highway driving at 75mph with a few sprints here and there. Assuming that everything else stays exactly the same except this supercharger, how much would mpg suffer?
Regardless, I think anyone installing this kit will be ditching the tires and there goes a big chunk of MPG anyway but I'm curious about the original question too.
You have to realize who you're dealing with here. I think everyone understood what you were saying, except for Visconti. This is an extremely typical, and expected response from him.
TemeCal is offline
Old 01-22-2013, 05:18 PM   #1082
Innovate Motorsports
Drives: Scion FRS, Subaru BRZ, Supercharged
I do not think any ill will was intended on anyone's part. Let us be urbane from now on. Go fast stuff is supposed to be fun, it's why we all enjoy it.
Innovate Motorsports is offline
Old 01-22-2013, 05:26 PM   #1083
TemeCal
Drives: 86
I completely agree! I am REALLY looking forward to your kit. I'm hopefully optimistic that some of the other tuners (ie: FA20Club/Perrin/others) jump in and have something to offer as well.
TemeCal is offline
Old 01-22-2013, 05:31 PM   #1084
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
No ill will for sure. To ask that we be urbane on an internet forum? That's asking for alot! It's too easy for people to be asshats online. I think we're all just eager for some real numbers already so we can start planning/dreaming about the direction we'll be taking our car.
industrial is offline
Old 01-22-2013, 05:39 PM   #1085
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
We, as intelligent individuals, can choose to be. I can totally sympathize regarding the wait. But it shall be worth it, and won't be much longer...
mines13 is offline
Old 01-22-2013, 05:57 PM   #1086
johnnie
Drives: GT86
There are way too many variables to have a reliable answer. That's why there's a whole standard for comparable results.
johnnie is offline
Old 01-22-2013, 07:14 PM   #1087
Visconti
Drives: 05 STi
Ready for the Dyno to go into the ground
Dynosheets soon!
Visconti is offline
Old 01-22-2013, 08:52 PM   #1088
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Dynosheets soon!
PRO86 | STL | LuckyDog
rice_classic is offline
Old 01-22-2013, 09:10 PM   #1089
roddy
roddy's Avatar
Drives: '13 Ultramarine
Dumb question but what is fuel economy going to be after an install like this?
If you can keep it out of boost, the difference would be negligable, but we all know that's not going to happen. Boost is addictive.
Edit for explanation... If it's anything like the MP-90 on my Mustang, there is a bypass valve that releases boost pressure when you're not "on it". When the actuator sees 0 manifold vacuum, that valve closes, and bam! you have boost. Under cruise conditions at light throttle, there is plenty of manifold vacuum (typically 10-20 in.Hg), and the bypass valve stays open. In these conditions, you're only using enough power to turn the rotors, not build pressure. It doesn't take much power to turn the free-wheeling rotors, so the impact on fuel economy is minimal.
Good luck keeping your foot out of it with one of these, though. Too fun.
roddy is offline
Old 01-23-2013, 11:37 AM   #1090
Huehuecoyotl
Originally Posted by roddy View Post
If you can keep it out of boost, the difference would be negligable, ... If it's anything like the MP-90 on my Mustang, there is a bypass valve that releases boost pressure when you're not "on it". When the actuator sees 0 manifold vacuum, that valve closes, and bam! you have boost. Under cruise conditions at light throttle, there is plenty of manifold vacuum (typically 10-20 in.Hg), and the bypass valve stays open. In these conditions, you're only using enough power to turn the rotors, not build pressure. It doesn't take much power to turn the free-wheeling rotors, so the impact on fuel economy is minimal.
thats interesting.
Is there an option to add such a bypass valve actuator to aftermarket SC kits?
Old 01-23-2013, 12:04 PM   #1091
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Originally Posted by Huehuecoyotl View Post
thats interesting.
Both roots and screw superchargers are positive displacement and both require bypass valves to prevent too much displacement during idle/general driving. The bypass valves are not necessarily an on/off valve but rather linked via vac/psi reference. The valves merely allow a portion of air flow to literally bypass the rotors in the supercharger housing. Similar to the way a wastegate bypasses the exhaust gases around the turbine of a turbocharger. So yes you could use an aftermarket bypass valve but for the most part they are pretty standard equipment.
AZFA20 is offline
Old 01-23-2013, 01:36 PM   #1092
drifter
Drives: truck and old car
i wish someone would just invent a simple "on/off" switch for this added boost like the batmobile
drifter is offline
***Recaro / Racetech / OMP / STATUS / Defi / Apexi / HKS / Innovate / AEM / Cobb***** Touge Factory Interior Parts (Incl. Lighting) 9 11-29-2012 02:13 PM
lost screw for sensor intake Mr.Jay Engine, Exhaust, Transmission 5 10-21-2012 09:26 PM
Lowest Prices on all Gauges and Electronics! Defi|STRI|AEM|INNOVATE+More Rev Works Audio/Visual, Electronics, Infotainment, NAV 28 10-09-2012 05:04 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
Missing rubber piece for intake screw ngabdala Engine, Exhaust, Transmission 1 08-31-2012 06:10 AM
