03-29-2013, 08:39 PM | #1079 | |
Enthusiast
Drives: 2013 Scion FR-S (37J)
03-29-2013, 09:13 PM | #1080 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
What about Enkei Fujins? ~17.1lbs, 17x7.5 with +40mm offset...
I have and love the Kosei K4R's (17x8 with 36mm offset) riding on Kumho Ecsta XS (215/45-17) for track duty - over 4lb weight savings a corner and you can really feel the difference in makes in handling. Rear tires worn down to wear bars in combination of aggressive street driving and a track day in ~8k miles though. Currently back on stockers, but hate how the stock wheel and tire weight affects the suspension in comparison (nothing wrong with the grip levels and handling though), so I will be swapping out to Enkei Fujin's for the daily driver's - transferring over the TPMS and tires to them. Once the 'Prius' tires wear out I'll probably go with 205/45-17 Kumho Ecsta LE Sports, which are an awesome, inexpensive (less than $90) Max Performance Summer category tire with superb wet handling and very good dry grip. With a tread width of 7.7" the 205/45-17 size will be a perfect match for 17x7.5 wheels and lighter than wider sizes...should be within ~1lb of the 17x8 K4R and 215/45-17 Ecsta XS setup.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
03-29-2013, 10:41 PM | #1081 |
Drives: 2018 BMW M240i
Since I am new to performance and custom wheels can I ask why so many here hold the Kosei K4R's in such high regard?
Outside of style what makes them superior to the Motegi? (sorry not being a d!ck I am just somewhat of a newb). |
03-29-2013, 11:14 PM | #1082 | |
Drives: 2013 FRS/01 Tacoma
03-29-2013, 11:23 PM | #1083 |
Red wine
Drives: Subaru BRZ(R.I.P)
They are super lightweight at a very good price and they look good and are made by Toyota.
03-29-2013, 11:24 PM | #1084 |
Drives: Attitude
235/35/19. On a 9" wide wheel.
The Following User Says Thank You to OrbitalEllipses For This Useful Post: | 20valvewynn83 (03-30-2013) |
03-29-2013, 11:24 PM | #1085 |
Drives: Whiteout FR-S
We don't all live in socal, wish i could run rs3's or star specs but those tires aren't thes best choice for every enviroment.
The Following User Says Thank You to JoeBoxer For This Useful Post: | 20valvewynn83 (03-30-2013) |
03-29-2013, 11:34 PM | #1086 | |
If you compare the Kosei K4R to the Motegi MR125 you can see the extra care Kosei took in engineering their wheel versus Motegi to handle track loading better (root blending and spoke geometry)... the Motegi MR125 would probably be 'ok' to track, but I'd much rather go with the better designed wheel. Motegi did make an excellent forged lightweight track wheel known as the Traklite, but it doesn't come in any sizes (- offsets or huge + offsets) that really fit the FR-S any more. Not sure on the Motegi MR125, but with the Kosei K4R's there is a ridiculous amount of clearance if you want to upgrade your brakes to the AP Racing Essex Sprint kit:
03-29-2013, 11:44 PM | #1087 |
Automatic Hooligan
Kosei K4R - made in Japan by a quality JDM manufacturer. As said, Kosei makes OEM wheels for Toyota.
Motegi MR125 - made in China. I don't think I need to say any more than that...
03-30-2013, 12:32 AM | #1088 |
Drives: 2013 Scion FRS
well the thing is about star specs or rs3 they have like 140 tread wear, where as something Like Michelin pilot super sports or falken 453 give you 300 tread wear.
you have to sacrifice Grip for longevity. my friend has PSS on his e46 m3 and he wouldnt have any other tire they are hella grippy. |
The Following User Says Thank You to powerj2 For This Useful Post: | 20valvewynn83 (03-30-2013) |
03-30-2013, 12:55 AM | #1089 |
A Very Annoying Person
Drives: Subaru Impreza :( Hopefully BRZ
The Following User Says Thank You to NorseLegend For This Useful Post: | 20valvewynn83 (03-30-2013) |
03-30-2013, 02:47 AM | #1090 |
Drives: 2013 BRZ Limited SWP
Do you have a budget? Is wet grip important? How cold does it get? These can all help you decide on what fits your needs and funds the best.
The Michelin Pilot Sports are nice but also a bit more expensive than the Conti's and are probably only marginally better. This being said I really like the Pilots. Eagle F1s are good tires but I find they are a little noisy and don't have the grip the pilots do. I've done well with Bridgestone RE-11s as well but kinda heavy tires. I've heard good things about Yokohama AD008s but have never actually owned/driven them. Same goes for Nittos. I've had RS-3s and Star Specs on my dedicated track cars which are great tires but maybe not the best for street use. They're sticky enough to pick up debris from the road and throw it up inside your fenders and on the side of your car. They also will not wear well if your car is a Daily Driver. (not that any summer tire will get you 40K miles ) From the sound of your driving needs any good summer tire will fit your bill. Putting 245s on your car will give you more than enough grip for public roads- if not you're probably driving a bit too fast. Also if you've never tracked your car taking things slowly and having forgiving tires with a little less grip is probably better than driving faster than your skill level hurting your car (or yourself) The great thing about summer tires is if you buy a set and don't like them they won't last that long anyway, so you can buy something different next time! Good luck!
Past Subarus: 08 STI, 05 Legacy GT, 98 Legacy L wagon, 97 SVX LSi
Daily Driver: 2013 Acura MDX |
The Following 2 Users Say Thank You to TSY For This Useful Post: | 20valvewynn83 (03-30-2013), Fly Guy (03-31-2013) |
03-30-2013, 03:12 AM | #1091 | |
03-30-2013, 03:49 AM | #1092 | |
You're budget covers about anything, and being California I guess you don't have to worry about snow or monsoons. As for 245s, I thought that's what you were thinking which is probably a good fit for the wheels you bought. 235s are hard to find. You definitely want to run a 35 profile tire, a 45 will increase your tire diameter by 2" (and raise your car up by 1")! If you need the clearance and want to go off road then get a different car. I don't have experience with that Hankook tire- did you see if Tire Rack did any tests with them? I myself will probably get the new star specs in a 245/40-17 as my track/autocross tire. I'm torn between the Pilots and the Conti DW's for a street tire (mostly for looks) in a 225/40-18. I may stay with a 17" street tire though since we have a lot of potholes and bad roads here. You've got a good set of wheels- put some tires on them and go drive! One more piece of advice, if you do get out to a track you might learn more from driving these skinny stock tires on the car than big fat sticky ones. Just something to think about! Have fun!
Daily Driver: 2013 Acura MDX Last edited by TSY; 03-31-2013 at 01:29 PM. |
Tags |
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
Similar Threads | ||||
Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
